Question about Apple iPhone Smartphone
1999 Nissan Maxima Keyless remote, power antenna, & clock problem
I have a 1999 Nissan Maxima both me & my spouses key less remotes don't work. The power antenna doesn't work & in dash clock doesn't work. Not sure which fuse is for clock or power antenna or key less remote but checked fuses under driver side dash and under hood near battery & they were all ok. clock has had problems for along time not keeping time & dimming. But now can't see it at all. My key less remote has been on & off for a little while but doesn't work at all now. My spouses worked fine & just suddenly stopped working. We changed the batteries in the remotes but that didn't fix it. We tried reprogramming remotes by closing doors locking doors using main driver side power lock switch on door panel. Inserting key in & out of ignition 6-10x's in 10 sec. But hazard lights never flashed. Car Battery was recently changed & I think that after that is when my Spouses key less remote stopped working. the only other thing that might be relevant is we had trailer lights wiring added a couple years ago. that may have been when clock started acting funny but I can't really remember. It might not be relevant at all! Any suggestion are appreciated!
  • at67webster Aug 09, 2008
    My power antenna got bent and now it won't retract when I shut off my car. I want to remove the fuse because I'm afraid I can smell the antenna motor burning. I found the fuse box. Which fuse do I remove?
    Thank you
Thanks that solution about fuse #40 helped solve my same issue! Thank youuuuu
Posted on Jul 29, 2008
Throw away your Nissan.
Posted on May 23, 2008
Thanks for the info about the Easter Egg Fuse!! Now I have to find a new fuse!!
Posted on Sep 03, 2008
Fuse # 40 involves keyless remote, antenna, vanity lights, dash board clock, security system indicator light and garage door indicator light on driver side visor. One easy way to tell if the fuse is blown is if both visor lights are out. It's easy to overlook the fuse because it's labeled in white background black letter "electronic parts". It's in the fuse box under the driver side dash. The fuse is a 7.5A located in extreme upper Right hand corner o 1999 Nissan Maxima. If this fuse keep blowing after replacement it's probably due to a short. Consider any non factor installed wiring/electronic as the first place to look!
Posted on Jul 23, 2008
How to bypass ignition switch on 2006 nissan maxima 3.5 lost keys
Hello Jam mmmm,
I have seen products that allege this can be accomplished...
And frankly... IF COST WERE NO OBJECT...
and YOUR ELECTRONIC SKILL peerless...
I don't doubt that t could be done.
However...
back down here in this vale of REALITY...
Your options are call a locksmith to where you are or
have your car towed to a DEALERSHIP and pay twice
as much...
If you get on AMAZON or eBay and check how little it would have cost to AVOID your current situation ... it would be MOST VEXING... my best cut charge = $6
Regardless ... do shop around: you can still save HUNDRES merely by checking & weighing your options.
2006+nissan+altima+transponder+key
Keyless Entry Remote amp Uncut Key Chip Transponder Ignition Nissan 2002...
2 New Keyless Entry Remote Fob amp Uncut Chip Transponder Ignition Car Key...
Carnac the Magnificent
Jan 10, 2017 | 2006 Nissan Maxima
Antenna behind the mirror don;t know what iit is
This is normally an antenna for a power door opener or a remote starter, if you bought the car used and have no idea about this, you should have a seperate key fob that would operate the remote starter or the remote keyless entry
Mar 29, 2014 | 2006 Ford Taurus
How do you bypass the security system in a 1999 Nissan Maxima?
Im buying a 1999 nissan maxima it did not come with a keyless entry lock remote i never had this kind of a car so i did not know it needed one i noticed the alarm was beeping before i started it but stopped after i guess i did not check the car over good enough before getting it it takes a few times trying to start it before it starts and noticed the key i have to start it does not lock the doors can i by pass the alarm.?
Jan 08, 2012 | Nissan Maxima Cars & Trucks
2004 Nissan maxima Keyless Remote doesn't work to unlock / lock the doors
your battery is probably dead. Take the remote to Orielly auto parts and they have a tester that will tell you if the battery is dead. If the other buttons work on the remote then the remote itself is the problem and will need rplaced.
Nov 16, 2009 | 2004 Nissan Maxima
Where can you purchase battery for keyless entry for 2007 Nissan
The best place to purchase a replacement battery is AutoZone. They have a tester there to make sure everything is working. It should be on the help counter.
Jul 15, 2009 | 2007 Nissan Maxima 3.5 Sl Sedan
Reset my key less remote for 2002 nissan maxima
Hello and thank you for using FixYa!
Here is a link on how to program your remote.
http://www.ehow.com/how_4669678_program-nissan-remote.html
Thanks Jay!
Jul 11, 2009 | 2002 Nissan Maxima
Suddenly, both my keyless remotes have stopped working.
check the keyless entry module on the car
Dec 28, 2008 | 1999 Nissan Maxima
Keyless Remote, Power Antenna, and Clock problem
have u tried under the dash a black box which is to alarm open it up there will be 2 pins there that u need to bridge with a flat screwdriver at the same time the blinkers should flash then press each of your remotes to programme them hope this helps
May 23, 2008 | 1999 Nissan Maxima
Door lock
Make sure the battery on your Keyless Entry remote is a working battery.
If thats not it, it could very well be the actual button on your Keyless Entry remote being faulty. But it could also be a relay in the car aswell. Depending on the cost of a Relay versus the cost of a Keyless Entry remote, I would try to replace either/or and try again, whichever is cheaper. The Relay may be cheaper, but your Key-FOB sounds like it could be the cause.
May 16, 2008 | 1994 Nissan Maxima
Apple iPhone Smartphone Logo
1,114 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
