Question about Jenn-Air JSD2789GES Side by Side Refrigerator
My Jenn-Air 2789 fridge leaks at the bottom of the freezer door (same door water/ice) There is also water that freezes inside the compartment at the bottom. I've turned the water line off, but I still get some leaking and frozen water inside.
HVACRH20
  • 237 Answers
SOURCE: icemaker is not freezing ice, freezer not freezing food,
The ice maker won't work if the freezer is warmer than 17 degrees so that's not an issue till you get the freezer cold again. I would guess that your unit is stuck in the defrost cycle. This could be the defrost timer failing. See if you can find the defrost timer in your unit and advance it by hand if possible. http://www.partselect.com/PartSearchResults.aspx?modelnum=jcd2295hes&mfgmodelnum=&fkmfgid=1&hint=defrost
Posted on Dec 04, 2006
mikedurland
  • 481 Answers
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer/board
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items. If it still has a problem then it might be the compressor and you should probably replace the machine.
Posted on Jun 28, 2008
docjohn174
  • 943 Answers
SOURCE: JENN-AIR BLOWS WARM AIR
hi thanks for the question the freezer is more than likely frosted up now with the door left open the drain hose from freezer is clogged shut down let thaw remove panel at the back of fridge allow 24 hrs to thaw clean out the drain tube re level the fridge so that if the door is left open the door will close by its self raise the front legs to achieve this thanks the appliance doc
Posted on Sep 17, 2008
SOURCE: Jenn-Air freezer leak
Apparently it is the drain behind the freezer panel on the inside and it is blocked. It needs to be unblocked and cleaned. You remove the food and the rear panel on the inside of the freezer. With a hair dryer (carefully) remove all ice build up and then unblock the drain line going to the pan under the refrigerator. The drain line can be cleaned with bi-carb and hot water (not boiling).
Posted on Dec 31, 2008
deby69
  • 16 Answers
SOURCE: water leaking from bottom of freezer compartment
the condensation drain line might be clogged.
Posted on Jan 02, 2009
I have a Jenn-Air side by side refrigerator. It has built up ice in the very bottom about three inches thick. What could be the problem?
ice is water freezing so check where the water is getting in ( leaking water bottles being frozen, bad door seals, too frequent door opening etc
Jul 10, 2016 | Jenn-Air Refrigerators
Water is leaking out the bottom of my brand new Jenn Air French door model JFC 2089 HE. Why?
likely a lot of condensate has been collecting in the catch tray, and it hasn't been able to evaporate off. You may have to slide the fridge out, and empty the tray by hand.
Nov 02, 2009 | Jenn-Air JFC2089HE French Door...
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
We have a bosch air flow fridge freezer
It's stopped completely
It's not cool
Cooling is poor
It's noisy
It leaks
The freezer compartment is icing up
The food in the refrigerator freezes
There's water dripping inside the refrigerator
The refrigerator never cycles off
The ice maker has a problem
There's an ice- or water-dispensing problem
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
Mar 14, 2009 | Bosch Refrigerators
Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Nov 24, 2008 | Jenn-Air JCD2389G Side by Side...
Jenn air side by side leaking water
to allow your fridge/freezer to be ice free a timed defrost phase apxx every 7 to 10 hrs occurres whe the ice is drefrosted the water shoud go via a collection tray to the top af the compressor to keep it cool the tray is situated at the bottom of the freezer side behind the panel youll find is probally blocked and the water is overflowing to the front instead of going the correct way if you tecn minded unplugh the appliance remuve the pabel and unblock the drain tray the panel is inside the freezer torward the bottom
Nov 13, 2008 | Jenn-Air JCD2389G Side by Side...
Aug 12, 2008 | Jenn-Air JCD2389G Side by Side...
Water leaking out from the inside bottom Jenn Air JRSD245L
It sounds from what you described is a clogged drain line pull the bottom drawer out and look at the bottom of the back wall. see if the drain is backed up with ice if so use the back end of a rubber handle screwdriver and lightly tap the ice until it breaks up clean up the best you can around the drain and pour some hot soapy water down until to you hear it going into the drain pan.. a cup will do....>>the water comes each time the unit goes into defrost as the heaters melt the frost build up on the evaprator it melts and is suppose to go down the drain but if it is blocked then it forms at the bottom of the freezer floor..let me know if you still need the wiring diagram I can email it to you. Hope this fixes YA !
Feb 22, 2008 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Jenn-Air JSD2789GES Side by Side Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
jasbo
jasbo
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
