Question about Bryant Heating & Cooling
My Bryant AC isn't blowing cold air. I have had it for a little over 2 years, but have rarely used it. Maybe a fuse? Any advice would help. I live in Southern California so no ice on it. Thanks.
    Master:
  • 571 Answers
Have someone check the pressures & temperatures in the refrigeration system.
Posted on Dec 06, 2013
22yooper
  • 828 Answers
SOURCE: Refrigeration AC not blowing cold air
If you can hear the A/C compressor start and run then your system has lost it's charge of refrigerant. If the compressor does not start and run it could be a control problem.
Posted on May 17, 2008
22yooper
  • 828 Answers
SOURCE: air not getting cold
You should have the unit serviced. If the compressor runs and does not cool it may have lost its refrigerant charge.
Posted on May 21, 2008
  • 16 Answers
SOURCE: window ac unit is not blowing cold air
When the unit is running, go outside and put your hand near the condenser fins, this air that comes out should be slightly warmer than the ambient temp. If it is not you will need to take the unit out of the window and out of its outer case and clean the condenser fins from the inside, this is no easy task as it is very hard to reach. You will want to get a small (toothbrushed sized) brass bristled brush with a long handle. Make sure the evaporator coil (in the front) recieves the same attention and wash the mesh filter that goes in front of the evaporator. Re- assemble and enjoy the cold air.
Posted on Jun 07, 2009
  • 534 Answers
SOURCE: air conditioner doesn't blow cold air. Continues
If the a/c fails to continue to blow cold there could be a few problems you can look for. First once you activate the system check to see if the compressor kicks in. You will hear the compressor humming . Once the a/c quits cooling go and see if the compressor is still running. If its not running its probibly gone into thermal overload (compressor overheated). If that is the case then you need to check to see if the coils are icing up if they are icing up then the problem is with 1) air flow restriction filter dirty, coils dirty simple repairs there replace filter, clean evaporator coil with a coil cleaner that can be purchased at a home repair store cleaning the condensor coil the same. 2) system is low on freon in which case the system will need to be recharged. Also, If you have a digital thermostat replace the batteries that may also be of some help. Good Luck on repairs
Dave
Posted on Aug 31, 2009
  • 55 Answers
SOURCE: The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Posted on Sep 13, 2009
Byant ac not blowing cold air
Check outdoor unit ,if the outdoor fan is spinning ,check if the compressor is coming on , if both fan and compresseor are working
it may be low on refrigerant
Jul 01, 2014 | Bryant Heating & Cooling
Furnace blowing warm air, ac overheats
Sounds like it is tripping on it's high pressure switch. This could be caused by a dirty condenser coil, overcharge of refrigerant, or non condensables in the system ( air most likely). I would get a second opinion from a repuatable company, sounds like he's trying to rip you off.
Sep 25, 2012 | Bryant Heating & Cooling
My air conditioner isnt blowing cold air
is the ac a manual one or automatic? if it's manual then it froze and will no longer work. it froze and is all done working. time for a new one. I bought one 12 years ago and apparently I was suppose to turn on and off. The ac couldn't do that. IF it works on it's own maybe the circuit isn't the higher amp for 220 ac units.
Sep 07, 2012 | tranexp.com Computers & Internet
I have a bryant fin. 15 years old. not getting cool air.i change the fiter.the fan is blowing.
Check the power to the outdoor AC...make sure it is running. If it is, someone will need to check to make sure the compressor is running and that the temperatures & pressures are good.
Jul 22, 2011 | Bryant 463AAC005BA Air Conditioner
My outdoor AC unit is not coming on. Air is blowing out of my vents inside but the snowflake symbol on my thermostat is blinking and the air isn't cold. The fan on the unit isn't even running. Any...
check power to outside unit, check if it has a fused disconnect, if you have power and no blown fuses it could be a blown capicator that starts the fan and compressor...............
May 09, 2011 | Heating & Cooling
I have a 2001 Yukon XL 1500. I broke an AC belt. I had the belt replaced and the system recharged. It now makes a noise when you accelerate after start up. But that is the only time. AC blows cold...
Actually,you both could be right.It may be the bearing inside the compressor.The compressor does not make the cold air,it helps pressurize the system to get the freon from the evaporator to the condenser.The evaporator provides the cold air.If you can,open your hood and have someone start your car.Have them give it some gas and see if you can pinpoint the noise more accurately.If your compressor bearing causes it to seize up,you will probably only get a couple of miles before your belt snaps.Another slight possibility is the tensioner.It's pretty rare but stranger things have happened.I did have a compressor seizure years ago and snapped a belt though.If you can pinpoint the noise it would help to know.If you can't I would like a better description of the noise though.Good luck! Greg
Sep 17, 2010 | 2003 GMC Yukon XL
No power to ac unit
Check the breaker for the unit or check to see if the disconnect by the unit in the attic has fuses that may be blown.
If the breaker is tripped or the fuses blown, then check to see what caused them to blow...
heatman101
Aug 01, 2010 | Bryant 463AAC008BA Air Conditioner
The AC blows on #4 fan setting but doesn't blow at all on 1-3
That is the blower resistor. 4 is wide open, so, no resistance. I had 4 of them put into my truck. The wires were burnt and shorted the others until the problem was found. Check the plug if you do this yourself.
Jun 13, 2009 | 2005 Chevrolet Colorado
Ac compressort had to be replaced because it seized up. AC ran good for 2 weeks then went out, now the heater doesnt want to work half the time. i dont know if its my heater coil, a leak in my ac lines,...
THE BLEND DOOR THAT CONTROLS HOT TO COLD SWITCHING IS STICKING. THE CONTORL HEAD IS ELECTRIC AND MAY BE CAUSING THE PROBLEM. HEAT AND AC ARE 2 COMPLETELY DIFFERENT SYSTEMS EXCEPT FOR THE CONTROLLER UNDER YOUR RADIO. HEATER COIL IS REALLY A HEATER CORE WHICH IS A LITTLE RADIATOR INSIDE THE CAR BEHIND THE DASHBOARD.
Mar 22, 2009 | 2004 Dodge Intrepid
Ac conditioner stopped blowing
do you mean the fan doesnt blow either or its just not blowing cold air? check your fuses under dash and under the hood
i can try to help you further with more info
Jun 14, 2008 | 2004 Acura TL
Heating & Cooling Logo
69 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
