Question about Troy-Bilt 21AE682L766 Big Red 10 HP Electric Start Rear Tine Tiller
I HAVE A 8HP HORSE TROYBILT TILLER. I CAN NOT GET ANY GAS INTO THE CARB. I HAVE CLEAN GAS, NEW HOSES, AND CLEANED THE CARB. THE FLOAT IS NOT STUCK, ANY HELP?
I HAVE A TROY BILT MOWER AND THE ELECTRICLE SCHEMATICS SHOW TWO FUSES. I CANNOT FIND THESE FUSES . ARE THEY HIDDEN OUT OF SIGHT SOMEWHERES? COULD YOU VERBALLY EXPLAIN WHERE TO LOOK FOR THESE FUSES?
Posted on Apr 17, 2011
  • 26 Answers
Have you checked to make sure your fuel shut off valve is turned on? If you remove the fuel line at the tank( with something to catch the gas) and your fuel shut off is turned on and you get no flow then something is clogging the fitting at the tank or inside the tank. You will have to remove and clean the tank. Let me know how you come out.
Frank
Posted on Oct 07, 2010
How do I adjust the carburetor on my 40+ TB horse tiller?
There is a floater in the carburetor which operates a needle gate to stop the overflow; take it apart and check if the needle is stuck or for some dirt.
Aug 18, 2015 | Garden
My troy-bilt 8hp tiller starts and runs good but after about 3 minutes of tilling it dies
Could be a number if things..the filter may be pluged or restricted the fuel pump if it has one us going bad..or if it does not have a pump..and by what you are saying you might have dirt in the carb bowl causing the float that supplies enough fuel under power to stick. This will let enough gas to start and run but under power essentuliy run out of gas temperarly...the carb will need to be cleaned and adjusted..Hope this helps...good luck.
Sep 16, 2014 | Garden
I used my tiller one time and the second time I used it, it was hard to start and when she did, she blew white smoke and would not start after that.
This happens frequently after a tiller, mower, snowblower, etc. sits for a season. Your tiller is probably flooded due to a stuck carb float. You can try a quick fix by tapping gently a few times on the float bowl, then pulling the spark plug and cleaning it with a wire brush, and then wiping it dry with a cloth. If you have a new spare plug to install, that is even better.
Try to start your tiller again, and if the same thing happens, your float is still stuck and you may need to have your carb serviced.
You can try one more alternative if you do not want to go through the bother and cost of having your carb serviced (or purchasing a kit and trying to do it yourself), but it is a 50/50 "hit or miss" sometimes it works, sometimes it don't type thing:
Drain all the gas out of your tiller. put about 2 ounces of carb/injector cleaner in the tank, and top off with gas. Give the float bowl a few taps. Now, pull the spark plug..... make sure the spark plug wire is at least 1 inch away from any metal. With the throttle set to full and the spark plug removed, Pull the starter cord 5 or 6 times (if you have electric start, crank it for about 5 seconds). You may see some vapors come out through the spark plug hole- this is OK.
Clean, install, and connect your spark plug (again, a new plug is even better). Give the bowl a few taps for luck, and try and start your tiller again. If the procedure worked, your tiller may run rough for 10 or 15 seconds (maybe even up to a minute or so... let it take its course!), but then smooth out.... if it stalls, don't worry.... Start it back up.
This will often work for tillers, snowblowers, mowers, generators.... pretty much any 4 stroke "lawnmower engine". It all depends on how badly the float is stuck after the engine sits.
You can minimize having this problem in the future (it may still happen, but less often and less severe) by adding a good fuel stabilizer (such as the brand name STA-BIL) to your gas and running for 10 minutes or so before you store your "lawnmower engine" for the season.
If you still have problems, the likely cause is a stuck carb float and the carb will need to be serviced.... but hopes are high that my solution helps!
Good Luck, and Thank You for using FixYa!
Apr 20, 2011 | Garden
I am in need on line of the owners manual for troybilt "8-hp Horse" tiller and fluid capacities and type/weight of oil used in front transmission and rear tine gears. Thank you, Sincerely, Wm....
This is as close as I could come to your exact model from this site. This is for a 8HP Briggs Horse model with rear tines. I hope this can help you. This site (the manuals site) needs to update to newer models. First a link to the site I use and secondly, the PDF online file of the 8 HP Tiller for you.
http://www.manualsonline.com/
http://dl.owneriq.net/7/7ba1d4f6-61b9-4c56-b878-fcfa51ddfeef.pdf
Apr 12, 2011 | Troy Bilt 21A682J766 Horse 8 HP Rear Tine...
Old (1981)Troy Prof. 8hp tiller runs 30 sec. and stops.
Clean the carb and if this machine was kept outside all winter make sure no water in tank. I realize you stated that you removed old gas but how it was removed is the key. Try the carb thing first though.
Apr 28, 2010 | Troy-Bilt Pony Garden Tiller
Gas flows freely out the carborator pn 632351 on a tecumseh 8hp
needle and seat valve stuck open remove float bowl and find the cause
Sep 27, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Briggs carburetor problem
Yes, the jet can be cleaned, along with any other small portals in the carb. Use a Den Tek Brush,(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152). They are great for this job!
Jim
Jun 09, 2009 | Troy-Bilt Garden
Float was sticking ,now will only run if i feed it
Here is a website that will tell you where to look for your particular engine number and how to obtain original tecumseh parts. good luck with it. if you need any other assistance please get back. i really do want to help you get your tiller running again.
May 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy-Bilt 21AE682L766 Big Red 10 HP Electric Start Rear Tine Tiller Logo
347 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
