Question about Panasonic Office Equipment & Supplies
The projector is a Panasonic PT-LB51. It continuously says that the lamp needs to be replaced. We replaced the lamp and it worked for about an hour. Now we are getting the same message. The on/off button blinks green, but nothing appears on the screen. Then it turns to orange and the lamp button illuminates red.
SOURCE: Panasonic projector PT-L78 lamp reset
Press the MENU button. Use the < > arrows to get to the OPTION menu. Press the ENTER button. Select LAMP RUN TIME. Press and hold the ENTER button for about 3 seconds. The 'lamp time reset' will display. Press OK and press the ENTER button. This will reset the lamp hours as well as turn off the projector.
Posted on Feb 25, 2009
SOURCE: PT-LC50E LCD Projector
With power available at the projector and the lamp off (projector off) - hold the input button on and press the power button on and hold for 5 secs. This will reset the lamp timer to zero.
I wish they could have stuck this in the operators manual.
Posted on May 27, 2008
projdoc
  • 2237 Answers
SOURCE: Cannot Reset Infocus LP 350 Projector after replacing a bad lamp
that model has a history of bad ballasts. you'll need to replace it.
Posted on Mar 09, 2010
Testimonial: "Of all the comments on lamps failing to power up, only this answer fits my circumstances. I eliminated other "solutions" posted on FixYa. Thanks!"
SOURCE: Panasonic PT-LB10SVU green light flashing,then orange,lamp light
i just replace the lamp, and don't have any light coming from lens,starting green (after a few seconds,green become to flash2_bing.gif), then turning on orange and lamp light flashing...please i need help, fan working perfect...i don't have a remote,is a problem, or not
Posted on May 03, 2010
SOURCE: the projector lamp does not turn on
I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
Posted on May 13, 2010
PT DZ13KU NOT WORKING AFTER LAMP REPLACEMENT
I think your best bet will be to contact Panasonic Customer service. But the most common cause for this is that the lamp connections weren't properly re-installed, or there's an interlock switch that is in the wrong position from when you had the lamp(s) out.
Apr 11, 2014 | Panasonic PT-DZ13KU DLP Projector
Tip
Panasonic TYLA1001 Manual Lamp Replacement Instructions Models No. PT-52LCX66 /...
Models No. PT-52LCX66 / PT-56LCX66 / PT-61LCX66
Models No. PT-52LCX16 / PT-56LCX16 / PT-61LCX16
Are you missing the Installation Instructions for your Panasonic TYLA1001 Replacement Projector Lamp?
A digital, pdf version of the TYLA1001 Lamp Replacement Instructions can be downloaded from here.
Once installed, reset the lamp timer of your Panasonic Multimedia Projection HDTV by following these steps.
I hope that helps.
on Apr 11, 2010 | Panasonic TYLA1001 TYLA1001 Projector Lamp
Can't reset lamp timer after lamp replacement on Panasonic PT-AE40000
I have a Panasonic PT-AE4000U and could not reset the timer after replacing the bulb with a, non-Panasonic branded bulb. Calls to tech support were not very helpful. It was another bad customer service experience. Through troubleshooting it myself, I discovered the solution was simply to unplug EVERYTHING (serial cable, hdmi cables, etc.) from the device, power it off and back on. Follow the procedure in the manual, the timer immediately reset!!
Feb 11, 2012 | Panasonic Office Equipment & Supplies
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Our projector (Panasonic PT AE900U) is still working but the picture seems very dark all of a sudden. we are wondering if this means we need to replace the bulb and if so, what do we replace it with.
You need a new lamp. Cost is around $350. The following site shows replacement:
http://www.shopvsc.com/Replacement-Lamps-for-Panasonic-Projectors-s/284.htm?searching=Y&sort=7&cat=284&show=50&page=1&f-PT-AE900=109462
Oct 16, 2010 | Panasonic (ETLAE900) Projector Lamp for...
Need owner's manual
Link
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi Opokuagyeman,
Suggest that you consult the Panasonic Support Team for your lamp replacement.
Thank you.
Jul 28, 2010 | Panasonic PT L750E Multimedia Projector
How can I tell if the lamp still works? I dont have the projector to text the lamp so I'm wondering if there is any way to tell if it still works.
Because the lamp does not have a filament, you cannot run a standard continuity test either. You really need the correct power supply and ballast to see if it still works. Many old lamps will continue to work although the lumen output will be significantly reduced.
Jun 28, 2010 | Panasonic Projector Lamp for PT-LB50...
Dear sir, My projector panasonic pt-d5700 projector power indicator blinking red continue & projector not working. achal tewari
Sounds like a dead lamp, most likely need to unplug for a while to reset and replace the lamp before plugging back in.
Apr 04, 2010 | Panasonic Televison & Video
Last night, a message started appearing saying the lamp needed to be replaced on our Panasonic LCD TV. What is this and is it something we have to do? I think it's the Panasonic PT-AX200 LCD Projector, but...
the lamp is good for about 2000 hours. after this, the lamp may still work, but not as well or for very much longer. after you replace the lamp, you have to reset the lamp timer (in the menu settings).
Aug 10, 2009 | Panasonic PT-AX200 LCD Projector
May 25, 2008 | Panasonic PT-F100NTU LCD Projector
547 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
