Question about D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch
I have two des-1005d network switches. i want to communicate betwwen them with a cat5e cable. the cable is made as cross through and distance is about 70 meters. with one switch pc is connected and at other end ADSL modem is connected. Now led indicator of both switches is blinking with about 1 to 2 sec interval and there is no communication. BUT if we reduce cable length b/w two switches, everything gets normal either with cross or straight through cable. please guide me about this problem. thanks and regards Muhammad Jamil Awan
    Problem Solver:
  • 17 Answers
Max distance for Cat5e cable is about 100M, but that is the best case scenario, essentially a straight line, down a building. If you have any kind of interference, like flourescent lighting, high voltage lines running parallel to the ethernet cable, the distance will be much less than 100M. Although it looks like you have 60 feet to spare, anything interfering with the cables will cut the signal down. Try to move the switches closer together, make the cable from pc to switch longer and ADSL modem to switch longer and cable between switches shorter. Use a known good straight through ethernet cable, as modern switches don't require crossover cables.
From Wikipedia: http://en.wikipedia.org/wiki/Category_5e#Maximum_cable_segment_length
According to the ANSI/TIA/EIA standard for category 5e cable, (TIA/EIA 568-5-A[5]) the maximum length for a cable segment is 100 meters (328 feet). If longer runs are required, the use of active hardware such as a repeater, or a switch, is necessary.[6] [7] This 100 meter limit is all inclusive. According to some authors,[who?] the practical limit for permanently installed cable is about 90 meters, leaving 5 meters at each end for the patch cables that connect the end equipment to the wall panel.
Hope this helps.
Posted on Jan 10, 2011
How to connect des-1005d
The new model. Just plug it in. No configurations. Any port for any use. The selling point is unmanaged. Look for the problem somewhere else (including the cables) till you are sure it's the switch. Then it needs to be replace.
http://files.dlink.com.au/Products/DES-1005D/Datasheet/DES-1005D_N1_Datasheet_11.pdf
The older model uses standard cabling practices, but still very versatile.
http://www.dlink.com/uk/en/support/product/-/media/Consumer_Products/DES/DES%201005D/Manual/DES%201005D_Manual_v02_EN_UK.pdf
Oct 25, 2012 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Tip
Trying to connect 3 pc to a dlink switch
I have an internet connection at home which 512 Mbps. I have bought Dlink Switch DES-1005d. I have 3 pc at home. I want to share the internet connection among the three pc. I have tried just by connecting the pc with CAT5 cables. I just have the received packet and then I do not have internet connection at all. Please can someone help me?
Thanks in advance for your help.
Best Regards
Jerman
on Mar 28, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
DES-1005D switch - I need to know the MAC address. How can I find it ?
usually it will be the serial number of most devices as it is unique. but if not try angry ip scanner, it should detect the ip and mac when you do a scan.
http://www.angryip.org/old/ipscan/
Apr 22, 2011 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
I have d-link des 1005d and i have ps3 and pc . i have Motorola modem sb5101 .. i want get connected both ps3 and pc at same time will u plz tell me how i will set up tks
You should use a router instead of a switch...however if you still want to use the switch, request your service provider to provide two ip addresses, instead of regularly just one...but you mostly like need to pay monthly the extra ip address...alternatively ask your service provider to upgrade your cable modem to cable modem with router capability, ...
Apr 12, 2011 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D-Link DES 1005D
set u r borad band router/modem to dhcp and set both system to auto detect ip address put u r boradband ethernet cable to hub and both pc in same hub that it nothing to do with configure  enjoy!!! need help for router/mode to configure tell me the model number i will tell step by step
Oct 18, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
D link des-1005d
do a factory reset. see if that helps. Check IP mapping, make sure the two PCs are on different IPs
Aug 14, 2008 | D-Link DES 1005D (DES-1005D) 5x10/100 Mbps...
Faillure connection
Hi
I think in cable is faulty, when conneting to pc to switch, cables as to straight cables, pls cross check the cable..
Jun 03, 2008 | Computers & Internet
D-Link DES 1005D (DES-1005D) 5x10/100 Mbps Networking Switch Logo
274 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
