It says there's a paper misdeed r2-4. We've pulled put each part and there's no paper in there. Turned it off, and still says the same thing.
  • 182 Answers
Well Check for any paper or objects that might be stopping the carriage.
If the paper tears when you remove it from the rollers, check the rollers and wheels for torn pieces of paper that might remain inside the product. If pieces of paper remain in the product, more paper jams can occur.
Reach inside the product, and then manually move the carriage.
The problem could also e due to Cartridges so Make sure that the cartridges are installed correctly
Step one: Remove the cartridges (Slide the cartridge out of the carriage.)
Step two: Reinstall the cartridges(Slide the cartridge into its slot, and then press it toward the back of the product until it locks into place.)
The problem can also be due to clutch so Adjust the clutch on the printer/FAx All in One
If this does not help let me know the exact model no and make of your Fax
Posted on Sep 27, 2010
SANYO TV CE37FH08-B
You need to have consequences which you consistently enforce for the misdeeds of your "kids".
Jan 18, 2018 | Televison & Video
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Jammed paper
You might need to update your drivers. If this doesn't help, there might be some loose gear inside the feeder . Try checking if there are also objects stuck.
Apr 17, 2012 | Epson Stylus R265 InkJet Photo Printer
I have a Canon MP210 scanner/ printer that is telling me I have a paper jam but there is no paper in the machine. I've turned off the power and turned it back on, I've looked for a small piece of...
Your printer might be out of paper.. so try this..... press Black/Color button... if it doesn't work turn off your printer and press paper feeder on the back side and press the power button with holding the paper feeder. Don release it until the process of printer is complete... thanks
Aug 26, 2011 | Canon PIXMA MP210 Photo All-In-One Printer
We have a Star TSP800 and when the last roll of paper ran out, we replaced it as we normally do. When we put a new roll in and shut the lid, the cutter usually comes across and the red error light switches...
Dear Star Customer
It sounds like you have a hardware issue. Please open the lid and take a photo of inside the printer and forward it to us at support@star-emea.com, it will help us find out what the problem it.
Best regards
Star Support.
Jul 16, 2011 | Star Micronics Receipt Printer TSP800...
I have a HP Color Laserjet 3600DN. The initial problem was no duplex printing. It wasn't pulling the paper back down. I replaced the duplex transfer belt. No luck. I then replaced the duplex reverse...
I've worked on these printers for years and I never heard of a "duplex transfer belt".
Sounds like you broke a wire or missed plugging in a connector.
Probably a bad Duplex Feed Drive assembly or bad DC Controller.
Jun 01, 2011 | HP LaserJet 5000gn Printer
Samsung ml-1640 giving red light, not taking papers
I had the same problem when a paper jammed and I have pulled it out. The red light came on and nothing worked. My solution was: I pulled out the tonner and put it back, opened all covers and closed it. All this apparently must be done with printed turned on (the same thing with printer turned off didn't work). Hope this helps.
Mindaugas
Oct 08, 2009 | Samsung ML-1640 Monochrome Laser Printer
I had a paper jam..took out the cartridge..pulled
Hello sir;Track back the paper you pull through you will find a senser either stuck or come off, put it back property.
May 06, 2009 | HP LaserJet 1020 Printer
Paper jam issue
I finally fixed the problem by running two sheets of heavy card stock through at the same time.  With the machine off, I positioned the two sheets in the feeder so that they would be pulled in when the printer was turned on.  When I turned on the printer, it drew the two sheets through and I guess this reset the paper sensor.  I previously found that only one sheet at a time did't work.
Nov 26, 2007 | Canon PIXMA MP460 All-In-One InkJet...
14 people viewed this question
k24674
jasbo
jasbo
