Question about Optoma EP716 Multimedia Projector
Optoma Power Problem
I have the same power problem you had and I have my projector torn apart but I can't seem to find the fuse. Can you give me some idea as to where it is and a better description of it? Also where did you find a replacement from? Any help would be appreciated,
John Jones
  • c_heastan Dec 11, 2008
    What does the fuse looke like?
WAT DOES THE FUSE LOOK LIKE
ANY PICTURES?
Posted on May 27, 2008
  • 563 Answers
Hi Jjonesiii
The fuse will be on the Powersupply Board ( the one with the AC socket in it )
I bought the fuse from our local harware shop.
Posted on May 26, 2008
Where are the fuses located on the Optoma EP1691 projector?
A majority of it is located within its power supply (located near the power socket).
Sep 06, 2015 | Optoma Office Equipment & Supplies
Optoma EP719 Projector "Pulse"
It is one of the fan, it is bent or out of place and cause reptead disturbance at cyclic intervals. The projector must be taken apart and examined on the inside
Jul 22, 2008 | Optoma EP719 XGA DLP PROJECTOR 2000L...
Optoma h79 wont power up is there a fuse to replace if so where is it thanks
hi,
All electronic equipments have fuse in the power supply section.
In your projector it is inside the unit. The fuse of projectors will blows only if there is any trouble in the power supply. Just try to replace the fuse in the power supply board. It will be near the input connector. If the fuse again blews then you have to replace the power supply board. Because the components in a projector power supply is rearly available. You will not be able to access the fuse with out oppening the projector.
OK
Oct 08, 2011 | Optoma H79 Multimedia Projector
Blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Dec 22, 2009 | Optoma HD80 Projector
EP716 Optoma Projector Fuse
There is no fuse. I took my EP 716 apart to find out why it died. I found a resistor had blown on the power board made by the Tiwan co. Quazarpower.
Dec 11, 2008 | Optoma EP716 Multimedia Projector
Power for optoma ep 716
TAKE TO THE AUTHORIZED SERVICE CENTER OF OPTOMA
WANT ADDRESS goTHROUGH WWW.OPTOMA.COM
Nov 11, 2008 | Optoma EP716 Multimedia Projector
Optoma EP 738
You can test the power source if you are getting any power input from the power cord itself. Plug in your power cord and use an eletronic meter on the other end to see if you are getting the proper voltage (110/120) reading. If not, then the power cable is bad in itself. IF you are getting power from your cord, it could also be a fuse inside the Optoma and/or where the power plug on the Optoma meets the actual power source is out of alignment or may also be not making the proper contact to the main circuit board on the Optoma. Hope it helps....JGUAM
Jan 28, 2008 | Optoma EP716 Multimedia Projector
EP 757 Intermittent powering down
Pls check if the lamp is not so old that is giving the same problem. If lamp is almost new, then you can have a check with the Ballast unit card and then the loose connection in the Power supply or may be overheating and tripping.
Viren
Nov 18, 2007 | Optoma EP737 - DLP PROJECTOR - 1500 LUMENS...
Optoma EP716 Multimedia Projector Logo
505 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
