Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
OK ,maybe I have a better explianation to my problem. The clear view window is rubbing against the carpet. Yes I understand that the machine has to be used in a foward and back motion. How can I prevent the window from cracking or breaking? Thank you
  • 276 Answers
From what you are describing the half moon shaped window behind the main floor nozzle is dragging on the carpet. There are two screws that hold the half moon window in place. Make sure those screws are tight then take off the front floor nozzle and re-install it, making sure the front nozzle is hooked to the half moon window in the center. If you need further assistance call BISSELL Consumer Services.
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Posted on Sep 27, 2010
Bissell proheat snags on carpet
Hi Richardad229. The front clear window nozzle(s) may be off alignment and can be re-aligned quite easily.
Here's a link to the instructions: http://www.bissell.com/FAQDetail.aspx?id=1212&cid=ccsocial
Apr 20, 2013 | Bissell 1699 ProHeat Clear View Upright...
Who makes the carpet magic steam machine
Originally, they were made by the "Carpet Magic Company" which was acquired during the 1970's by "Hartz Mountain Corporation". Hartz Mountain Corporation (HMC) was ultimately sold to "Sumitomo Corporation" of Japan, in 2004.
The Carpet Magic trademark has lapsed, meaning that these machines are no longer manufactured by anyone.
Parts for these machines are still available in places, however there is no longer any manufacturer support available for these machines.
Please rate this solution if you find it helpful. Thanks.
Oct 26, 2010 | Bissell 8910 ProHeat Clear View Upright...
It won't move forward. it turns on but drags when going forward will go backward smoothly.
On the front of Carpet claner is the clear part that pulls the water back up. It may have come apart. this will cause it to catch, unplug the cleaner, remove all the cleaners and water container, then , lift up and look at this part, If it has a large gap it has come apart.
Mar 24, 2010 | Bissell 1699 ProHeat Clear View Upright...
Brushes stop rolling when against carpet, yes it is out of the upright position and when I left the base off the carpet the brushes start to roll again. What is wrong?
Your belt is stretched out so it just stops when the carpet resists it. Get a new belt made for your particular machine and you should be back up and running
Aug 02, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does not allow you to push forward
check to make sure that both clear window screws are tight. these will be the 2 screws on the very front and the 2 screws above the brushroll in the bottom of your steamer. if they come loose it will drag on your carpet and not want to push.
Sep 26, 2008 | Bissell 1699 ProHeat Clear View Upright...
Ckeaner drags on carpet
This unit has the outer window, and a half moon window behind it. Check to make sure the 2 screws holding the half moon window are tight and that the plastic hasn't broken. The 2 windows at the bottom cener merge together, they may have come apart. Usually when one or the other window is out of place, it will cause a drag. You may have to replace the half moon window.
May 17, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissle will not let water out if Bladder
Check the vale at the bottom of the tank. Push it in and see if water comes out ok, also check to make sure the seal is on the valve asm. Check the pump belt to see if it broke. Could have a bad pump. Is the top cover seated against the base in the back, if it is raised up, then it also raises the tank so it can't work.
Apr 12, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell proheat
Where the lip of the tank sits on the clear window, is the gasket there? If it is missing, it won't suck up the water. It is black, oblong (#24)and sits in a slot on the clear window providing a seal for the tank. Is the filter clean(#62), should be sitting in the square opening on the bottom of the lid, it sits right over the sucking opening.
Feb 25, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
54 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
