Question about Microwave Ovens
Table will not rotate - Microwave Ovens
  • Microwave Ovens Master
  • 17,130 Answers
Possible that the belt has broken or damaged, or the motor drive/motor is faulty.
remove the back cover and chek to get access, if motor voltage is not present check the program controller driver to the motor./ the trigger signal to the drive.
Posted on Sep 27, 2010
Testimonial: "great help thanks"
My Bosch innowave has stopped rotating!
Check the voltage on the table motor. Basically if the wiring is intact, the problem will be the table motor. Not uncommon for them to fail.
Dec 07, 2014 | Bosch Microwave Ovens
Why
The table motor belt may have detached which stops table from rotating and the magnetron control shuts off the heating if table does not move. Need model number etc for the microwave. It is not recommended to open the units unless you are qualified technician or understand the operation of the microwave oven. The voltages and waves can harm human body.
Sep 02, 2014 | Kenmore Microwave Ovens
Sharp r-1850a turntable problems
turntable motor p/n 46-841666-3, available from searspartsdirect.com, use correct model #!!
Feb 09, 2013 | Sharp R-1850A Convection/Microwave Oven
GE Microwave model hvm1750sm1ss table wont rotate
The turntable motor has seized up, the only solution is replacement.
Jun 15, 2012 | GE Microwave Ovens
My daughter just moved into a townhouse and the microwave plate warms, however the plate doesn't rotate. Is there any easy way of fixing this issue
The rotating table in a microwave shouldn't be getting warm unless something is sitting on it and transferring heat to it. The chamber should not be left empty when the microwave is running. The motor that drives the table is of very low mechanical power but should be able to handle about any load it must. I suggest you remove the glass table, the ring on which it rides, put a cup of water in the chamber and turn it on. Look at the drive spindle that engages with the table when installed. If it isn't rotating 9should be easy to see) then the motor is defective which is highly unusual to see one fail. If the spindle is clearly not moving, then I recommend replacing the whole unit since while the part isn't expensive, the labor cost would likely make the repair uneconomical.
Dec 22, 2010 | GE Microwave Ovens
I have an Emerson (2 weeks old). It heats well but there is a thumping noise when the table rotates and sometimes the table will operate with a jerking motion.
It sounds like the table is'nt positioned properly on the base it sits on, most are not attached and can be easily removed for cleaning purposes, try repositioning the table on the base.
Mar 10, 2009 | Microwave Ovens
My convection/microwave quit rotating.
Hello Tina,
Usually those turn tables(or lazy Susan's colloquially) are driven by a small motor. The motor attaches to a gear or spindle which transfer the rotational energy to the turn table. A plastic gear may have been broken or popped loose. It might also use a belt to transfer the energy, the belt could have worn and is now slipping which would cause the table to stay stationary.
Aug 10, 2017 | Sharp R-370E 1000 Watts Microwave Oven
Kenmore microwave 721.80803401 rotating table pops up and stops turning.
I would bet the arm ("ring assembly") is either worn or warped from heat? and is not meshing well with the motor shaft or glass tray.
That is part number 4351W1A003A and you can get it for only $6.30 (compared to over sixteen via Sears) from Tritronics.
The motor is part # 6549W1S018C and if it's the culprit, you can get that for $24.84 from Tritronics, compared to almost thirty-two from Sears.
You should look again and see how loose the arm is on the shaft and which might be worn or warped or out of perpendicular. I think that one of these is the problem.
Dec 21, 2008 | Microwave Ovens
Microwave rotating assembly jumps up and stops turning.
Sharpe microwave,turntable sticking.
Remove the turn table and clean the rotating circle with the cleaning solvent and the read the instruction manual for avoiding over loading of the table.
Thanks
Jan 23, 2008 | Microwave Ovens
Microwave Ovens Logo
52 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
