Question about Nextar MA566 MP3 Player
Nextar mp3 NA566 2GB
Is there any special button you can press to reset the whole mp3?
    Problem Solver:
  • 5 Answers
Im sorry but im pritty sure there isnt sorry!!!!Nextar mp3 NA566 2GB - 374beab.jpg
Posted on Jun 07, 2008
How do i turn it on
Please check if there is a reset button on the player. Press and hold to reset.
Jan 10, 2012 | Nextar MA933A MP3 Player
Mp3 player will not let me listen to music
look for a small pinhole on the device, and use a paperclip or needle to press the reset button inside the device.
doing this should reset the device and fix your problems
Jul 31, 2010 | Nextar MA58820BL MP3 Player
Can u help me to deleting everything on my MP3 player. All the files r corrupt. Doesn't allow me to delete or add music. Has these stange language or symbols that arn't deletable? Is there a way to reset...
Hi, follow the instructions below to reset your Nextar mp3 player
To customize the player settings:
(1) On the main menu, select the “Settings”item and press the MENU button to enter the
system settings mode.
(2) Press the PREVIOUS/NEXT button to select setting item and press the MENU button to
confirm or press the PLAY/PAUSE button to cancel/return.
(3) System
(4) Load Default - Restore the player to default setting
Take care
Feb 18, 2010 | Nextar MA797-20 MP3 Player
The ma933a nextar model skips over songs every 10 secs!
you have the play mode set to "intro",
how to solve this;
1) start playing a song.
2)Press the "Mode" button quickly, don't hold it down, just press it quick.
3)Select Play Mode by pressing the Mode button
4)Select "N" normal
all done.
Nov 14, 2009 | Nextar MA933A MP3 Player
Nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Nov 04, 2009 | Audio Players & Recorders
I got a Nextar MP3 player model #MA797-801, but it doens't work on my Windows Vista, but it should. I'd plug it into my computer to charge, but it hasn't, but I was able to put music on it. However, the...
I have the same model - you have to press and hold the Play/Pause button (the button to the left of the 4-way button) until the unit turns on.
It took me awhile to figure it out.
Jul 10, 2009 | Nextar Audio Players & Recorders
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
MY NEXTAR MA9336A1S IS STUCK ON THE NEXTAR SCREEN
Since the operating system and navigation software are preloaded into the internal flash memory of the GPS, the freezing may either be software or hardware failure. First, press the "Reset" button or push the stylus into the "Reset" hole, to see if the navigation software can load successfully. If the program still does not load, then the software may be corrupted. Also, if the internal memory fails to read or write and the software cannot load properly, it may be caused by hardware failure. In either case, please return the unit for exchange or repair to the retail location from which you purchased it, or contact us for further assistance.
Apr 06, 2008 | Nextar MA933A MP3 Player
Mp3
hold and press the play/pause button on the front for 1.5sec then release
Dec 20, 2007 | Nextar MA933A MP3 Player
Nextar MA566 MP3 Player Logo
187 people viewed this question
Top Nextar Audio Players & Recorders Experts
Robert Graf
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
