Question about Jandy Laars Lt 250,000 Btu Heater
My Jandy Lars LT fires up fine for the pool or Hot tub. However, for the hot tub, it will only get to 95º even if i set it to 100. It then shuts off & won't come back on at all until cooled down completely, or if it does fire up again it is only for a minute or so. I'm not an electrician, but if it is something simple, I can probably handle it. Any advice would be greatly appreciated.
  • 19,396 Answers
Hi.
This unit uses dual thermostat and electronic temperature control.
Testing the thermostats to reveal a 5 or 10 degrees gap is quite difficult (it is easy finding out a broken thermostat), and such a small error gap lets think that the problem is not the thermostat but the electronic control.
You can take a chance replacing the thermostats and then the electronic control. I think that in this case the job should be better done by a technician. The difficulty in this case is not replacing parts, but testing them. The fault is uncommon and probably caused by an electronic control. An on-site technician may spot some clue of a different problem before replacing the electronic control.
Here a part seller: http://www.a1poolparts.com/-strse-Heaters--dsh--Parts-cln-Jandy---dsh---Laars/Categories.bok
Posted on Sep 27, 2010
Jandy Aqualinks not turning on my waterfall or fountain in the pool and 3 out of 4 of my hot tub jets. How do I re-set or repair
Turning off the power and then back on will do a simple reset. Resetting your jandy will probably not fix your issue. The issue seems more like a bad relay or bad pump or the breaker for the pump may be tripped.
Jun 18, 2017 | Jandy Pool & Spa
Jandy Lars LT fans doe not turn on and error flashes hi limit
check safety circuit and see if high limits are corroded also see if fusible links are tripped
Nov 27, 2013 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Show me the pump valve for the hot tub jandy
go to system setup then go to jva set up activate in and out then make sure JVAs are on
Jul 31, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
My hot tub doesn't heat up all the way even though it says it's ready
If a floating thermometer is more than 3-4 Degrees F off what the control panel display temperature then the temperature sensor has likely failed.
Jul 17, 2012 | Pool & Spa
Jandy lx250 won't keep water hot
what size pump motor slow the water down put a bypass in
Feb 27, 2012 | Jandy LAARS LX250 - NATURAL GAS, DIGITAL...
My hot tub won't turn off. I turn the pool on and
check the owners manual. I believe your are experiencing the auto set feature, default perhaps and see if there is a setting to change the auto switching. The older models used to do that all the time.
Feb 19, 2009 | Jandy AQUALINK RS TELELINK KIT
Jandy Laars Lt 250,000 Btu Heater Logo
105 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Pj Kiley
Pj Kiley
Level 1 Expert
Bill Jordan
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
