Question about Royal Sovereign ARP9011TL Air Conditioner
Compressor is running but ac not cooling - Royal Sovereign ARP9011TL Air Conditioner
  • Royal Sovereign Master
  • 43,501 Answers
The unit leaked the refrigerant and so it does not cool even though it is running... Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Posted on Sep 28, 2010
2 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
Picanti ac sistem flush and new compressor expression valve fixing after ac cooling running vehicle after compressor jam damage not cooling
no year
no car
no country stated.
wow.
IS this car a KIA
and you spelled,
Picanto
wrong,
this is USA forum and in USA we dont have Picanto
here.
so, be hard to answer.
and you never asked a real question.
just facts on AC.
AC is dead,?
is clutch engaging on compressor, that is first
then fuses.
Jun 16, 2016 | AC Cars & Trucks
Dometic rm7732 not cooling
If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
First, answer these questions:
  • Is the refrigerator completely dead? If so, see “It's stopped completely.”
  • Is the thermostat knob turned to the proper setting? If not, reset it.
Next, see if the compressor motor is running
The compressor is a football-sized case with no apparent moving parts. It's on the outside of the refrigerator at the back near the bottom. If it is humming or making a continuous noise and your refrigerator is still not cooling, there may be a more serious problem with one or more of several different components, we recommend contacting a qualified appliance repair technician for further help.
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor
Jun 17, 2008 | Dometic RM2652 Refrigerator
AC compressor clicks on and off while running?
the compressor will cycle on/off when the cabin temperature is reached
the larger pipe will be cold to touch as it is the suction line for the compressor
if you have a problem with the ac ,it will not work the compressor at all and the lines will not get cold
When in doubt take it to an accredited ac specialist shop and have the system check out.
Aug 11, 2015 | 2000 Cadillac Escalade
My Dometic roof top ac doesn't cool. Fan runs fine, no COOL air. With thermostat in off position. Checking the voltages I found 118v at the breaker. At the run relay, 118v going in and a coupl
Please reply with Model number of bottom of AC unit ( upper) . Can be seen from inside usually. Thermostat model, plus if controls are at the ceiling assy or at thermostat on wall.
Jan 17, 2013 | Dometic Rooftop RV Air Conditioner
Hyundai accent 2002 car high temparature during start ac
check see if cooling fan running could have faulty cooling fan relay or fuse.if cooling fan dont run when ac on car will overheat.AC COMPRESSOR PUT LOAD ON ENGINE.
Sep 06, 2012 | 2001 Hyundai Accent
A/c compreesr cluth stays on but no cool air
You replaced the ac compressor, and the clutch stays on, but the compressor does not run ???
Not sure I am following your info here.
If the ac clutch stays engaged the compressor should be running. You should have one hot and one cold ac line and the radiator fan should be running.
Aug 04, 2012 | 1999 Cadillac Seville
Location of ac high pressure cutout switch on a 97 Plymouth voyager. Could it be a different problem? Had to replaced the PCM and a couple sensors because of a short in the wiring cluster. Now the ac...
HIGH PRESSURE CUTOFF SWITCH LOCATED ON AC COMPRESSOR DISCHARGE LINE LEADING TO THE CONDENSOR.THE HIGH PRESSURE CUTOFF SWITCH WILL CUT OFF THE AC COMPRESSOR IF SYSTEM PRESSURE RISES TO HIGH CAUSED BY RESTRICTION IN THE REFRIGERANT CIRCUIT OR OVERHEATED CONDENSOR.MAKE SURE COOLING FAN IS RUNNING WHEN THE AC SWITCH IS ON.THE COOLING FAN KEEP CONDENSOR COOL, IF COOLING FAN DONT RUN.YOUR AC WILL STOP BLOWING COLD AIR.HAVE THE REFRIGERANT SYSTEM CHECK OUT.MAKE SURE YOUR LOW SIDE PRESSURE IS 10 - 37 PSI. THE HIGH SIDE PRESSURE SHOULD BE 112 - 210 PSI. CHECK THE AC COMPRESSOR CLUTCH FUSE AND RELAY.
Jul 29, 2011 | Plymouth Voyager Cars & Trucks
My window ac is not providing cooling. The compressors runs but it doesnt colles the cooling coil. The regerent is also charged
the start capacitor is either defective or if the compressor has a ptc overload relay,this could be the problem then
May 20, 2010 | Kitchen Ranges
Ac compressor not coming on 2001 cadillac deville
hi there,
there are several test to be done and analysis on trouble shooting ac performance.if the ac run smoothly but insufficient cooling effect was taken after recharching factors can be obtain in poor performance of compressor,clogging of tubes mostly on capillary tube and expantion valve.this main factor
contribute on ac in sufficient cooling.compressor performance can check the on the discharge valve by mounting a hi side pressure gauge and check the lost compression effeciency.while the compressor is running if it can discharge a pressure higher than the operating pressure w/o losses on psg. you have good
compressor performance.but if can not maintain a operating pressure you replace compressor.if the compressor is good check the capillary tubing by purging and cleaning the system,obstruction can't expand the freon inside your evaporator,have a nice day don't forget to fix my rate.also recharge exact amount freon on the system don't exceed.poor refrigeration was the result,no cycle will occured.
May 04, 2010 | Air Tools & Compressors
Royal Sovereign ARP9011TL Air Conditioner Logo
238 people viewed this question
Top Royal Sovereign Heating & Cooling Experts
jdthefixer
Bill Long
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Royal Sovereign Heating and Cooling Expert? Answer questions, earn points and help others
