Question about Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator
Ice maker not making ice. Handle is in on position
Joe_Rex
  • 114 Answers
SOURCE: Ice Maker Won't Stop Making Ice
There is an adjustment for the "harvest" bar (The bar you lifted up). That bar you are lifting up tells the ice-maker that the cubes have fallen into the ice storage and starts the ice-making cycle over. It is also the Limit switch for the ice level in the storage container ... if it stays up for preset time determined by the manufacturer it stops making ice... most all ice-machines use the same devices. they vary little in design. Sometimes you can just gently bend the bar down to the point where it turns-off the machine at the level you want ... unless you can get to the adjustment hinge you can adust it there. For the fact it goes off when you lift it all the way up tells me the harvest switch is turning the ice-maker off.
Posted on Apr 29, 2007
fridgetech
  • 473 Answers
SOURCE: icemaker not making ice
First thing to check is to see if the optics are working properly. This is the red flashing light on right hand side of freezer wall. Close the flipper door, be sure not to block the beam, and the light should go to solid red. If it does then the optics are ok. If it continues to blink then that is your problem. If optics check ok then pull ice maker out and remove the white plastic cover. It just pulls off. Look at the center of the gear wheel and see if one of the plastic tabs is either broken or if they are sort of twisted and touching eachother. If any of these things with the gear have happened then that module will need to be replaced along with the ice maker thermostat. If your not sure how to replace these parts then just replace the whole ice maker. That is much easier and not much more costly.
After changing the parts or the ice maker out follow these steps to start the ice maker thru a cycle. 1. Remove the ice maker from the cradle but leave the harness connected. Remove the front cover from the module. Unplug the refrigerator. Get a small jumper wire with bare ends and jump T and H on the module, leave the jumper in and set the ice maker on the shelf. Close the door. Now plug the refer back in and wait 30 seconds. Open the door and the ice-maker should be cycling. Remove the jumper, put the module cover back on and set it back in the cradle. The fill should take place when the ejector blades reach the 12:00 position. Follow these steps exactly in order
Posted on Nov 10, 2007
SOURCE: ice maker quit
check water supply toice maker also check water inlet valve
Posted on Mar 06, 2008
  • 3422 Answers
SOURCE: ice maker doesn't work. changed filter. light on ice maker door still on.
Just check THIS link out.It will solve your problem.
From my side i believe it is the control board which has to be replaced and it will work again.
Goodluck..
Posted on Apr 05, 2008
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
Posted on Jul 31, 2008
My refrigerator will not make ice
Verify water line to ice maker is clear and on. Check ice cut off handle in down position. Frozen ice piece in extractor will also jam and not allow " flipper" to reset
Sep 13, 2015 | Refrigerators
Not making ice
make sure your waterline is not kinked or leaking. Otherwise no water will run through to your icemaker, and make sure your ice making handle is in ON position
Apr 10, 2014 | Kitchen Appliances - Others
KitchenAid KBFA25ERSS01 I replaced the water
if its computerized make sure someone didnt turn icemaker off check to make sure its in all the way
Oct 27, 2013 | KitchenAid KBFS25EVMS Stainless Steel...
We emptied all of the ice out of our fridge and now after leaving the ice maker handle to the 'make ice" position, nothng is happening
I would try flipping that handle up and down a few more times...
but here is a tip that will give some other things to try also..
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Aug 22, 2010 | Frigidaire FRS23KF7AB Side by Side...
The ice tray is not producing ice and we have the handle up. I think the ice makeer has frozen itself over. Can the ice make be removed or thawed out without unplugging the whole fridge?
the handle needs to be in the down posit. ans if up it shuts the ice maker off. .. you can defrost the ice mker with a turkey baster & hot water . use towel under icemker .. mm
Aug 10, 2010 | Jenn-Air JFC2089HP Bottom Freezer French...
The ice maker constantly making ice
the icemaker is bad and needs to be replaced
Jun 02, 2010 | Refrigerators
The ice maker will not stop making ice even with wire handle in up position
Good day,
The wire, if inserted properly, breaks an electrical circuit, when it is in the up position.
The bad news, is the end of the wire I described is inserted into what is best described as a semi-solid state board.
This board or front end as it is often called, can be replaced, but it's cost is so close to the price of a complete ice maker that most people opt for the complete.
But you have the choice.
To replace the front end, remove the ice maker from the machine. pull the wire going into the front of the ice maker out.
Unsnap the plastic front cover, remove the wire power plug, then
remove the screws holding the front end on, and pull out.
Install in reverse order.
It, like the ice maker are very common parts, and any appliance parts house will have them in stock.
Thank you for using FixYa
Jan 16, 2010 | Whirlpool Refrigerators
Ice maker arm in freezer
On most automatic ice makers the arm is in the up position to make ice, but check with the manufacture to make sure
Jul 20, 2009 | Amana ABB1927DE Bottom Freezer...
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
Kenmore Frig 59658692890
ok there's a handle in the ice maker 1 position turns it on another turns it off just do that and the ice should stop coming down if it dosent just remove the water connection to it
Apr 07, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Open Questions:
Jenn-Air JBR2088HES Stainless Steel Bottom Freezer Refrigerator Logo
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
