Question about Carrier 36KCARMS Air Conditioner
I need a fan motor for 1.5 ton carrier ac indoor unit. vfixenterprise@gmail.com
  • Carrier Master
  • 43,501 Answers
Here is a tip that wrote about how to buy heating and air conditioning partsonline.
How to find Air Conditioning, Heating and Furnace parts online.
heatman101
Posted on Sep 28, 2010
What kind of capacitor do i need for 3 ton carrier ac unit
Where is the capacitor connected? To the compressor, inside fan or condenser fan motor. The value of the capacitor is stamped into the metal housing of the capacitor.There will be a number followed by the letters mfd
Aug 28, 2014 | Carrier Heating & Cooling
Bluestar split ac indoor unit making abnormal noises. I have a 5 star 1 ton bluestar ac model 5HW12ZBI. It makes noise (kit -kit) when the ac trips off. The noise is minor during day time but it Ibecomes...
From your details i can observe the blower motor bearing worn out. or its side bushes in which there is small bearing that may be worn out. Replace it. Finally check for correct voltage too.
May 07, 2014 | Heating & Cooling
I live in Phoenix, AZ. I have a 2 story 2300 sq ft home built in 2001. I have two Carrier AC units outside on the side of the house. They are the originals. The Large unit (upstairs) model 38CKC042340 and...
T the upstairs is a 3 1/2 ton 10.0 SEER condenser, and the downstairs is a 2 1/2 ton 10.0 SEER condenser. You can use any 10 SEER Unit on replacement, but if you go any higher in SEER (efficiency), there is a possibility the unit will freeze up. The reason is because the indoor coil also has an efficiency rating (10.0 SEER). It is not a good idea to mismatch units when it comes to SEER. Otherwise, you can use any brand of unit, if you want to go higher in efficiency, you need to change the indoor coil as well. Hope this helps. Mark
Jul 31, 2011 | Heating & Cooling
Hi there I have a model number for my carrier a/c unit. I need to find out the tonnage. 38ykc042300 Please any help I will be very greatful.
This is a 3 and 1/2 ton unit.
The 042 in the model number is the tonnage of your carrier unit.
AC tonnage is based on 12,000 btu per ton.
12,000.....1 ton
18,000.....1 and 1/2 ton
24,000.....2 ton
30,000.....2 and 1/2 ton
36,000.....3 ton
42,000.....3 and 1/2 ton
48,000.....4 ton
60,000.....5 ton.
There is no 4 and 1/2 ton unit.
Apr 09, 2011 | Heating & Cooling
How to connect a fan motor for a 7 ton carrier ac unit
7 ton, sounds like a commercial unit, if this so could be three faze. is this fan for cooling the outside condensor coils or the blower motor for moving air through the inside duct work
Feb 02, 2011 | Heating & Cooling
Carrier 1.5 tons ac Indoor unit switch off and write on display screen ( E5 ) please help me to solve the problem
If you have the manual the codes are listed in there. if you lost the manual, you can download a copy at Carrier.com
Oct 20, 2009 | Carrier 38CKC042 Air Conditioner
Compressor and outdoor fan runs indoor fan does not. Has 230vac can't find capasitor has GE ECM motor carrier package unit 2 ton
cap usually mounted to blower housing with power off turn blower wheel if rough bad brown wires from motor should lead to cap if replacing motor get new mount belly band also and make sure rotation is correct reversable motor hope this helps
Jul 06, 2009 | Heating & Cooling
BDP furnace + model 585A030080YACR
Sounds like your indoor fan motor is not working, check either the cap or the indoor fan motor it's self.
Jun 26, 2008 | Carrier Heating & Cooling
Carrier 36KCARMS Air Conditioner Logo
172 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
