WJ-MX12 powers on but doesn't send video signal
  • 3 more comments
  • 734jeant May 23, 2008
    This is NOT a projection television. It is an AV mixer.
    I don't know how to perform a factory reset.
    When I turn it on, only the power light comes on. No "Sync warning light, no buss lights, or any of the others that are usually lit.
    Thank you. Abrsvcs, for your help
  • jeanfr Dec 16, 2008
    How can I restore to factory settings?
  • 4,234 Answers
Make sure that you are sending in the correct signal type. Also, try resetting to factory. If you messed up a setting, you could end up with just the black field. Also, is there anything in the "preview" output?
Dan
Posted on May 23, 2008
  • ABRsvcs May 23, 2008
    I realize that. There should be a factory reset option. I believe that your model also allows you to black out the output. If the settings have been confused it is possible that this unit is "stuck" in the blackout mode. Try the factory reset first. I'll look up the model tonight and see about other options for you.
    Dan
Directv remote and LG remote will not control tv, just receiver
Let's start simple first. Your TV is not responding to either remote control, but specifically if your factory original LG remote does not operate the LG TV, then the problem could be with the IR receiver in the TV itself.
Ensure nothing is blocking the IR receiver on the TV. Move anything out of the way.
Test both remotes to ensure that they are sending an infrared IR signal to the TV. Use a digital camera (such as the one on your phone) and point the remote into the camera lense and press the power/volume/channel buttons. You should see a faint flashing light in your camera viewfinder. This indicates that the remote is sending IR signal. If you don't see anything, then there is no signal. Try FRESH batteries.
If your remotes are working, and since this is an LG, look at the back of the TV by the video inputs. Look for a port called "REMOTE CONTROL IN" or similar. It looks like a 3.5mm headphone jack. This port is used for external remote control and may be dirty.
UNPLUG the TV, then use a regular 3.5mm male headphone jack to plug in and out several times. You basically want to push all the way in and all the way out several times to dislodge any dust and remove any oxidation that has built up in the port. 10-15 times should do fine.
Then plug in the TV and try your remote.
Best of luck.
Nov 05, 2017 | LG 32LG30 32 in. LCD HDTV
I have a Panasonic WJ-HD36 video recorder in my building
frist cheak ip address, gateway,subnetmask then cheak your network connection
Mar 12, 2012 | Panasonic WJ-HD316/6500 Series 16 Channel...
When i power my moniter it shuts itself off in ten second by itself
Either your computer is sending a signal it doesn't support (too high resolution or refresh rate), or the monitor has power issues. Try starting the computer and going into the setup screen. If the monitor stays on, it's a resolution/refresh issue in the OS. If it doesn't stay on, it'll be cheaper to get a new monitor.
Jul 06, 2011 | HP Computers & Internet
The bike has power, but the turn signals don't turn on, it doesn't even acknowlegde that im pushing the indicator switches.
Contact me directly at wd4ity@bellsouth.net and I'll send you a trouble shooting guide for the turn signals. Don't forget to remind me of what you need.
Steve
Jun 28, 2011 | Harley Davidson XL 1200 C Sportster Custom...
How can I reset my password to WJ-HD500?
The default is 12345 you should be able to go to setup and enter a new code
Feb 21, 2011 | Panasonic WJ-HD500 Hard Disc Video...
The picture doesn`t fit the screen. Daewoo DWX-28W5GB telly
Sometimes the box that sends the signal to the TV preconditions the signal to 4x3 or 16x9, depending on the capability of the TV. I always opt to the "no fit" option and allow the intelligence of the TV to fit the screen.
If you have "off air" TV signal without that preconditioning, I cant help.
Oct 02, 2017 | Daewoo DTQ-20U9SC TV
Repair regulator in jeep 2001
Jeep 1999 at 2004 also called WJ model, in here you can find the information about window regulator:
- WJ 2000 Section-23-Body-ewj23S (page 40 and next)
- WJ 2000 Section-08s-Power-Window-Systems-Ewj8s
Good luck.
Sep 08, 2009 | 2001 Jeep Grand Cherokee
My turn signals and hazards are not working
Check your "flahsers" maybe need to change.
Also can review this document, in spanish but the graphics can help you:
- WJ-Cherokee-Service-Manual-PDF-08J-Sistema-de-Senales-de-Giro (Signals and Hazard Lights)
- WJ-Cherokee-Service-Manual-PDF-08W-Diagrama-de-Cableado (Wiriring Diagrams - 8W 52-1, page 303 and next)
Good luck (remember rated this help).
Aug 31, 2009 | 1999 Jeep Grand Cherokee
2002 wj jeep grand cherokee p1756
The governor pressure sensor is the most likley cause however an inspection of fluid or debris in trans pan would be a good idea to make sure there's nothing excessive in it. Attached is a list of possible causes however the senor would be the most common.
POSSIBLE CAUSES
  • Powertrain control module
  • 5 volt supply circuit open
  • Check transmission fluid level and condition
  • GOV press sensor signal circuit shorted to voltage
  • GOV press sensor signal circuit shorted to sensor ground
  • GOV press sensor signal circuit shorted to ground
  • GOV pressure sensor signal circuit open
  • Sensor ground circuit open
  • GOV press sensor signal circuit shorted to voltage inside transmission
  • 5 volt supply circuit open inside transmission
  • Intermittent governor pressure solenoid
  • Internal transmission problem
  • Oil burnt or oil pan has excessive debris
  • Other transmission DTC'S
  • GOV press sensor signal circuit shorted to sensor ground inside transmission
  • Valve body
  • GOV press sensor signal circuit shorted to ground inside transmission
  • GOV press sensor signal circuit open inside transmission
  • GOV press sensor ground circuit open inside transmission
  • Governor pressure sensor (high)
Mar 26, 2009 | 2000 Jeep Grand Cherokee
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
Electro Med Services...
