Question about DeLonghi Microwave Ovens
Hello. I have a Delonghi microwave (model no: AG925EFY) which is not heating food, but otherwise seems to be operating fine (i.e. lights come on, etc). I think I may have pressed something by accident and now when the microwave is on, the top left hand icon flashes (I think it indicates auto reheat) along with the normal heating icon. I don't know how to get rid of it or how to reset the microwave to factory settings. PLEASE CAN SOMEONE HELP!!!
Junoon007
  • 1011 Answers
SOURCE: Blows fuses!
sir,
Try this link for the manual to repair it.
http://www.eserviceinfo.com/browse.php?id=36
www.yinyanghome.com/Products/Icebox/Microwave.pdf
Posted on Mar 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Amana microwave comes up with an F 4
Your temperature sensor is defective.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
You can download Amana owner's manuals and installation instructions here.
Posted on Dec 07, 2008
bestdarngood
  • 3037 Answers
SOURCE: it turns on ...lights up but doesnot heat or warm the food
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Posted on Apr 26, 2009
  • 234 Answers
SOURCE: GE spacemaker microwave does not heat food; fine otherwise.
Most likely the hi volt energy components. Usually the hi volt diode or hi volt capacitor. There is hi energy stores here so be careful or do not attempt it. A person skilled in electronics, tv repair, or microwaves can handle it . It is usually worth repairing. The other parts that could be the problem are the magnatron or the hi volt transformer; if so, you might think twice before repair (the price will be higher).Goodluck, Macgivor
Posted on Jan 16, 2010
Testimonial: "Thanks for the quick response ... I don't want to mess around with something only a professional should be touching. Thanks for the advice ..."
  • 119 Answers
SOURCE: Does not heat up food.
90% of the time it is a magnetron fault
Posted on Feb 17, 2010
Hi, i have an ac925efy delonghi microwave oven, i bought it manufacturer refurbished and when i switched it on there was a big bang and a flash. it came from what looked to be the back top right hand...
From your description it is the magnetron that heats the food that has gone, I suggest that you take it back for a refund, because if you decide to fix it the repairs will run you more than what the microwave oven is worth.
Jan 16, 2011 | DeLonghi MW 535 Microwave Oven
My delonghi 800w microwave oven works but does not heat up food
If your handy with getting the cover off and looking inside... check the obvious.
I suspect :
fuse
thermister
relay
If both microwave and Heating elements dont work, then I will assume the magnetron is ok, ans we are dealing with a high voltage issue... and you will need at best... a volt meter and or neon troublelight...
moust appliances have a simple schematic inside... I would start with the heating element first... trace wiring back to circuit board... usually one side of the heating element is connected to the white wire (neutral) and live (Hot) side is controlled thru the circuit board... so finding the neutral should be easy... then trace with neon light or voltmeter...
I know easy for me to say... but with everything else working... it doesnt seem to be the microprocessor that controlls the unit...
May 06, 2010 | DeLonghi MW 605 Convection/Microwave Oven
Mw8992rd seems to be working fine except won't heat food. timer, touch pad, inside light, carousel all work fine. tried different times and power levels but still no heat.
This sounds like a bad magnetron that would have to be replaced. There is up to 2000 volts stored in a microwave, even when unplugged. For saftey reasons I would strongly suggest you have a qualified technician check it out.
Hope this helps.
Aug 24, 2009 | Emerson Microwave Ovens
It turns on ...lights up but doesnot heat or warm the food
Benjamin
Apr 17, 2009 | DeLonghi MW 605 Convection/Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
fggfd
Sep 22, 2008 | Sharp R-1610 Microwave Oven
MICROWAVE NOT HEATING
I have the same problem. Everything seems to work except it doesn't heat up food.
I remember last time when it was working. I pressed the start botton before I closed the door. So it didn't start automatically, and I pushed start and it worked(it still heat up the food), but it doesn't work now. Help Please!!!
I have a Whirlpool Gold GH5184XPQ.
Thanks in advance
Aug 27, 2008 | Microwave Ovens
Microwave Ovens Logo
82 people viewed this question
Top DeLonghi Microwave Ovens Experts
William Miller
William Miller
Lisa
Lisa
tfelton3
Are you a DeLonghi Microwave Oven Expert? Answer questions, earn points and help others
