Question about Jcb Refrigerators
Drive problem i have a loadall telehandler wen it gets hot it loses drive we have changed tourqe converter ,clutch pack and new pistons in the pump and it is still the same
  • 828 Answers
Posted in wrong category!
Posted on May 23, 2008
When my automatic changes from 3rd to 4th gear their is a shudder between the gears prior to the change, if I go slow it changes their is no shudder
Could be a number of things, dirty fluids,solenoid packs or sensors bad worn clutches converter, thrust plates piston or pistons bad in the gear clutch plate housing ,i would start with the simple fluid change first.
Nov 02, 2015 | 2004 Porsche Cayenne
Torque converter clutch
It should be attached to transmission block, I will see if I find a diagram.
May 29, 2008 | 2001 Nissan Altima
PLEASE HELP!!!! 93 ford crown victoria wont accelerate in gear after a while driving in hot weather
The problem is with your transmission It's getting hot and not engaging Check the tranny cooler as well
Apr 08, 2014 | Cars & Trucks
May be I have to make my problem clear. The car goes ok when I drive it on plain roads. But moment comes to up hilly roads car loses power and almost stall. it makes only very tardy slow move up hill.
not getting enough back pressure in the exhaust system. weak or lose of power can be caused by this. usually middle box. if you hit it and it rattles thats were your problem is. also can be piston rings falling under pressure.
Oct 11, 2013 | 2008 Toyota Yaris 1.0
2001 chevy s10 loses power, will not stall, restart runs better.
SOUND LIKE ENGINE GETTING TOO HOT.THAT WILL CAUSE LOST OF POWER.CHECK COOLING CLUTCH FAN IF IT HAS RESISTANCE WHEN ENGINE HOT FAN CLUTCH IS GOOD.IF FAN CLUTCH FREE WHEELS WITH NO RESISTANCE WHEN ENGINE HOT.FAN CLUTCH IS BAD.THAT WILL CAUSE ENGINE TO RUN HOT WHILE DRIVING.
Jul 23, 2010 | 2001 Chevrolet S-10
The tranny well not engage in drive or reverce
did you change tourqe converter sounds like bad tourqe converter or u dont have enough trany fuild in it
Feb 17, 2010 | 1992 Jeep Cherokee Sport
Please help
i dowt it it sounds like you got a bad tranny probably not the tourqe converter
Sep 30, 2008 | 1990 Chevrolet S-10 Blazer
1986 dodge ram 150 tranny problem
Sorry this is not an easy fix the clutch packs in the transmission are slipping, usually caused by wear, but the hydraulic pump is probably getting week. As the oil warms up the oil gets thinner and the hydraulic pressure decreases. Times for a overhaul of the transmission, and if the torque converter can not be flushed a new torque converter is recommended. You may get lucky buy changing the fluid several times, but if the transmission is 22 years old it may not help.
Aug 09, 2008 | Dodge Ram 150 Cars & Trucks
Refrigerators Logo
331 people viewed this question
Top Jcb Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Jcb Refrigerator Expert? Answer questions, earn points and help others
