Question about Kenmore Kitchen Ranges
I have a Kenmore range Model # C970-652521. 5 Years old. The problem is somehow the heat indicator has switched from fahrenheit to celsius and I would like to switch it back. Can someone explain how I can do this?
SOURCE: Switch from Celsius to Fahrenheit Temperature setting
200 degrees celsius is ? degrees Fahrenheit?
Posted on May 13, 2008
SOURCE: Celsius to Fahrenheit
In order to change the temp setting from C to F, Press cancel & bake together for 5 seconds then use the more or less pads to change.
Posted on Jan 22, 2009
SOURCE: I need to change my Maytag oven from celsius to fahrenheit.
should say how in the owners manual.
Posted on Oct 09, 2009
Press cancel and bake buttons simultaneously for 3-5 seconds until C appears then use up/down buttons to change to Fahrenheit. Hope this helps!
Posted on Mar 10, 2010
I had the same problem, after multiple calls to maytag I finally rec'd an answer. I feel your frustration, didn't need a service call for this.
On my model hold down the keep warm and cancel button for 3 seconds and it will change it.
Hope this helps!
Posted on Mar 22, 2010
I have an inglis range model IRE3230, how do I switch it from celcius?
The temperature is preset at Fahrenheit, but can be changed to
Celsius on some models.
To Change: Press and hold CUSTOM BROIL for 5 seconds. A
tone will sound, and "°C" will appear on the display. Repeat to
change back to Fahrenheit. To exit mode, press OFF/CANCEL
Inglis Range Use And Care Manual Clock Tones Fahrenheit And Celsius Timer
Dec 01, 2015 | Kitchen Ranges
How do I change the baking degrees on my whirlpool accubake range from Celsius to Fahrenheit?
You can just convert from Celsius to Fahrenheit yourself by going to this site. http://www.metric-conversions.org/temperature/celsius-to-fahrenheit.htm. Just type in the Celsius and it will convert automatically. And, it's fun to learn how to do it yourself. O.k, don't want to do that? You don't say if your oven is electric or gas or what the model is. Check this website and I hope it helps:
http://www.manualslib.com/brand/whirlpool/oven.html
Good luck
Apr 10, 2015 | Whirlpool Kitchen Ranges
Sub zero FREEZER temperature display is all of a sudden -22 in lieu of the usual -5. is it possible that somehow it has switched to celsius? if so, how do I change it back to farenheit? Model 601F/F
These instruction are from the site below:
To convert the temperatures from Fahrenheit (°F) to Celsius (°C) readings:
  • Turn the unit off then back on again using the unit on/off button.
  • Within one minute of turning the unit back on, press and hold the door ajar alarm bell ON/OFF key and the UNIT ON/OFF key simultaneously for 5 seconds.
  • Release the keys and "°C" will appear on the LCD indicating that temperatures will now be displayed in Celsius units of measure.
  • To convert back to Fahrenheit units of measure, repeat the steps above. "°F" displayed will confirm Fahrenheit units of measure.
  • Refer to the product use and care guide for further information.
  • Note:
    • Temperature Units Selection must be performed within the first minute after switching the unit ON.
    • Model 427R will require temperature conversion for both the upper wine storage zone and the refrigerator drawers separately.
Without a bell on / off button on the control panel, it is not possible to change the temperature display.
400 600 700 Series Temperature Conversion
Jan 29, 2015 | Refrigerators
How do I change the oven temp from celcius to farenheiton my Maytag Advanced System Model #MGR5710ADW
try unplugging range. If it does not return to F display
You can try this: Hold either timer keys down on power up. The right digit will display "F" or "C". The temperature display can be toggled from C to F by pushing the Broil key.
or
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4SP964
Read more: http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/66531-switch-celsius-fahrenheit.html#ixzz37a4C5UH2
Jul 15, 2014 | Whirlpool Gold GW399LXU Gas Range
How do I change temperature back to Fahrenheit?
Simple, Press and hold "Broil" for 5 seconds. It doesn't mean there is anything wrong with it.
Dec 06, 2011 | Kitchen Ranges
Can't set temps above 260 degrees
check in your owner's manual for the section on setting your control to fahrenheit or celsius. Then check to see if your control is set to celsius.
May 20, 2010 | Whirlpool Kitchen Ranges
Range got switched to "Celsius", how can we get it back to "Farenhight"
If the model number is correct, to change from Celsius to Fahrenheit (and vice-versa) follow these steps:
1. Press and hold the AUTO/CLEAN button for 5 seconds and TEMPERATURE UNIT FAHRENHEIT should appear.
2. Press OFF/CANCEL to exit mode.
Repeat the same steps if you ever wish to change back to Celsius.
These instructions are printed on page 11 of your owner's manual. If you cannot find your copy, go to managemylife.com and type in your model number under the "Manuals" link. Your installation and owner's manuals are available in .pdf (Adobe) format that you can download or print for FREE.
If this is not your model number, please post back and let me know. I hope this helps you.
Mar 05, 2010 | Whirlpool GR448LXPQ Electric Kitchen Range
Hope this helps!
Oct 09, 2009 | Maytag Admiral LER3330AAW / LER3330AAZ /...
Feb 10, 2008 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
65 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
