Question about Orion VR213 VHS VCR
I have bought a second hand orion vcr d1097 with no manual.I have no idea how to tune in 32" tv flat screen and hd box (with hdi cable) to the vcr. So I can record and watch back my recordings . Any help will be recieved with great gratatude. As I am house bound And my t.v. and vcr are my only pleasure. With regards Bill.
  • Orion Master
  • 5,056 Answers
Visit the Orion website they might have the manual for free! Or they might be able to help!!
Posted on Sep 28, 2010
How to hook up vcr when using a cable box
That will depend upon what you want to do. If you plan to record to the VCR from the cable box, then the cable box will need to directly connect to the VCR, then the output of the VCR is connected to the TV. Unfortunately, most VCRs are analog, not digital, so you will lose HD capability (if you have it) trying to connect this way. You also cannot record one show while watching something else (you will need to be tuned to the channel you are recording). If you want to simply use the VCR to view recorded tapes, then connect the cable box to the TV as per the cable company recommendations, and then make a second connection for the VCR. Of course, your TV will need appropriate and available jacks on the rear to do this. It is difficult to give specifics without knowing the models of the cable box, VCR, and TV.
Sep 15, 2015 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
Can't find where to hook up tv coax.
As far as I can tell your TV is just a monitor. You would have to buy a separate tuner. I had the same problem with mine and found it was cheaper just to use an old VCR. I hooked up the coax wire up to the VCR and hooked the VCR to my TV with composite cables and changed my channel through the VCR. That will only work now if you're using cable because of the switch to digital. If you're using an antenna you will need a digital tuner.
Aug 08, 2010 | Philips 32FD9954 32 in. HD-Ready Plasma...
My philips hd tv does not have a picture . only
Do the channel controls work? If not, then try going into the TV's menu and find the factory default reset function. If that solves the issue, you may have to do that every time you turn your TV on.
Just as with almost every other issue, I suggest you get in touch with the manufacturer for proper assistance.
Jun 03, 2010 | Philips 32PFL7332D 32 in. LCD HDTV
Problem recording of hd tv with cable box from
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
Jan 07, 2010 | Toshiba W522 VHS VCR
My 32'' sanyo flat screen tv every channel ''flickers''..only on cable channels not when using the vcr..anyone else having these problems?
you have a bad tuner, you can replace the tuner, it requires soldering it in, or use an external tuning source, like a vcr or cable box, hook the cable to the external source, and into one of the tv's audio'video inputs, this will bypass the tuner.
Sep 15, 2009 | Televison & Video
Dont know how to tune in stations
did you try websiye for philip
Jan 31, 2009 | Televison & Video
Orion VCR 213 will not record with converter box
The chain of cabling that you have should go like this; First in line should be the wall supplying the cable box. Then, the cable box connects to the VCR, then the out of the VCR should go to the TV. Select whatever channel you desire, make sure that the VCR is on Channel 3 or 4, (Whichever the back of the cable box is set) then select 3,4 or line/AUX to see the results....accordianman
Dec 12, 2008 | Orion VR213 VHS VCR
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Orion VR213 VHS VCR Logo
321 people viewed this question
Top Orion Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you an Orion Televison and Video Expert? Answer questions, earn points and help others
