Question about Frigidaire 24 in. FDB1250RE Built-in Dishwasher
I have a Frigidaire FBD1250REQ0 dishwasher, and the top rack keeps coming off the wheels on the right hand side. How do I fix this? Also, when we push the start button the washer does not aways start. We have to open and close the door and try again, usually several times. Is this fixable?
    Genius:
  • 1,417 Answers
what this simply mean is that there has been a lost or pastier connection on the power distributor from the panel to the control unit .what you are to do to solve this problem is to unscrew the washer from the screws then trace the wires (main power supply) down to the panel then also trace it to the door unit to see if there is any form of loose of wire if so it then need a fix up but if the answer is no then locate the wire down to the door switch unit but it all look to be okey then it then you will have to replace the hole of the control unit of the washer .
please note this if you can not carry out this assignment the you will have to invite a technician to visit the washer in order to avoid more damage on the washing system.
thank you .
Posted on Sep 27, 2010
Upper rack roller axles are brittle and 1 has
Our upper wheel failed. It is part of the huge assembly called the "Rack Adjust" on our model # PLD4460REC Frigidaire Dishwasher and cost $88 to $120. Hey.. thanks to the guy above I was able to fix my machine without spending to much!! for a huge part when all I needed was the upper wheel. the part # for the upper wheels is = PS976006 and is for another model dishwasher (Sears located it for me first.. without trying to make me buy the huge assembly) but might work... I will order and give them a try. The model # referenced about seems to be incorrect... We used model # PLD2855RFC1... as google helped us fill in the missing part# letters. I asked frigidaire... why they encouraged customers to borrow this small part from the store display.. why not just sell it!! .;)
Aug 02, 2010 | Frigidaire PLD4460REC Stainless Steel...
The top rack - missing pin
At an appliance spare parts shop or by calling a number in the booklet that came with your dishwasher that you probably don't have anymore.
Jun 03, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Frigidaire Dishwasher FDB2810LDC1 not draining
Sure its redeemable if you have the time and money. If I understand you correctly when you move the lowewr spray arm the water drains out? If this is the case then more than likely its a pump motor or solenoid. Reason I say this is on the bottom of the spray arm is a impeller and under that is filter and then pump impeller that drains the water. If its not draining but will by hand then its your pump motor or solenoid. When you start the washer then press cancel/drain do you hear anything? Maybe a humming sound. One more thing could be a thermal fuse for the motor. These are usually not resetable its a one time fuse if it blows you have o buy another one.Hope this helps
Jan 25, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Wheels keep falling off on lower rack, clips all
the clips come with new wheels, they should cost about $4 for four, I would replace all wheels on the lower rack
Nov 17, 2009 | GE Nautilus 24" Built-in Dishwasher
How does the rack come out of the freezer to adjust
there should be a plastic clip between the rack and left side of the freezer remove the clip then push the rack to the left real hard then the right side should come out raise the right side up and remove rack
Jul 12, 2009 | Frigidaire FRT15B3A Top Freezer...
Just installed new dishwasher top rack will not slide in
I had the same problem with my new GE. They installed 2 brand new upper racks.$$ it worked ok for about a month and then I had to force it in again. on the 7th repair call in as many months my repair guy walked in the door stating that he finally knew how to fix the problem. It is caused by poor design in the wheels. they are porous and the detergent breaks them down and they swell. new wheels from an older model fixed the problem. they have RND on the case.
May 30, 2009 | Frigidaire PLD4375RFC Dishwasher
My dishwasher is not washing dishes on the top rack...
HI,
The top rack is not cleaning because of low water pressure from the wash motor to the upper spray arm.
Assuming the top spray arms are clear of debris, remove the lower spray arm to access the wash motor. Remove the 4 torx screws and the filter (accumulator assembly). Remove the torx screw and the inlet protector that covers the chopper assembly. Make sure the chopper is not broken (broken chopper will fill with debris and block water flow). While holding the chopper blade, reach inside the "D" shaped opening on top of the motor and spin the wheel/motor by hand in each direction to make sure either the chopper gear or the motor gear that drives the chopper is not broken. Replace the chopper if necessary . If the motor gear is broken, replace the sump and motor assembly . Remove any debris from the sump area in the process.
You don't have to shut the power off to the dishwasher because the door will be open, but if you feel more comfortable, do so.
thanks,
Mar 18, 2009 | Frigidaire 24 in. FDB1050RE Built-in...
I have Kitchen Aid Dishwasher Model # KUDMOITJBLO. We began having trouble with the top rack coming out of the brackets on the upper rack track. Kitchen Aid sent me 4 parts # 8268785. The problem is...
I removed the tracks from inside the dishwasher.  Then I was able to carefully remove the endcaps (something I had not been able to do previously) carefully.  The existing broken wheels slid out and I slid two new brackets into each track.   If I attached the tracks to the rack first, I would not be able to clip them into place, so I first replaced the endcaps and then returned the tracks to their positions inside the dishwasher. Reattaching the upper rack is not difficult, but takes two people while I connected the left side, my assistant supported the rack on the right side.  I then connected the right side of the rack.  I slide the rack back and forth to macke sure that is worked smoothly.  We then loaded the dishwasher and washed our dishes as we had in the past.
May 27, 2008 | Dishwashers
Frigidaire FDB740RCS0 Upper Armnot Turning
the motor stops and runs in the opposite direction to pump water up to the top rack. you first need to listen for the motor to stop and start. if you hear that open the door and try to tell if water was coming out of the top spray arm.
Nov 01, 2007 | Frigidaire 24 in. FDB1050RE Built-in...
Dishwashers Logo
66 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
