Question about Splendide 2100 Vented Washer-Dryer
I have a splendide 2100 vented washer-dryer it will not drain. i hear a click but no results.
  • Splendide Master
  • 17,130 Answers
If you measure the voltage on the drain valve/pump and find that the voltage is good, the pump can be stuck( it can be warm without working) If so remove and clean dirt accumulated ,test it on the bench.
If there is no voltage then the program controller is defective and must be checked for the loss of trigger voltage to power the valve/pump.
Posted on Sep 27, 2010
  • Pam Batson
    Pam Batson Jul 06, 2014
    It washed the clothes but the water will not go out the door lock button is blinking.
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Clicking noise in splendid dryer
We did not get a book. It washed the clothes BUT water still in washer. we don't no how to put it on to dry the clothes?
Mar 05, 2014 | Splendide 2100 Vented Washer-Dryer
Where can I find parts for the Splendite Washer/Dryer unit model WD2100
westland sales splendide parts ordering and tech support 800 356-0766
Mar 13, 2010 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Sep 19, 2009 | Splendide 2100 Vented Washer-Dryer
Indesit washer dryer, washer is fine, but dryer does not heat up
If you don't hear the fan running then the fan motor has gone bad. If the fan motor is bad then most likely your element has burned out. If you hear the fan motor than probably your element has gone bad..
Jul 29, 2009 | Splendide 2100 Vented Washer-Dryer
Hose replacement
yes , I recommend stainless hoses because they will not break.
Phil
Jun 10, 2009 | Splendide 2100 Vented Washer-Dryer
Doesn't completely dry clothing
Make sure lint filter is clean and vent pipe and outlet are not clogged.  If the clothes are getting warm then the element is working.
May 30, 2009 | Splendide 2100 Vented Washer-Dryer
Broken door handle on Splendid 2100 RV Washer/Dryer Combo
The Splendide distributor in OR sells handles for about $45.
Jan 27, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2100 Vented Washer-Dryer Logo
281 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
