Question about Troy Bilt 5.5hp Self Propelled Mower
I have a troy bilt self propelled mower model #12AV565Q711. The drive cable came loose from the transmission area. I have no idea where this connects. Does anyone have a diagram or can someone explain to me where it connects.
SOURCE: how do i replace a drive belt on a troy bilt self propelled lawn
You turn the mower over, remove the blade with a 9/16 or 5/8 socket. There is a bolt holding shroud on, 3/8 or 7/16, there are two screws by the rear wheels, 7/16 that need to be removed. Once the shroud is removed, belt can be removed and new one put on.
Posted on May 26, 2009
SOURCE: Troy Bilt 33
If you didn't by the Troybilt belt, try that. I had the same problem with a Napa belt. Going into drive as soon as I grabbed the operator presence button, not coming out of gear etc. When I switched the the Troybilt belt, the problem went away.
Posted on Aug 16, 2009
radar001
  • 1051 Answers
SOURCE: front wheels lock up when pull mower backwards
Typically self-propelled mowers are propelled using the front wheels, which only turn forward. Pulling the mower back while the front wheels are turning will damage the drive gears. It's best to raise the front wheels slightly off the ground before pulling back.
Posted on Mar 24, 2010
SOURCE: my troy built 210 6.75 hp mower self propelled mow...
remove the front black plastic plate that is stamped self propelled and replace the wheel drive belt that attaches the engine pulley (above blade) to the transmission pulley (found under the cover). When you buy the belts, pick up two or three as I seem to go through a couple per season. Hopes this helps
Posted on May 30, 2010
  • 251 Answers
SOURCE: My Troy Bilt self propelled
Hi , it can often be something as simple as the engine needing a oil change as oil looses viscosity/thins with use ( use correct grade ), replace or clean the oil filter and a good service or something more complex which requires a full engine stripdown like worn piston ring/oil scraper ring causing oil to flow up the cylinder walls and fouling the combustion chamber or oil leaking up through the valve stem oil seals , also storing the machine tilted can cause oil to collect in the chamber or petrol to leak into the sump causing the oil to thin.
Hope this helps , please rate accordingly
Posted on Aug 31, 2010
Variable speed doesn't work troy bilt self propelled lawnmower
Cable could be stretched belt could be worn or old, if it has a gear box maybe it slipped a gear or lost some teeth. Do some investigation, Good Luck
Jul 26, 2010 | Troy Bilt 5.5hp Self Propelled Mower
My troy built 210 6.75 hp mower self propelled mower doesnt pull
May 20, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Front wheels lock up when pull mower backwards
Mar 24, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt self propelled problem
My only guess is you've put the cable actuator in upside down. Sorry, that's the only thing that makes any sense.
Aug 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Replacing Drive Cable on 05 Troy Bilt Self Propelled Lawn Mower
It is a pain in the ***!!! but not impossible to do it your self.
Jul 27, 2009 | 2005 Ford Focus
Self propel always engaged
you may have lost the spring that pulls the transmission drive belt down or have the cable adjuster too tight.word of caution here, the cable goes thru the engagement lever and if you overtighten it the lever will crack or break. if it does the complete transmission will have to be replaced.seems they dont make the lever avalible seperate.
Jul 09, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt lawn mower. Will not engage self propell, front wheels
Hello:
Send me the Model and Type or Spec Numbers Off the Engine and the Mower Model Numbers, Please. With these I can Locate the Proper Manual and Better Assist you. The Engine Model Numbers May be Stamped Into the Blower Housing (metal engine cover) Above the Spark Plug. The Mower Model Numbers are Usually Located Under the Seat on a Sticker on the Body of the Mower.
>>If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance. Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Happy.
>>Thanks.
Respectfully
John
Apr 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
446 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
