Question about GE JKP15 Electric Single Oven
While baking oven starts broiling with no input from controller. f2 is displayed on screen
  • GE Master
  • 3,051 Answers
Hello there:
F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Posted on Sep 27, 2010
  • tmoney_hudso Sep 27, 2010
    ok, this started happening after I used the self cleaning button? could that have something to do with this, also, I may have tried to open door right after I started the self cleaning?? But it was after that when it started to just switch to the broil mode when I would be baking something. Should I do the self cleaning mode again and see if it will correct itself?
  • Michael Thomas
    Michael Thomas Sep 27, 2010
    ok thanks for the reply
    This the bad things about these ovens once there in the self cleaning mode and you try to open the door things like this error code appear so here is what you need to do first is to unplug the oven for at least 1 hour this allows for the internal reset feature to reset the system then after one hour plug in the oven again and press the cancel button if yours has one if not wait for 5 min and it should be able to be operated normally after this you may hear a audiable click sound if so great you can open the door and continue on what you were doing but if not and you get the error code again than you do have a problem please keep me posted so i can continue to help on this oko
    Best regards MIke
I have a Whirlpool drop in stove. I had food in the oven baking and all of a sudden the timer started going off. F-1 was displayed on the front of the stove. Can you tell mean what F-1 means?
F1 - Control Board Failure - Replace control board (clock).
F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ...
F3 - Open Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
F4 - Shorted Oven Temperature Sensor (RTD) - Replace oven temperature sensor (RTD).
Whirlpool Google Search
Dec 15, 2016 | Whirlpool Ovens
On a whirlpool double oven, what does F2 error mean
F1 - Control Board Failure - Replace control board (clock). F2 - Oven Temperature Is Too High - Check for welded contacts on bake and broil relays. ... F3 - Open Oven Temperature Sensor Replace oven temperature sensor ( ). F4 - Shorted Oven Temperature Sensor ( - Replace oven temperature sensor
Nov 23, 2016 | Whirlpool Ovens
Ge profile f2 error while broiling in upper oven
F2
During
BAKE Control senses oven
temperature above 615F-630F If actual over temperature condition occurred: Look for
welded relay contacts on bake or broil relays. If this happens, replace oven
control (also called clock or ERC).
If no over temperature condition
occurred
: Look for a high resistance connection or any other cause of high
resistance in the oven temperature sensor circuit. Check sensor, sensor harness
and sensor harness connection at sensor and oven control. Replace sensor if
found defective.
Remember: Oven control (ERC) measures resistance
of sensor circuit , not actual oven temperature. F2
During
CLEAN Control senses oven temperature above
915F-930F If actual over temperature condition
occurred
: Look for welded relay contacts. If this happens, replace oven
occurred
found defective. Check door lock switches.
(ERC) measures resistance of sensor circuit , not actual oven
temperature.
Jan 24, 2011 | GE Profile JTP56 Electric Double Oven
Broiler element not working at all. checked element--it's OK. Called a serviceman-- he thought it was an oven sensor--replaced sensor ---no change Electronic clock some times shows a code "F2 ...
you do not say it is electric oven. if so broil element requires 240 vac. may be controlled by relay. Is bake element working? also controls for broil may be different setting if digital panel is in this design. I think same sensor may be used for bake or broil.
you do not say if gas oven, electric oven, single or double oven or if digital panel control, a little more information would help.
if you have digial voltmeter, FULLY disconnect electric power and measure element on terminals. probably less than 15-20 ohms for a good element.
Dec 28, 2010 | Ovens
The ovens were just installed. We can't make them work. We are getting a F2 on the screen.
The F2 means Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit, not actual oven temperature.
Nov 25, 2010 | Whirlpool GBD307PD Electric Double Oven
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Will only broil, then gives an F2 error
F2 Oven temperature is too high 1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
Mar 27, 2009 | Whirlpool RBS305PDS Electric Single Oven
I need to disable my ovens auto shut off
The control is automatically set to turn off the oven after 12 hours baking or 3 hours broiling should you forget and leave the oven on. If you want to remvoe this feature do the following steps: 1. Press and hold, at the same time, the BAKE and BROIL buttons for 3 seconds, until the display shows "SF". 2. Press the DELAY START TIME button. The display shows "12Shdn" for 12 hour shut off. Press the DELAY START TIME button again. The display will show "no Shdn" for no shut off. 3. Press the START button.
May 21, 2007 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE JKP15 Electric Single Oven Logo
151 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
