Question about HP Photosmart D5360 Printer
I have just loaded both color and black cartridges into my HP photosmart D5360 and the ! buttong and On/off button are flashing. The message on the printer screen is "Print cartridge(s) missing or not detected. I have tried unplugging my machine, removing and reinstalling with no luck. ANy help?
  • HP Master
  • 17,130 Answers
Remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can also be poor ink cartridge contacts
Posted on Sep 27, 2010
Error message "to print in color, install the following cartridges:" continually comes up after installing new cartridge.
on ours the cartridges click twice to be fully seated..there are 4 cartridges in this one.. if one is not all the way down, it will error..in extreme cases if all the cartridges are in place..unplug the unit and reboot it..
Jan 19, 2014 | HP Photosmart C6180 All-In-One InkJet...
Error: 0xc18a0106
replace the print head unit not the cartridge.
Jun 17, 2012 | HP Photosmart C7180 All-In-One InkJet...
How do I install printer cartridge on photosmart D5360
Click the link below and it will show how to install the printer cartridge and also it has a picture on every steps.
https://h10025.www1.hp.com/ewfrf/wc/document?docname=c01112512&tmp_task=setupCategory&lc=en&dlc=en&cc=us&product=3434581
Hope this helps. Rate if it works. Thanks
Apr 28, 2011 | HP Photosmart D5360 Printer
My hp d5360 printer is saying print cartrdge(s) missing or not detected.
You should try to verify if the cartridge is correctly put on the bay. If this not work you can try to clean the metal plates with a sheet of white paper and alcohol.
Mar 08, 2011 | HP Photosmart D5360 InkJet Printer
Cartridge jam message. cartridge seems to be working but at the end of the self-test it reports the same message. Cartridge is free and clear as far as I can see.
$12.99 - money back guaranteed if you are not satisfied! Get timely email assistance from me.
Receive as many solutions as you need.
Nov 16, 2009 | HP Photosmart D5360 InkJet Printer
HP D5360 "print cartridge missing or not detected" message
You may have a defective cartridge. I'd take them back to where you bought them for an exchange.
Sep 12, 2017 | HP Photosmart D5360 InkJet Printer
I buy until now 5 hp351 colorcartridge, after few days is "dead"
Sounds like the problem is that you are refilling the cartridges. Each HP cartridge has a special chip on it that will only read the original ink supply properly. Try a brand new cartridge that has never been refilled and see if that makes a difference.
Jul 26, 2009 | HP Photosmart D5360 InkJet Printer
D5360 Printer Flashes "Print cartidge(s) missing/not detected."
These Steps should get you pointed in the right direction....
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458297&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Copy and paste in your browser ...
May 21, 2009 | HP Hewlett-Packard D5360 Photosmart Inkjet...
How do I install ink cartridge for hp photosmart C4280
To replace the print cartridges
1. Make sure the HP All-in-One is on.
CAUTION: If the HP All-in-One is off when you open the print cartridge door to
access the print cartridges, the HP All-in-One will not release the cartridges for
changing. You might damage the HP All-in-One if the print cartridges are not
docked safely when you try to remove them.
2. Make sure you have letter or A4 unused plain white paper loaded in the input tray.
3. Open the print cartridge door.
The print carriage moves to the far right side of the HP All-in-One.
4. Wait until the print carriage is idle and silent, and then lightly press down on a print
cartridge to release it.
If you are replacing the tri-color print cartridge, remove the print cartridge from the
slot on the left.
If you are replacing the black or photo print cartridge, remove the print cartridge from
the slot on the right.
1 Print cartridge slot for the tri-color print cartridge
2 Print cartridge slot for the black and photo print cartridges
5. Pull the print cartridge toward you out of its slot.
6. If you are removing the black print cartridge in order to install the photo print cartridge,store the black print cartridge in the print cartridge protector or an airtight plastic container.
7. Remove the new print cartridge from its packaging and, being careful to touch only
the black plastic, gently remove the plastic tape by using the pink pull tab.
1 Copper-colored contacts
2 Plastic tape with pink pull tab (must be removed before installing)
3 Ink nozzles under tape
CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching
these parts can result in clogs, ink failure, and bad electrical connections.
8. Slide the new print cartridge forward into the empty slot. Then gently push the upper
part of the print cartridge forward until it clicks into the socket.
If you are installing the tri-color print cartridge, slide it into the left slot.
If you are installing a black or photo print cartridge, slide it into the right slot.
Work with print cartridges 69
Maintain the HP All-in-One
9. Close the print cartridge door.
If you installed a new print cartridge, the HP All-in-One prints a print cartridge
alignment page.
10. When prompted, ensure plain white paper is loaded in the input tray, then press the
button next to OK.
NOTE: If you have colored paper loaded in the input tray when you align the print
cartridges, the alignment will fail. Load unused plain white paper into the input
tray, and then try the alignment again.
11. Place the page print side down on the scanner glass and then press the button next
to OK to scan the page.
When the On
Please Don't forget to rate this solution. Thanks.
Feb 17, 2009 | HP Photosmart C4280 Aio Printer
HP Photosmart D5360 Printer Logo
222 people viewed this question
Seeker5211
Seeker5211
