Question about Freestyle Mongoose Bmx & Owners Manual - Bike / Bicycle
The handle bars will not keep straight? - Freestyle Mongoose Bmx & Owners Manual - Bike / Bicycle
    Genius:
  • 1,788 Answers
You may have a stripped stem bolt, and need to replace it. Also, I hope that you use metric allen wrench because all bikes are metric. Take it to a bike shop and they should be able to set you up for a very nominal fee.
Posted on Sep 27, 2010
I got a 1989 big bear it pulls to the right i put new tie rid ends and upper and lower balk joints in pulled cv axel it seems to be ok steering bearings seem fine also anyine have any ideas
Try aiming the handle bar straight and pull some kite string across the rear wheel , lightly touching the sidewalls of the tire. With the length of the string pulled across the front tire, adjust the outer tie rod so as to make front tire lightly touch the string. That should square the front tire to the back tire. Once the front and rear are squared, adjust tie rod in 1 turn for a slight negative toe. Do both sides while making sure to keep the handle bar straight during string and adjustment. That should help.
May 25, 2017 | Cars & Trucks
How to raise handle bars
handle bar post is held in the head unit by a taper block and a split in the bar post
undo the central bolt about a /14 inch and tap the bolt down . this releases the clamp action and you will be able to lift the bar section up .
centre the bars to straight ahead and re-tension the centre bolt
May 19, 2015 | Cycling
My 1998 Schwinn Moab steering head is loose and clunky. When I ride it the steering head clunks and very hard to keep straight. This happened after swapping out the handle bars and I had to put a 2"...
Without seeing this I can't say for sure but it sounds like a bearing is shot or a washer is missing from the neck. What is confusing me is you said you just replace the handle bars and the would not require removing the neck. If you have more information I will keep an eye out for your response.
Aug 09, 2012 | Cycling
The steering bar is not even with handle bar. The child's handle bar is straight, but the push bar will then be crooked to the right.
I put some packing tape around the bar to where the handle bar fits. It is holding for now, i don't know how long it would stay :)
Jul 11, 2011 | Radio Flyer Steer and Stroll Deluxe Trike
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
I have a 2007 Yamaha TT-R50 and when I turn the handle bars to the left it revs up really high. Then when I turn it to the right it shuts off. If I keep the handle bars straight, it idles just fine. Any...
sounds like a throttle cable issue. follow the cable from the throttle, back to the carb. making sure there are no tight spots, also make sure its the correct cably and long enough
Mar 11, 2011 | 2005 Yamaha TT-R 125 E
How do you remove the tri handle?
You just pull the handles straight off the faucet. There are no screws or bolts holding the handles. Only a friction guide attached to the faucet stem. You can see this guide in the Grohe Classic Kitchen/Bar Faucet 31.057.000 installation instructions.
Dec 12, 2010 | Grohe Classic Kitchen/Bar Faucet ...
How do i tighten the steering tube? the front wheel can turn left/right while the handle bars are straight ahead.
mcdevito75 here, There may be a bolt on top of the handle bars you can tighten, or a clamp just under the handle bars you can tighten, this clamp may also be on the shaft just above the wheel.
Jun 26, 2010 | Razor E300 Scooter
1992 Honda 250 Nighthawk Handle bar diammeter
Take an ajustable wrench and place it around the handlebar where their is a straight section, snugly. Slide the wrench off without ajusting it. Measure with a ruler or tape measure the distance between the wrench jaws. That measurement is the diamater of your handle bars.
Dec 22, 2008 | 2005 Honda CB 250 Nighthawk
Freestyle Mongoose Bmx &  Owners Manual - Bike / Bicycle Logo
Top Freestyle Cycling Experts
Christian Samuelsen
Christian Samuelsen
Level 1 Expert
Ed Hauk
Ed Hauk
Level 1 Expert
Are you a Freestyle Cycling Expert? Answer questions, earn points and help others
