Question about Sylvania 6313CE 13 in. TV/VCR Combo
Dvd will not load
The tv works fine. the remote works fine. the dvd door opens and accepts dvd and closes and makes whirring noise. dvd does not play and have tried several.
  • sunruh May 23, 2008
    the tv is about 8 years old and both new and old dvds were tried
  • sunruh May 24, 2008
    I wanted advice not a question about old or new dvds. The dvd (old or new) will not load.
    Genius:
  • 3,422 Answers
HI,
Load a disc and listen.Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable.
Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word.
This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces.
You could try to clean the optics. This is the most common malfunction as far as i know in all disc players. It would involve taking the cover off and finding a way to expose the lense, and then cleaning it with a very gentle brush. some players have a cover for the lense that swings to the side during playing, this greatly reduces the chance of dust accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that guides the carriage of the laser pickup. Dirt, grome, dust and solidified lubricant can cause stoppage of the carriage and the laser eye then fails to read the next track.
If the problem does not get solved then you have to get it repaired.
Goodluck,
Please don't forget to rate the solution
Posted on May 24, 2008
  • Sylvania Master
  • 19,396 Answers
Sounds like it is a dirty lens problem. Try using a
CD/DVD Lens Cleaner,
if it does not work the unit should be opened, and the lens cleaned directly with isopropyl alcohol and cleaning solution.
  • Ginko
    Ginko May 24, 2008
    you can also blow some canned air toward the lens , if you gain access through the tray door
  • Ginko
    Ginko May 24, 2008
    First try a cleaning disk as suggested above, it is the easiest solution
    Here is how the inside should look like:
    You need to take apart the device and gain access to the lens pickup indicated in picture.
    Clean the lens using extra soft cotton , and isopropyl alcohol.
    If unit still does not read disks after thorough lens cleanup, then probably the lens is faulty. In this case lens pickup should be replaced.
    Sergeant:
    Champion:
  • 359 Answers
Try cleaning the lazer and failing this the lazer needs to be replaced, sorry
    Problem Solver:
  • 41 Answers
Here's some advice: your DVD player is broken. Buy a new one.
    Genius:
  • 3,587 Answers
Hmmm..is this a new issue? or has it worked prior to this?
Posted on May 23, 2008
  • Patrick Michaels
    Patrick Michaels May 23, 2008
    and how long you had the TV? and are these older or newer DVD's?
Why doesn't the open/close button on DVD player of DVD/VCR combo work?
Assuming there is not a forgotten tape stuck in the VCR side, the mode selection logic has gotten all confused. On the VCR side, a tape is grabbed and loaded to be played. There probably is an EJECT button that is enabled for later use. The DVD side is disabled so no buttons work. On the DVD side, the open/close button is enabled (if no VCR-side problem is detected), allowing you to place a DVD in the tray and close it to play. The VCR side is disabled so no buttons work. That's the theory. From your description a sensor on the VCR side may have failed or been damaged, causing the player to keep reverting to VCR and preventing use of the DVD side.
Sep 21, 2015 | Emerson EWD2204 DVD Player/VCR
I cannot play a dvd movie or record a tv program in ilo dvdr05 recorder, what might be the problem?
1: Get a movie and some popcorn.
2: Make sure the DVD player and the tv are turned on.
3: Push the button on either the front of the player or on the remote to open the player door to load the disc.
4. Put the disc on the tray that pops out
5. Push the same button pushed previously to close the door
6. Enjoy the movie
Jan 19, 2015 | iLO DVDR05 DVD Recorder
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
Purchased the DP300 at the Goodwill. The DVD has the remote control;however, I do not know how to use the remote control. I used the red, yellow, and white connector to my the DVD player and to the TV but...
with regard to using the remote control :
Make sure the batteries in the remote are working (they go in the back of the remote at the bottom).
Turn on the DVD player with the power button on the DP300 itself (lower left). Open the dvd tray either with the remote (press open/close button, upper right) or with the button on the DP300. Put a DVD in the tray and close it with the remote or the button on the DP300. The DVD should load.
Use the arrow buttons in the centre of the remote to select choices from the onscreen menu of the DVD. Press Play (centre of the 4 arrow buttons) to activate the choice you want. For example, if you want to play a movie, use the arrow buttons to go up or down until "play movie" is selected, then hit PLAY, and movie will play. If you want to choose a scene/chapter of the movie, use arrow buttons to go up or down until Scene Selection or Chapter is selected (highlighted), and press PLAY. This should bring up a list of the scenes or chapters. Use the arrow buttons to select the one you want, then hit PLAY, and that scene should play.
If the DVD tray is taking less than 20 seconds to operate, there is likely no problem. If it is taking more, there may be. I think the mechanism that opens and closes the tray is often the first thing to stop working on DVD and CD players.
Jul 20, 2011 | Norcent Technologies DP300 DVD Player
The tray on my DVD player won't open. When I press open/close, it just makes a whirring sound.
Failure of the loading mechanism, possible that the drive is struck or the belt is worn out ,. You will need to remove the tray mechanism to check and confirm. The motor seems to work as there is noise but the drive is not working , possible belt slipping or gear slipping.
Feb 21, 2011 | Televison & Video
How do I make player JVC XV-S300 region free.For years it worked fine,but all of a sudden it will not accept different codes. Please help, and many thanks!
hi,
Try the following to make your dvd player region free
1. Make sure there is no Disc in the tray.
2. Shut off the unit and unplug it from the AC outlet.
3. Press and Hold the "Play" and "Open/Close" keys, simultaneously on the player and not the remote control.
4. While holding these keys, plug the AC cord back into the outlet. (TEST and CPU ver# will appear on the display)
5. Release the "Play" and "Open/Close" keys.
6. Press DVD Menu twice on the remote.
7. When the display reads s000 5858 use the up and down buttons to change the 000 to 02E.
8. Using the Left and Right arrow buttons, change the last four digits until they read 0000 for Region Free, 0101 for Region 1, 0202 for Region 2 or 0404 for Region 4.
9. Press Enter on the player.
10. Press Standby and wait 5 seconds.
11. Press Standby again. Your player is now set to the region you requested. If you find some titles do not play on the region 0 setting, you may have to hard select the appropriate region.
ok
Feb 17, 2011 | JVC XV-S300 DVD Player
I have a dvd stuck in a toshiba tv dvd combination
Try a reset on ur tv,Like unplug ur tv an hoour.Replug it back.Should get power to the DVD port to take out the DVD disk.
Feb 08, 2010 | Toshiba 23HLV87 23 in. LCD Television
DVD won't play
get yourself a lazer cleaner and run that, it should work after that.
Apr 10, 2009 | Televison & Video
I need the universal code for my bush dvd player?
TRY THIS. It works on my Philips DVD player: To make some DVD players play disks from different regions. 1. Connect DVD to TV ensuring both are then switched on. 2. Press "OPEN/CLOSE" button on DVD player. 3. Enter "8421" using remote control. 4. While watching TV screen repeatedly press "Select" on remote control until region 9 is reached.  5. Press "OPEN/CLOSE".
Dec 18, 2008 | Televison & Video
Pioneer xv htd520 won't play dvds
This is a common problem for this model. It has a memory IC that must be replaced. This is a surface mounted IC that requires exceptional soldering skills to replace. I work at an authorized Pioneer service center and have repaired a good number of these for this exact problem. Unless you have great soldering skills it is not something that should be attempted to do yourself, it can cause permanent damage to the board if not done perfectly.
If you have the proper skills and soldering equipment I will be happy to give you the Pioneer part number so you can replace it yourself. If not, then you really should just take it to a service center and have a professional do this.
Let me know if you would like that part number.
Dave
Dec 12, 2008 | Pioneer XV-HTD520 Multi-disc DVD Player
Sylvania 6313CE 13 in. TV/VCR Combo Logo
143 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
