Removing card memory - Computers & Internet
  • 3,083 Answers
I'm not sure what kind of device you're trying to remove the memory from, but the way cards work is that they push into a slot, and lock. To get them out, you push on the card, and it releases the lock and pops out about 1/4" so you can grab it and remove it. This is true for digital cameras and a lot of devices.
Hope this helps, and good luck!
Posted on Sep 27, 2010
My vivicam x024 won't turn on. how do i remove the memory card? will the photos still be on the card if I remove it?
The SD memory card slot in located on the side og your camera. Push the SD card and it will pop out.
The photos are stored on the SD memory and removing it from the camera will not lose the photos stored on this SD memory card.
Remove the memory card from the camera and insert it into anUSB memory card reader. Connect this USB memory card reader and memory cardinto the USB port of your working computer. Your computer will see this as anUSB Mass Storage Device or an external storage device; you can then open thefolder on the memory card and copy the photos to your computer.Memory card reader is a handy device and is inexpensive. Youcan copy photos from other cameras and you can also download photos off yourmemory card to someone else's computer without the need of installing anyprograms.
May 28, 2012 | Vivitar ViviCam 5100 Digital Camera
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
How to remove memory card my n73
The memory card slot for Nokia N73 is located at the bottom of the keypad just above the charger connector.
  1. Before you eject the card, press the power key, and select Remove mem. card. All applications are closed.
  2. When Remove memory card and press 'OK' is displayed, open the door of the memory card slot.
  3. Press the memory card to release it from the slot.
Do not remove the memory card in the middle of an operation when the card is being accessed. Removing the card in the middle of an operation may damage the memory card as well as the device, and data stored on the card may be corrupted.
Jun 29, 2011 | Nokia N73 Cellular Phone
I was using black berry then i switched to nokia e50 and i remove the mmc from black berry and when i inserted it to nokia e50 memory card is currupted how to solve this problem
You may need to format the memory card with your Nokia device.
However, all data in the memory card is permanently deleted if you format the memory card.
It is recommended to back up device memory regularly to the memory card. The information can be restored to your device
later.
To back up information from device memory to a memory card, select Menu > Tools > Memory card > Options > Backup
phone mem.
To restore information from the memory card to the device memory, select Menu > Tools > Memory card >
Options > Restore from card.
Do not remove a memory card when the card is being accessed. Removing the card in the middle of an operation may damage
If you cannot use a memory card in your device, you may have the wrong type of memory card, the card may not be formatted
for your device, or the card has a corrupted file system.
Tip: You can install and remove a memory card without removing the battery or powering off the device.
Dec 21, 2010 | Nokia E50
My memory card getting automatically removed from the phone giving error msg. uasafe to remove memory card withou selecting "remove mem. card" first......... autometically
hmm...reset ur mobile (w/o mmc) and after that..switch off fone,insert memory card and start.. <even i had same prob but now solved >
Jun 15, 2010 | Nokia N73 Cellular Phone
To clear sd memory card password
i cant to delete files from my memory card
Mar 20, 2010 | SanDisk 2GB microSD Memory Card
How do i remove memory card from my nokia
1. If the device is switched on, before you remove the card,
press the power key, and select Remove memory card.
2. When Remove memory card? Some applications will
be closed.
is displayed, select Yes.
3. When Remove memory card and press 'OK' is
displayed, open the cover of the memory card slot.
4. Press the memory card to release it from the slot.
5. Pull out the memory card. If the device is switched on,
select OK.
Regards,
Jeep Brainy
Sep 13, 2009 | Cell Phones
Memory card password remover
i want software for remove password from phone's memory card.i kindly requesting.
Jul 28, 2008 | Nokia 7610
Problem with "remove memory card"
Your memory card is like having a contact issue.
Remove your memory card, grab an eraser(the end of the pencil will do best), erase or scrube the gold contact point of the memory card and test it.
It should work fine now.
Hope this helps...
Jun 21, 2008 | Nokia 6681 Cellular Phone
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
