Question about Siemens Washing Machines
SIWAMAT XSP 1241 I start it up, here the water being pumped in and then nothing. The machine seems to be working ok, but it is not spinning. Now there is just water accumulated in the machine.
  • 209 Answers
SOURCE: Washing machine not spinning
check for a capacitor on the motor if it has one, replace that to start with, that what it sounds like
Posted on Oct 10, 2007
  • 3422 Answers
SOURCE: WFL 2066 NOT DRAINING FULLY - NO SPIN
THIS LINK may help you understand what is actually wrong.
Goodluck,
Please don't forget to rate or accept the solution.
Posted on May 20, 2008
jyackle5
  • 8197 Answers
SOURCE: my siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Posted on Dec 16, 2008
dh1200s
  • 335 Answers
SOURCE: Model FAV6800AWW will not pump water out if clothes are in machin
Hello domino14
Your experiencing symptoms of clutch malfunction with the FAV6800AW. Do you want to dive in and try to fix? Here is what is involved to pull the clutch out of your machine. Also read the last couple of post in this forum. If you call a repair service in your are looking at $300 +. If you can DIY the repair cost could be from $10 dollars if you just need a roller clutch clean up and re-lube to $50 -140 for a replacement clutch. I’m cheap and would go for the $50 Clutch.
First check is to lift lid and see if you can rotate the empty wash basket CCW with one finger. That will let us know if you are experiencing some drag with the roller clutches in the clutch assembly. Here is a step by step to remove the clutch. It is a tight work area but can be done with basic hand tools and basic mechanical skill sets.
What is the serial number of your machine? Just need the first two digits i.e. 10, 12, 14, 16. This info is located on the top right back side of the console.
Next comment will be the clutch removal process, this board has message limits.
Posted on Apr 24, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Machine starts, fills with water & then nothing... clicks on and off & time counts down. Won't spin or drain water... have cleaned filter & removed pump to check it-- all good--- then worked for two loads...
YOUR ISSUE SEEMS TO INDICATE TO AREAS TO LOOK INTO THE NON WASH OR NO AGITATION USUALLY IS DUE TO A BAD WATER PRESSURE SWITCH, THE NO DRAIN NO SPIN IS USUALLY DUE TO A CLOGGED PUMPED OR IMPEEDED PROPELLER, ARE U SURE U CHECKED IT WELL? THE ONLY OTHER THING COULD BE IS UR CONTROL BOARD IS MIS COMMUNICATING WITH UR DRAIN PUMP?
SEE PICS
May 26, 2015 | Washing Machines
Siwamat xli1240
Unplug it for a minute, that should reset it, if that does not work, then you need to get a meter to check the heating coil and also the water valves to see if they are ok.
Nov 11, 2013 | Washing Machines
Drum not turning despite belt ok and motor ok, lots of sediment from drainage pipe
check the pump/impeller for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 26, 2009 | Washing Machines
Hotpoint Aquarius 1200 Washer Dryer not drying.
Hi, I think the problem you have is with the cold water inlet valve? When your machine dries it uses a small amount of water at high pressure through a restricter fitted in the water inlet valve. These break down letting in to much water which cannot evaporate quick enough for it to pump out causing the washing to become wetter than after the wash/spin cycle. The only way of solving this is to replace th tree way water inlet valve. But make sure that the pump is working ok first and that there is nothing in the sump hose trap which is located underneath the washing machine out the bottom of the tub.
Good luck.................
Dec 28, 2008 | Hotpoint Washing Machines
My siemens washer will not pump the water out or spin
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
Shows "LE" in display.
Machine has a bad motor or "stator" on this machine. It is a direct drive winding on the back of the machine. Remove the back panel, the one bolt removes the rotor then you will see the stator winding, replace it and your good to go.
May 11, 2008 | Washing Machines
Indesit w11
does it have a manual programme knob?if it does ,probably the internal contacts do not mesh so it stops at next step (programme)but the water pump keeps on making the noise.
try turning the knob by hand when machine stops before entering next programme cycle.if machine starts ,programme knob is the problem.
Mar 21, 2008 | Washing Machines
Washing Machines Logo
172 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
