Question about Garden
I BOUGTH THE ROUTING POWDER AND I HAVE BEEN TRYING TO GET ROOTS ON THE STEMS.HOW THIS WORKS
  • 490 Answers
Ok, first thing; the rooting hormone powder is Very concentrated and should never be touched with your skin. Secondly, the cuttings need to be fresh cut or have been recently recut on the ends. If you are doing hardwood cuttings or green , the process is similar: Dip the fresh cut end lightly in the powder and place in the rooting medium ( this can be anything from warm sand to a peat mix). Your two enemies are rot from too much moisture and dryout failure from not enough. You can root green cuttings at room temperature, but hardwood cuttings do a little better if cooler. I do most of my rooting in my kitchen these days using a cold tea made from snips of willow branches. This has a ton of rooting hormone and is safer and cheaper (free) to use. I root most of my plants in water jars on the windowsill. Hope this is helpful,
Best regards, Farmerbear at FixYa.com
Oh, if you liked the advise, please vote lots of thumbs. And, If you didn't like it, I guess you'd better vote not so many thumbs:)
Posted on Sep 28, 2010
How to freeze beets
Bo, leave a 1/2" of stem and root to help prevent bleeding. Cook in boiling water until tender, beets 25 to 30 minutes, medium beets 45 to 50 minutes.
Cool immediately in cold water. Peel, remove stem and tap root, and cut into slices or cubes. Place in freezer bags,seal and freeze.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Freezing Beets from Your Garden at Home
Aug 04, 2016 | Cars & Trucks
Whats the root word of Is?
A root, or a root word, is a word that does not have a prefix (in front of the word) or a suffix (at the end of a word). The root word is the primary lexical unit of a word, and of a word family (root is then called base word), which carries the most significant aspects of semantic content and cannot be reduced into smaller constituents. Content words in nearly all languages contain, and may consist only of root morphemes. However, sometimes the term "root" is also used to describe the word minus its inflectional endings, but with its lexical endings in place. For example, chatters has the inflectional root or lemma chatter, but the lexical root chat. Inflectional roots are often called stems, and a root in the stricter sense may be thought of as a monomorphemic stem.
'is' is a root word. Can only be made smaller to 'I'. Can be made into is, this, isn't.
BBC Skillswise English
Mar 18, 2016 | Office Equipment & Supplies
Mesenchymal Stem Cells
Mesenchymal stem cells (MSCs) may make a few sorts of cells having a place with our skeletal tissues, for example, muscle, bone and fat. Researchers are exploring how Mesenchymal stem cells may be utilized to treat bone and ligament maladies.
Sep 23, 2014 | Health & Beauty
THE ROOT WORD FOR POSSIBLY
I believe that the root is latin - possiblis but might stem from other words.
Sep 11, 2014 | Vehicle Parts & Accessories
My willows r shedding and have a white powder substance on the branches what to do?
Not enough info. White powder could explain a scale or a fungus. Did you mean shedding? Willows prone to aphid. If these are the problem treat root system according to label with Merit (Bayer) also known as imidicloprid.
Jul 26, 2014 | Garden
Can i stem my hair after i week of relaxer?
yes u can , but i dont know what u mean by steam !!!!!!
from exsperiance u can curl or flat iron or wash and sit under the dryer
but i dont know what u mean by steam.
Nov 30, 2012 | Organic Root Stimulator Organic root...
No tire or tube on rim. where do I start for trying to put the new tube and tire on?
its somewhat hard to explain in words
check this video out
http://www.youtube.com/watch?v=u7KJK_rl9cU
also most bike stores will probably help you out for free
Nov 09, 2010 | Cycling
Cube root
http://answers.yahoo.com/question/index?qid=20071129202945AAOndt7
You can multiply a number by 1/3rd to get the cube root or
Under the MATH button, the fourth option down will give you cube root. Any n root beyond that will require the x^(1/n) method.
Feb 12, 2009 | Texas Instruments TI-83 Plus Calculator
LG LDF6920ST Bottom spray arm dose not work
The LG LDF6920 dishwasher has an innovative "Vario" motor/check valve. It switches between full power spray on the upper arms and the lower arm. So, if you are looking inside the dishwasher to see which arm is spinning, you just have not opened it when the lower arm is turning.
if the root problem is that your dishes are not getting clean with this water conserving DW, go out and buy a name brand detergent powder - like Electrosol or Cascade. And use less powder then you have been using.
Good Luck!
Feb 02, 2009 | LG LDF6920ST Stainless Steel 24 in....
Finean.exe error
make sure your SD card is not locked. Attempt to write a file to the card. If you cannot, move the switch on the side of the card. Otherwise, visit www.finean.com.
Oct 30, 2008 | Route 66 Route USA 2004 for Mac
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
