Question about Summagraphics Office Equipment & Supplies
After lowering the cam rollers, my summa d610 keep on giving the message to lower cam rollers
3 Suggested Answers
copiersplusw
  • 136 Answers
SOURCE: Paper want go in to print
The reason why it keeps saying this is cuz you paper feed tire needs replacing. Now i am not sure based on the cost of this unit if it would be worth to have this repaired but, this is what is causing this error.
Posted on Jul 24, 2009
  • 8 Answers
SOURCE: HP Officejet Pro L7580 ADF will not pick up paper
You can lift the top of the unit to inspect the rollers. Be careful because the L series the roller can pop off easily and if you're not paying attention to original orientation, can be a pain to put back in.. you press the blueish button to release the pick up assembly. See if any rollers are dusty. If they are, use Isopropyl alcohol (highest % you can find) and a LINT FREE cloth (dryer sheets/coffee filters or something of that nature..) and wipe clean
Hope this helps, I'm honestly doing all this from memory, I used to work for that dept here in Oregon ..
Posted on Sep 08, 2009
C3202 error
C 3201;C 3202 Fusing motor malfunction.Remove the fusing unit and inspect the upper and lower fuser roller and the drive mechanism gears.If is OK reset the error.To reset turn OFF the copier.Press and keep pressed the Uility key and turn ON the copier.Keep pressed the Utility key and wait to displayed Trouble Reset message.Release the key and touch the message then turn OFF the copier.Wait 1 minutes and turn ON.
Apr 03, 2013 | Konica Minolta Office Equipment & Supplies
I have a apple imac Mac OS X Version 10.5.8. I have a Summa Sign D610 cutter. I am looking for software to make it work.
  • Make sure all words are spelled correctly.
  • Try different keywords.
  • Try more general keywords.
  • Try fewer keywords
Sep 17, 2011 | Computers & Internet
Can I use Illustrator to cut direct from my Sumagraphics d610?
Yes, download this file: http://www.summa.be/download/setupSCT.exe which contains plugins for Illustrator CS, CS2, CS3, CS4, and CS5.
Nov 30, 2010 | Summagraphics SummaSign Pro T610 Printer
Display shows a blank area in the right lower corner, of around 2 to 3 inches
You have dead pixels on your screen. You will have to replace it. I suggest you give it to Dell Service Centre.
Nov 18, 2010 | Dell Latitude D610 Notebook
Document roller up & down
On the Canon copy machines when this happens, normally it is a bad wiring harness....sounds like your switch is good, but the signal for 'roller down' is not reaching the main board, thus it repeatedly cycles up and down. Try continuity test on the wiring harness from switch connector end to main board connector end...it's a pain to do this, however, when you find the open wire connection, it's worth it.
Oct 28, 2009 | Canon Office Equipment & Supplies
Jul 24, 2009 | Lexmark X7170 All-In-One InkJet Printer
Cam belt loose is there an adjuster
Yes there is. You don't have to, but it's a good idea to remove the lower timing cover to adjust it. There is a bolt that goes through the middle of the lower cover, it has a 12mm hex head. If you loosen this off a couple of turns while turning the crankshaft just a bit (NOT the cam!) counter clockwise, the roller should slide in its slot to take up the slack. There is supposed to be a spring acting on the roller when you loosen the bolt but sometimes the last guy that did the timing belt, doesn't put it back on. That's why you may have to remove the lower cover. This engine will damage itself if the belt breaks so make sure it is replaced or tensioned accordingly.5cbfd02.jpg
Apr 25, 2009 | Honda CRX Cars & Trucks
TRACTION PROBLEM
The cam that keep the pressure between the roller pick up and the lower feed is the solution
Oct 22, 2007 | HP Photosmart C3180 All-In-One InkJet...
50 people viewed this question
Top Summagraphics Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Summagraphics Office Equipment and Supply Expert? Answer questions, earn points and help others
