Question about Frigidaire Refrigerators
SOURCE: Hidden Ice build-up inside plastic bottom cover of freezer
Generally, icing is the result of too much water vapor inside the unit, blockage of the circulation channels and too much packing in of the box. The water vapor is generally caused by: uncapped items in the fridge, opening the door too often, humid conditions, bad door seals. There is of course, there is a possibility that the defrost cycle on the unit is not working. About once a day, depending on the brand, you should notice that the fans and compressor don't run and you should hear a bit of creaking, sloshing or other strange noises as the ice melts. If this is not happening, your defrost timer or the coil it heats could be bad.
Posted on Nov 12, 2008
SOURCE: On our Kenmore Coldspot Model 71182100, water is
We have found a solution to our problem. Please take our info off of your list.
Posted on May 02, 2009
SOURCE: ice maker flooded top freezer compartment
It may be just the water control valve on back of refrigerator. Put tap water in ice maker and lower lever for on. After ice is made, does it drop to tray? At this time when empty is the time the control valve is asked for water. The problem could be in valve on back or the inside ice maker itself. If you can try a few test with me I will help you locate the problem. Let me know what you find as I go through this with you. Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 20, 2009
SOURCE: GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Posted on Oct 06, 2009
SOURCE: Waterline Rattling AND DIRTY ICE CUBES
Sound like a clogged valve or a dirty water filter. Change the filter then try it. Good luck.
Posted on Nov 09, 2009
Jan 21, 2015 | Frigidaire Refrigerators
Jan 07, 2014 | Frigidaire FRT15B3A Top Freezer...
Oct 28, 2009 | Frigidaire FRT8B5EQ 30" 18.2 Cu. Ft. Top...
Jun 20, 2009 | Frigidaire FRT21H8 Top Freezer...
Jan 09, 2009 | Frigidaire GLRT186TA Top Freezer...
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
Dec 05, 2008 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Nov 21, 2008 | Frigidaire FRT21H8 Top Freezer...
Sep 01, 2008 | Frigidaire FRS26R4A Side by Side...
Nov 12, 2007 | Frigidaire Refrigerators
Mar 03, 2018 | Frigidaire Refrigerators
229 people viewed this question
