Question about Pioneer Audio Players & Recorders
Pioneer receiver sx 880 when volume turned up around 1/3 way, sound cuts out
SOURCE: Pioneer SX-203
Try taking the receiver apart and checking the fuses.
Posted on Mar 23, 2008
SOURCE: Pioneer receiver sx-315
With persistence, I was able to program the Universal Remote Control provided with the cable box to control my new used Pioneer SX-315 receiver. I now can control the tv volume, cable box, auxiliary stereo receiver with speaker system with one remote. Thank goodness I did not have to resort to buying a Pioneer remote control.
I was able to program another previously unused universal remote which I purchased several years ago. However, since the other remote control did not list the Vizio TV. That brand is too new for the remote.
Posted on Dec 07, 2008
SOURCE: Pioneer SX-750 Old School Need Help
Check the speaker wire. Sometimes it can just be loose in the terminals and cause distortion. I have had the problem before.
Cheers!
DellMan94
Posted on Jan 12, 2009
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
SOURCE: Pioneer Stero Receiver model SX-3700-
It sounds like your volume control pot has dust in it.You need to remove your cover from the receiver,spray pure denatured alcohol in the small openings in the back of you volume control dial and turn the knob all the way up and down several times and then blow low compressed air threw the same small openings while rotating your dial.That should fix your problem.Be sure you unplug your receiver before performing this procedure.
Posted on Feb 20, 2009
Pioneer elite sx-a6 keeps going to standby
I had a receiver that would shut off when I had the volume too loud. It was caused because the speakers were using too much juice. Does it work with less speakers or at low low volumes? Then this may be the case.
I solved it by getting a different receiver.
if it has nothing to do with volume then check your manual and settings for a auto standby feature that may be just putting the receiver to standby after a set time.
Apr 14, 2014 | Pioneer ELite SX-A9 HI-FI Audio Receiver...
I have tv hooked up to the pioneer but the TV will not play its sound through the speakers? what Am I doing wrong? I have the DVD hooked to the Pioneer and it works fine.
Is the unidentified TV a sound source from the SX-315's perspective? Is it's audio output enabled whene the TV volume is down? Would the Cable Box be a BETTER source?
Jul 26, 2011 | Pioneer SX-315
How can I control volume on my Pioneer SX-205 receiver from the couch?
There is a couple ways you can do this.
1.you can use the maufacture remote control, or if you dont have one you would need a universal.
2.If your receiver is hidden, or behind closed doors than you will need a radio frequency capable universal remote
Jan 07, 2011 | Pioneer SX-205 Receiver
I don't have sound even if I turn knob at top level. The sound coming from my speaker is not loud what button should I touch to get more volume converter sx-316
Turn it down to 1/4 while troubleshooting or you may destroy your speakers after you find that button, whatever it is.
Has it NEVER worked or did it suddenly start acting this way?
Do ALL sources act this way or only one(some)?
I'd look for a the Mute button or a Tape monitor incorrectly selected.
Mar 28, 2010 | Pioneer SX-315
Can't find part needed.(Pioneer SX 1250 volume control part # ACV-169. Is there a replacement
Your only recourse at this time is to check with local servicers that may have one around in their old stock. Or check Ebay for a parts machine that you can salvage one from. I believe that the volume control from an SX-850 will be the same, so you can search for one of those as well.
Good luck.
Dan
May 19, 2009 | Pioneer Audio Players & Recorders
Constant Buzz coming from SX-255r
Power source harmonics. Or its power supply regulation. Check also if input line is touching something.
Apr 03, 2009 | Pioneer SX-255R Receiver
Dec 06, 2008 | Pioneer SX-315
Overload
Have you checked your wiring connections? Wires could possibly be touching each other making it short out and giving you that "Overload". If not that then I would say it could possibly be a fuse that has gone bad inside. ??? Just some suggestions. The reason I say that it could be the wiring is because when I hook up a system and the wires accidently touch each other it overloads the system past a certain volume. Again I would check my wires first and move on from there.
Dan Colton, Ca
Sep 24, 2008 | Pioneer SX-205 Receiver
Pioneer stereo reciever model # sx-880 ,i can't get sound
please give more info of your problem. on what source are you not having sound? in all sources like your tuner, auxilary, tape CD etc...?
Apr 25, 2008 | Audio Players & Recorders
186 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
