Question about LG DLG5988 Stainless Steel Gas Dryer
Dlg 3788w-7.3 cu ft gas dryer
Drum will not rotate or heat the dryer buzzes then shuts down i was told this is because the drum is jammed how to i get the front panel off so i can repair it?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
You don't, it is gas dryer, so I advise you to get a authorized gas technician to look at your unit.
Chances are the blower assembly is out of whack, maybe the motor is off its brackets.
Sgt 48
Posted on May 31, 2008
Inglis Gas Dryer... mercy me?
Sounds like what you said. Time for a motor. The motor has an internal overload and will shut the machine off if the motor runs hot.
Good Luck
Feb 26, 2014 | Inglis 6.5 Cu Ft Super Capacity Gas Dryer
I was drying rugs and one of the rugs got caught and the drum stopped turning. The power comes on but the dryer drum will not turn.
Hello, one possible cause of dryer drum not rotating is the rugs stuck between the drum and front panel.Secondly, maybe the dryer belt dispart.
Jul 31, 2013 | Sears Kenmore Elite Gas Dryer Front Load...
DLG 3788W Dryer
could be the drum wheels
May 04, 2013 | LG Dryers
Ge dryer - buzzes when the start button is pushed but the dryer motor doesn't start or the dryer drum moves. could be a jam or the motor? Motor didn't seem to be a problem before today.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2011 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
When I went to turn on my dryer, I rotated the switch to turn it on. However, it makes the normal sound but the drum is not spinning and the dryer will not stay on. When I rotate the on switch and I let...
It sounds like the drum bearing is bad. It can prevent the drum from turning and overheat the motor and cause it to shut off.
Another possibility is that the belt has broken and the motor is just spininig. Some dryers have a safety that prevents the dryer from staying on it the drum is not turning.
Apr 08, 2011 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
My dryer doesn't seem to function properly, it's just blowing cold air. I had it on for over one hour, my clothes are still wet and the air is still cold. The dryer model is LG Tromm DLG 3788W. The...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 24, 2010 | LG Dryers
Makes a humming nose when you press start
Gas Dryers may produce buzz when the solenoid opens. The valve clicks at the start of the heat cycle, start of ignition and when the burner turns off. The flame makes a low roaring sound.
Make sure nothing is loose inside the drum. Check all exposed screws, and make sure they are tight.
Make sure dryer is level on the floor, and that nothing is leaning against the dryer.
Check for foreign objects in the drum. (Coins, buttons and zippers will make a rattling sound as they roll around in the drum)
Good Luck and have a nice day
Rating the solution is highly appreciated
Jun 18, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Duet Sport Dryer drum will not turn
Most likely thermal fuse is bad, but also could be door switch or a control problem.
Oct 12, 2017 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Jan 30, 2009 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
LG DLG 3788W not heating
can you look in one of the holes in the back and see if the inside glows orange after you turn it on? If it doesn't could be the igniter, if it does glow orange, clicks or clacks, and glows again 20-30 seconds later, click/clack and nothing, it's probably the gas valve. I'm going through the same thing with a new one and they had to order the valve and a new controller board in case it is bad too. If you are handy, have an electronic tester, and have the patience, go to http://136.166.4.200/contents/Laundry/DLG3788.htm for the service manual and disassembly instructions and see if you want to tackle the test flow for no heat. I just stumbled on the site.
Dec 03, 2007 | LG DLG5932W Gas Dryer
LG DLG5988 Stainless Steel Gas Dryer Logo
109 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
