Question about Quickie Wheelchairs Parts Breezy Ultra 4 Light Weight Wheelchair Quickie
The plastic 'panels' on my armrests are broken, can they be replaced without buying a new armrest?
  • 10,865 Answers
Hello. Here is a link to the parts dept. of your chair's manufacturer
http://www.quickie-wheelchairs.com/wheelchair-parts/sunrise-medical/breezy-ultra-4/base-frame/frame/hemi-frame
Joe
Posted on Sep 27, 2010
How do I remove an armrest on a 1984 Ford Bronco?
Pull the armrest vertically up. There is a slot in the armrest and a pin on the frame. You have to match these to pull the armrest off. Without a zipper it's a little more challenging. Some armrest have a little screw that keeps the armrest on the frame. The older models usually worked with the slot and pin.
Dec 31, 2016 | 1984 Ford Bronco
How do replace Honda Accord Armrest Vinyl Front Door Panels Armrest Covers
See the crack, the arrm rest is in 2 pieces remove the side it is snap ,there is 2 or 3 screws inside
Apr 22, 2014 | 1999 Honda Accord
Armrest on passenger side door
sometimes yes..there are bolts and screws that hold it on..take those out and the armrest should come off..(padded part anyway..)then you can decide on a salvage part or try to put something else on it..
Dec 22, 2013 | 2000 Dodge Intrepid
Where can i buy kia spectra armrest
Go to your local Kia dealership.
murf427
Aug 02, 2012 | Cars & Trucks
How to replace armrest latch
If you are talking about the center armrest between the two front seats, the repair is easy. The plastic latch can be ordered for about $10 and replaced by taking apart the top lid assembly. I did it and it is not hard at all. Now if you are talking about the armrest compartment, that is one the I have not had any luck figuring out and have not found a solution to from anyone else.
If anyone knows how to reattach the armrest please let me know. My e-mail is pvd3@yahoo.com. Thanks, Pete
Jul 31, 2012 | 2003 Lincoln Town Car
How do i replace the hand grip on guardian red dot crutches?
I had the same problem, but i found an answer.
have a friend with 2 good feet help you with this.
Turn the crutch upside down and place armrest on the ground.
Stand on the outside edges of the armrest and pull crutch upward. The armrest is not glued to the rest of the unit. It's just a snug fit. Once the armrest is removed, the hand piece can be removed.
Now comes the struggle to remove the damaged rubber hand grip, and put the new one on, took me about 5 minutes to do this step.
Then reverse what you've done, put the hand grip back on the crutch, put the armrest back on, turn the crutch upside down, and push the armrest back into place.
Hope this helps!
Jan 01, 2012 | Optics
How to remove passenger interior door panel?
check your armrest on the door panel, it should have 2 or 3 plastic plugs that cover the screws that hold the armrest onto the door,
these plugs can be gently levered out with a pointed instrument or a small screwdriver, also check for screws where you put your fingers to close the door when you are in the car.
if the door handle is on the armrest or the door trim you will see a x screw that holds it to the door, remove the screw
you may need to buy a set of torx drivers for removing the screws for the armrest and the door handle (Maybe)
once these are removed check for any screws around the bottom of the door trim, if there isnt any, use a flat instrument such as a knife blade or a blade screwdriver and put it between the back of the trim and the door and lever it back gently
Jul 08, 2010 | 2006 Chrysler Pacifica
2 items. Front basket support and armrest
You shold be able to order replacement parts for both the basket and the arm rest. Have your serial number ready. You can contact me if you would like them ordered.
John R.
May 30, 2010 | Pride Legend 3 Wheel Mid-Size Scooter
The door handle (looks like an armrest came off. Do I have to buy a whole new door panel?
That is the best fix. Even though you paid a lot of money for the car BMW hasn't figured out how to make decent door panels. They're stuck on this cheap fiberboard, waferboard panels covered with leather and vinyl. Then they put an occasional heavy duty bolt through it to hold on the door handle and armrest. Pull on it hard enough against the wind one day and bingo, the waferboard breaks and there really isn't a decent repair. Gorilla glue, epoxy, etc. might hold you over.
Wait til you get a leak in the door plastic. Then the water turns the waferboard door panel to mush.
Nov 10, 2009 | 1996 BMW Z3 Roadster
I need to know how to get to my drivers side window motor to replace it. i have a 1989 mustang lx 5.0
Remove the door panel -- it is held on with snap fasteners pushed into holes areound the edge of the door panel. There may be few screws to remove around the handle, and armrest, etc.
May 05, 2009 | 1991 Ford Mustang
Quickie Wheelchairs Parts Breezy Ultra 4 Light Weight Wheelchair Quickie Logo
308 people viewed this question
Top Quickie Wheelchairs Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Quickie Wheelchairs Health and Beauty Expert? Answer questions, earn points and help others
