Question about Canon PC-940 Black and White Copier
I want a service manual for my canon pc940 copier
Just installed a new cartridge. Made one copy. worked great.
Went to make a copy today. All Black. Thought about it. Tried again and noticed lamp was not lighting. Before you say DUH! is the lamp out or is their extenuating circumstances preventing the lamp from lighting during a copy. The table top moves and everything else seems to work accordingly.
Posted on Oct 21, 2010
  • 6 Answers
SOURCE: Canon PC940 copier
check the operations panel on/off switch.
Can be a problem on this type of machine.
Posted on Jan 30, 2008
  • 117 Answers
SOURCE: EO10 CANON PC940?
E010 is a code indicating main motor failure.In actuality it rarely fails.look for a broken belt or gear in the Main Motor train.Good Luck
Posted on Apr 02, 2009
  • 1126 Answers
SOURCE: Copier making loud noise
Remove the drum/toner unit and close the top,...does it still make the noise? If so, there is a paper jam in the fuser section (left side)
I also have a Canon PC900 series copier....mine does not have the automatic document feeder, however the machine is the same....If the noise persists, you will probably need to replace the Fixing (fuser) Unit drive gears (worst case senerio) perhaps you can locate the jam in the fuser and "carefully" remove without damaging the Fixing Belt....good luck
Posted on Jul 04, 2009
n25an
  • 622 Answers
SOURCE: canon pc940 error code e261
try turning the machine off and then on...you either had a power surge and it freaked out your machine or the fuser is shot...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Posted on Dec 17, 2009
muleskinner2
  • 270 Answers
SOURCE: how do you change the
You have to replace the whole toner/drum unit cartridge. There is handle on the left side. Release this and then the whole reader section of the copier will move left. Raise the right side cover asnd below this is the drum cartridge. Gently lift out and replace it with a new one.
Posted on Jun 15, 2011
Start button for canon pc940
I also am having this problem...but the system tray disapears almost like someone took some scissors and cut it out..and all my icons slide under the startbutton. but whatever programs that are unminamized i can still use..but thats all
Mar 19, 2014 | Canon Pc940 Alog Copier 13cpm 0008a040
Trying to find a manual for a canon pc940
http://www.devicemanuals.com/guide/Copier/Canon/Canon-Personal-Copier-PC940-User-Guide-TkRFd01URT.html
Jan 01, 2011 | Office Equipment & Supplies
Canon pc940 error code e261
Dec 17, 2009 | Canon PC-940 Black and White Copier
Canon pc940 won't turn on
power fuse blown on power supply board ,replace it.
Dec 10, 2008 | Canon PC-940 Black and White Copier
Canon PC940 Ticking noise when copying and regestration is off
The waste toner is in the drum unit it's self. If it full you may as well replace the drum unit all togather. Once it is full the drum is just about shoot. If the regestration is off, you may have a problem withe reg. feed clutch. Dose it show up with the paper tray and the manual feed try?
Nov 15, 2008 | Canon PC-940 Black and White Copier
Canon PC940 Problem
You could have a broken exposure lamp. Does the scan bar light up when you make a copy? If not that is the problem. You might also ck the contacts on the machine where they touch the toner cartridge. The toner cartridge opens a shutter to the drum when you slid it into the machine and that may be broken.
Feb 11, 2008 | Canon PC-940 Black and White Copier
Canon PC940 copier
Jan 30, 2008 | Canon PC-940 Black and White Copier
Cannon copier pc940 paper jam
canon i960 -three flashing orange lights (paper jam error) but no paper is jammed. The print cartridge1.gif will not slide to center either-- I have tried to get the printer into service mode, but cannot get there because the orange lights never stop flashing.
Dec 06, 2007 | Cannon Canon i960 Photo Printer
Canon PC-940 Black and White Copier Logo
756 people viewed this question
old marine
old marine
