Question about True TD-65-24 Commercial Refrigerator
Water in bottom of cooler - True TD-65-24 Commercial Refrigerator
    Sergeant:
    Novelist:
  • 193 Answers
There is a drain in the bottom of the box usually in the middle of the box. It must be stopped up.
Posted on Sep 27, 2010
I have a primo bottom load water cooler model # 900130 the pump is not working. How do I fix it
I have missing or damaged parts. + - Select parts are available for your dispenser. Please complete the Contact Us form and provide the dispenser model number, serial number, and note the replacement part needed in the comments field. A Care Specialist will follow up with your request. A replacement fee will apply to out of warranty part requests.
900130 Primo Water Store
Dec 26, 2015 | Unknown Primo Deluxe Stainless Steel...
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Gas smell in coleman cooler
Clearly someone used the cooler to dump gasoline that was probably old. That odor is extremely difficult to get out. First try this: Let it air out indirect sunlight, tilting the cooler so the sunlight gets to the inside, Do this for at least three days and as much as a week. After you've done that, there will likely still be some of the gasoline smell still there but it should be a lot less noticeable.
Next, get a large box or even a bag of baking soda. Make sure the drain plug is in and dump at least two cups of baking soda in the bottom of the cooler.
Add enough water to make a paste of the baking soda. The paste should be thick enough to smear and stick to the walls of the cooler. Do that...smear it on, completely covering the walls, bottom and inside of the top of the cooler.
If you run out of paste make a little more but make sure that every part of the inside of the cooler is covered with paste. Leave the paste on for a minimum of 24 hours but preferably 48 hours or more. Shut the lid to slow down drying of the paste.
After 24 hours or more, check to see if any odor remains. If it does, wait another 24 hours. After 48 hours, the baking soda will likely have done as much as it's going to do. Rinse the dried baking soda off the walls bottom and top, letting the residue collect in the water that is filling the cooler.
Add the remaining baking soda in the box or bag to the water stirring it until it has dissolved. Fill the cooler to the top with water and close the lid. Wait 24 hours then drain the cooler. If you're lucky the odor, or most of it, will be gone.
This is a slow tedious process but it can work. I've never tried it on gasoline odor but I used it forplastic pickle buckets and it's never gotten the odor completely out but it has gotten enough out to make the bucket usable. Good luck!
Apr 02, 2014 | Coleman 54qt Classic Steel Belted Cooler
How to clean and sanitize a Kentwood water cooler?
Using one cup of bleach Per 5 gallon jug. Find the drain plugs on the bottom of the unit there are two. Drain unit of any water that is in it now. Replaced drain plugs. Place 5 gallon jug on top of unit and allow unit to fill. Be sure that heated water is off. Open spigots and allow a gallon of water to drain. After about 15 minutes open the drain plugs and allow all of the solution to drain out. Proceed to fill the 5 gallon jug with clean Clear filtered water and allow that to drain thru the unit, do this five more times.
Oct 29, 2013 | Hamilton Beach Water Cooler with Storage...
Help the water just pours out the bottom, what am I doing wrong?
I took the back off of mine and one of the hoses was disconnected, connected and it works fine....
Aug 09, 2011 | Hamilton Beach Water Cooler with Storage...
I HAVE A G.E. SMART WATER COOLER THAT LEAKS WATER FROM UNDER BOTTOM BASE I HAVE TO KEEP A TOWEL ON THE FLOOR UNTIL ITS GETS SOAKED THEN I CHANGE IT, USUALLY OVERNIGHT, I'M USING A 5 GAL. BOTTLE...
try replacing the bottle...it might have a hairline crack that is causing the "leak". I have the same cooler and had the same issue...replaced the bottle and all was well then.
Roy Martinez
Jan 12, 2011 | General Electric GE SmartWater Household...
Water accumulation underneath the bottom vetable
Two solutions
1 If a frost free fridge/freezer - ice build up in internal cooler - defrost totally until no more water
2 if ordinary fridge/freezer look inside at the back, you should see a very shallow 'V' shaped plastic channel running to a small drain hole which leads to the rear outside of the unit. This channel collects the water drips from the cooler
Clear this hole with a pipe cleaner or cocktail stick or similar
Sep 27, 2009 | Samsung Refrigerators
Cold water is freezing
if ur water cooler is freezing there could be two different things wrong, one yes is the thermostat, the second how ever is a relay switch located at the bottom of your cooler.
need any help? omilian.jos@gmail.com
May 04, 2009 | Hamilton Beach Water Cooler with Storage...
Water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Nov 25, 2008 | U-Line Wine Captain (2015WC) Wine Cooler
True TD-65-24 Commercial Refrigerator Logo
108 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
