Suggestions on fixing slow log in and sometimes not able to get login screen upon boot?
  • 3,083 Answers
The most helpful thing you can try is to modify the "startup programs" when your computer boots up. This will make your bootup shorter, and less likely to cause problems with the log in screen. Here is a web page that explains what to do:
http://www.ehow.com/how_5843727_fix-slow-log-windows-xp.html
There are programs you can purchase to clean the registry, but try the utilities in Windows first...they are free, and can help in many cases. Here's a site that suggests the uninstall options in Windows, and can free up memory that unused programs are "soaking up":
http://howtospeedupyourcomputer.net/windows-xp-slow-login.php
I assumed you're running Windows, but there are fixes on the net for Linux and Mac systems, just google "slow startup" and enter your system type, and you will hit on some web pages.
Good luck, hope this helps, and thanks for using FixYa.
Posted on Sep 27, 2010
Screen turns pink after login
While in Safe Mode....
Go to HP.com, Support, Drivers....
Download the latest video drivers, including the "Chipset" drivers.
Then, uninstall all video drivers by going to control panel, (System, Device Manager)
Reboot system, hopefully Windows will install the correct drivers upon reboot.
After reboot, re-run the new drivers
Mar 12, 2013 | HEWLETT-PACKARD Compaq Presario CQ56-110US...
Login error
restart your pc once and then try again.
Oct 05, 2008 | Dell Inspiron 1000 Notebook
Windows logon problem
so it logs you in and then logs you back out immediately? If that's the case try booting in safemode by hitting f8 during boot.
Oct 09, 2012 | HP Compaq 6820s Notebook
WIN VISTA boots up to the login screens. When I
try going into safe mode,usualy by pressing f8 after restarting it,then select safe mode and see if it boots.If it does boot then you most likely have a driver,virus or maleware problem.There is always the system restore option too from safe mode.
May 14, 2010 | Acer Aspire 4315 Notebook
HP 6910p will not boot upon restart. If the
seems like there is some s/w glitch in it. try to create a new admin a/c. hopefully it will fix the problem.
Apr 28, 2010 | HP Business Notebook 6910p Notebook
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
Acer Aspire M1100 Desktop - lost password, can't login in User Login. Is there a way to bypass the password?
If you're having trouble logging into Windows, you can attempt to use the Administrator account to edit/remove the password of the user login. The Administrator account is hidden by default while in normal mode. You'll need to boot the PC into Safe Mode and login as the Administrator account. Follow the below steps:
  1. Reboot the PC and before the Windows boot screen appears, tap the F8 key about once per second.
  2. Eventually you'll be faced with a screen asking you how you want to boot Windows. Select Safe Mode.
  3. You will see some dll, sys, and com files scrolling down your screen, this is normal. Eventually the PC will boot up and you'll have a login screen with your User Account(s) and a new account, Administrator. Select Administrator.
  4. As long as you haven't, in the past, altered the password for the Administrator account, you should be able to simply click this account and have it log you in. If it requests a password, you might try "password" (without quotes) for the password.
  5. Once in, Navigate to Start -> Control Panel -> User Accounts
  6. Select the User Login information that you're not able to log into and remove the password for the account or change it something you know.
You can now reboot the PC normally and be able to log into this account without a password or with the password you created.
Mar 05, 2009 | Acer Aspire™ T180 PC Desktop
Can't get past log on screen on HP laptop
press cortl+alt+del whneyou have the log on screen
click on option button at eh lower right corner, that will bring you;
login name
password
domain
change the domain to local computer,
login name =admin or administrator,
password= blank, or Admin or Administrator
Dec 26, 2008 | HP Pavilion Ze4900 Notebook
Travelmate 290 starts then shuts down
please re install the recovery software.
Dec 10, 2008 | Acer TravelMate 290 Notebook
Computers & Internet Logo
David Payne
David Payne
