Question about Garden
I need the torque specs for the cylinder bolts on a Stihl MS 660
chuck943
  • 783 Answers
SOURCE: Head bolt torque specs needed for 96 tbird 3.8
Head bolts are torque to yeild so you MUST use new bolts.
Tighten cylinder head retaining bolts in numerical sequence in three steps as follows:
  1. 20 Nm (15 lb-ft).
  1. 40 Nm (30 lb-ft).
  1. 50 Nm (37 lb-ft)
Loosen retaining bolts one at a time two to three revolutions and retighten as follows:
Long bolts:
  • Tighten to 40-50 Nm (30-37 lb-ft).
  • Rotate an additional 175-185 degrees.
  • Go to next bolt in sequence.
Short Bolts:
  • Tighten to 20-30 Nm (15-22 lb-ft).
Here is a pic of the sequence
http://i253.photobucket.com/albums/hh43/chuck943/Headboltsequence38L.gif
Posted on Mar 19, 2009
outdoorsman5
  • 631 Answers
SOURCE: head bolt torque specs for 2000 dodge neon 2.0 SOHC
I have the specs and diagrams. If you want me to send them to you, give me your email address. Outdoorsman592003@yahoo.com
Posted on Sep 05, 2009
inspectmycar
  • 233 Answers
SOURCE: 94 mazda B3000 3.0L cylinder head torque specs
Step 1 torque to 59 ft pounds
2. Loosen one full turn
3. 37 ft pounds
4. 68 ft pounds
Use torque sequence below
Posted on Sep 17, 2009
Dolfoff
  • 148 Answers
SOURCE: How would I replace the bar hold down stud bolt in
At our dealership we replace the Bar studs with Heli-Coil and locktite for $20.
NOTE: Remove the old stud by double-nutting and screwing out of the case and marking the end that came out. Take it with you to NAPA and get the correct Heli-Coil size and a small tube of BLUE Loctite. (Might be cheaper to let the Stihl dealer do it)
Hope this helps!
Posted on Sep 28, 2009
sirgabe51
  • 66 Answers
SOURCE: I have 4.9L6 need torque specs for cylinder head
for cylinder head the torque is : step 1 55 ft-lb, step 2 65 ft-lb, step 3 85 ft-lb. Rocker arm stud nut or bolt is 17 to 23 ft-lb. and valve cover bolt 72 to 108 in-lb.
Posted on Dec 05, 2009
Flywheel torque spec's for 1983 Ford F-100
Could it be a F-150 instead?
Ford Engine Bolt Torque Chart Bolt Torque Spec Chart for Ford Engines
These specs are for stock-type bolts with light engine oil applied to the threads and the underside of the bolt head. Moly and other lubes offer reduced friction and increased bolt tension, which will affect the torque figure. If you use after-market performance bolts like ARP's, you should follow the recommended torque specifications.
260, 289, 302 Torque Spec.
Fastener Type Torque Spec Main cap bolts 60-70 ft-lbs Outer main cap bolts 35-40 ft-lbs. Connecting rod bolts (40-45 ft-lbs. for 289 HP & Boss 302) Cylinder head bolts 65-72 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs Oil pump bolt 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolts 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351W Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 90-100 ft-lbs. Rocker arms 17-23 ft-lbs. Intake manifold bolts 23-25 ft-lbs. Oil pump bolts 23-28 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 8-10 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 351C, 351M Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (45-50 ft-lbs. For Boss 351C) Cylinder head bolts 105 ft-lbs. (125 ft-lbs. For Boss 351C) Rocker arms (non-adjustable) Rocker arms (non-adjustable) 5/16in. intake manifold bolts 21-25 ft-lbs. 3/8in. intake manifold bolts 28-23 ft-lbs Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Cam thrust plate bolts 9-12 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs. 360, 390, 406, 427, 428FE Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs. Crossbolts for 406-427 40 ft-lbs. Connecting rod bolts 40-45 ft-lbs. (53-58 ft-lbs. For 406 and 427) Cylinder head bolts 80-90 ft-lbs. (100-110 ft-lbs. For 1963-67 427) Rocker arm shaft bolts 40-45 ft-lbs. Intake manifold bolts 32-35 ft-lbs. Oil pump bolt 12-15 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-15 ft-lbs. 429-460 Torque Spec.
Fastener Type Torque Spec Main cap bolts 95-105 ft-lbs Connecting rod bolts 40-45 ft-lbs. Cylinder head bolts 140 ft-lbs. Rocker arms (non-adjustable) 18-22 ft-lbs. Intake manifold bolts 25-30 ft-lbs. Oil pump bolt 25 ft-lbs. Cam bolts 40-45 ft-lbs. Harmonic damper bolt 70-90 ft-lbs. Flywheel / flex-plate bolts 75-85 ft-lbs. Pressure plate bolts 35 ft-lbs. Front cover bolts 12-18 ft-lbs.
Dec 18, 2015 | Ford Cars & Trucks
Torque spec's for the fly wheel
Dec 18, 2015 | Cars & Trucks
Cylinder head to engine block torque sequence and ft lbs
    images for Cylinder head to engine block torque and ...
    More images for Cylinder head to engine block torque and sequence
    Small Block Chevrolet V8 Engine Specs ' Torque Specs ...
    boxwrench.net/specs/chevy_sb.htm
    their specs. Click Here! 3/8 Connecting Rod Bolt, Engine Oil, 45 ft-lbs. 11/32 Connecting Rod Bolt, Engine Oil, 35 ft-lbs. Cylinder Heads. Engine oil. (blind hole).
    [PDF]
Nov 29, 2015 | Cars & Trucks
Need head bolt torque specs for a 1996 saturn sl
Quote:
Originally Posted by norvelplagbao52
1993 saturn sl2 1.9 dohc cylinder head torque
specs and sequence
Cylinder head bolt
tightening procedure:
CYLINDER HEAD BOLT TIGHTENING SEQUENCE:
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
torque the cylinder head bolts. Torque: 30 Nm (22 ft-lbs).
In sequence,
torque all bolts. Torque: 50 Nm (37 ft-lbs)
In sequence, turn each bolt an
additional 90 degrees.
specs and sequence
Cylinder head bolt
INTAKE
SIDE
8 4 1 5 9
7 3 2 6 10
EXHAUST SIDE
In sequence,
In sequence,
Sep 19, 2013 | 1996 Saturn SL
I need to find the torque specs for the connecting piston rod? also the sequence and torque for the cylinder head bolts this is for a kia rio 2004 6cyl
22 - 24 ft. lbs. for the rod caps and....
110795143Cylinder Head Tightening Torque and Sequence.
Tighten cylinder head bolts in order shown.
Tightening torque: 36.1 ft. lbs. (49 Nm, 5 kg-m)
Loosen bolts in reverse of order shown.
Retighten cylinder head bolts in order shown.
Tightening torque: 18 ft. lbs. (25 Nm, 2.5 kg-m)
Mark cylinder head bolts for rotational reference.
Rotate cylinder head bolts 90°(1/4 Turn) in order shown.
CAUTION:
  • Do not reuse the old cylinder head bolts.
May 31, 2010 | 2004 Kia Rio
Dec 05, 2009 | 1988 Ford F 150
Chain stops under load ms 660 stihl
your centrifical clutch need to be replaced there is no adjustment,I hope this helps you?
Oct 01, 2009 | Garden
3. 37 ft pounds
4. 68 ft pounds
Sep 17, 2009 | 1994 Mazda 2WD B Series Pickup
Need to know cylinder head bolt torque specs
Head Bolt Torque For your 1994 Oldsmobile Cutlass Supreme (3.4L SFI DOHC): clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 6 2 3 7 | | 5 1 4 8 | --------- Step 1: torque in sequence to 33 Ft/Lbs Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque. clearpixel.gif clearpixel.gif clearpixel.gif Foot pounds (Final torque) clearpixel.gif Note: Torque sequence --------- | 8 4 1 5 | | 7 3 2 6 | front --------- of engine | 6 2 3 7 | | 5 1 4 8 | Step 1: torque to 40 Ft/Lbs --------- Step 2: turn an additional 90 degrees Recheck final torque in sequence *** CAUTION ***engine uses Torque To Yield head bolts (TTY) thatpermanently stretch during the initial installation.New head bolts must be used when cylinder head isreplaced or re-installed to obtain proper torque.
Feb 07, 2009 | 1994 Oldsmobile Cutlass Supreme
Garden Logo
410 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
