Wiper blades are stuck in the up position and all attempts to remedy have failed. They eventualy end in the upright position whether car is on or off?
  • 17,130 Answers
There is apostion setting inside the wiper motor assembly that allows it to park in auto mode at the designated lower part of the windscreen.
This is a semi contact which activated when the motor moves from start and the power transfers to the contact .As the motor moves down to park and if the switch is off the connection cuts off for the blades to park.
You can remove and check this contact plate mounted on the nylon circular wheel which is driven by the motor spiral gear. adjust and set, it can be a contact problem.
Posted on Sep 27, 2010
    Brigadier General:
  • 7,191 Answers
You have posted the question under MP3 Players category
Kindly submit the question under cars section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, enter the question in the "Ask an Expert" box.
Thanks for using FixYa.
How do you troubleshoot 2000 Jeep Grand Cherokee Laredo front wiper blade
Check your manual for wiper fuse & relays location.You can inspect fuses visually...hope this helps
Dec 29, 2012 | 2000 Jeep Grand Cherokee
Tip
Replacing Wiper Blades or Not
Do not replace your wiper blades until you have tried this, get some warm soapy water, soft all purpose cloth. Hose down your front and rear windscreen (if fitted with wiper blades) with normal water, clean the windscreen as you would when washing the vehicle. Get your cloth and dip it into warm soapy water, if your wiper arm stays upright put it in that position other wise lift it up and put a piece of towel or similar under it. Now with the soapy cloth give the wiper blade edge a good scrub, up and down, hold the blade itself with one hand on one end, it may slide out, you will notice the cloth getting black, you are cleaning off all the dirt that is stuck on the wiper blade, simple as that. It is usually that dirt which causes your wiper blades not to clean properly, you will eventually need to replace it but give it a go, you will be surprised.
on Feb 20, 2011 | Chevrolet Chevy Cars & Trucks
Wiper blades stuck in upright position
there is 2 switches in the wiper motor a run and a park sounds like one of them has failed or the wiring to them but check the switch first may have broken wires
Sep 06, 2017 | 2000 Buick Century
Wiper blades stuck in up position on my 2005 Hyandai Tucson
Disconnect the wiring harness to the motor and check for power and ground with a 12 volt test light. If they both are good, the wiper motor has most likely failed.
Apr 21, 2010 | 2006 Hyundai Tucson
2003 Chevrolet Venture rear wiper blade does not work and is stuck in an upright position. Turn it on - nothing. Push the blade down to correct position it eventually ends up back in upright position. Is...
I went to Jiffy Lube, and they did something free that made mine work again. Granted I rarely use it anyway(I'm in the desert), but so far, so good. No idea what they did, but it can't have been very difficult.
Apr 06, 2010 | 2002 Chevrolet Venture Passanger
My windshield wipers are stuck in an upright position when they are turned off. they run fine when they are on. what is the problem and is it an easy fix
The wiper blade arm may have stripped the splines that keep it in position on the wiper motor shaft.Sometimes you need a special
arm puller to remove the blade arm, but if it's stripped,it will pull off pretty easy. If yopu take it off,look inside to see if the splines are stripped inside, where the motor shaft holds the arm.It will look all
rounded off, and not sharp ridges.Make sure you start taking it off,
with the arms in their normal down position,and the car off.
Good luck.
Mar 30, 2010 | 1990 Ford Taurus
How to replace the wiper insert at the back of
  1. REMOVE RR WIPER BLADE
    1. Raise the rear wiper blade to the position as shown in the illustration where the meshing of the claw disengages with a clicking sound. NOTE: Be careful not to break the claw.
    2. Pull straight the rear wiper blade to vehicle's left from the wiper arm. NOTE: Do not fold the rear wiper arm with the rear wiper blade removed from it.1722d05.gif
  1. REMOVE REAR WIPER RUBBER
    1. Place the rear wiper with the rear end of the rubber protruded from the blade stopper as shown in the illustration. NOTE: Do not pull out the wiper rubber forcibly, as the backing plates will become deformed or the blade claws will become damaged. HINT: The rubber can be easily pulled out by pushing the middle area of the blade.
  1. INSTALL REAR WIPER RUBBER
    1. Install the 2 wiper rubber backing plates to the rear wiper rubber. NOTE: Be careful to observe and keep direction of curvature for correct replacement.
b. Insert the rear wiper rubber from the claw of the middle of the rear wiper blade into the rear end position.
c. After passing the rear wiper rubber through the rear end side claw, protrude it from the rear end stopper and pass it through the front tip side claw.
Sep 12, 2009 | 2005 Toyota Matrix
2005 impala windshield wiper
the wirpers are connected to a shaft. the shaft is connected to a motor. The shaft must have turned and wipers were stuck and didn't move. So you will need to pull of each wiper arm and reposition with wipers turned off.
Apr 03, 2009 | 2005 Chevrolet Impala
52 people viewed this question
 Grubhead
Grubhead
