Question about Orion Computers & Internet
The monitor will not come on. We tried different power cords but no luck.
  • Rommel Cana
    Rommel Cana Sep 27, 2010
    if your Orion Monitor is connected in a computer Video Card, check the Computer
    if it is booting properly.
    Check the Menu , Check if you can see anything on the Monitor and post
    include the Monitor Model so, as to help you further.
  • 732 Answers
John855, Need to know model and "date of manufacture" from rear of unit to provide you with some help. Is unit LCD or CRT type of display? Is unit powered by a wall outlet or is it connected to a multi outlet "power-strip" ?? 12fixlouie
Posted on Sep 27, 2010
3 Suggested Answers
  • 508 Answers
SOURCE: I have a SDM-HS75 monitor that is 33 months old
bad power supply
Posted on Jun 25, 2009
  • 1705 Answers
SOURCE: Computer is hooked up and running. Power to mouse
If you can, try your monitor on another PC, neighbough or friend if necessary. If it fails, you've a monitor problem, if it works you've a PC problem. Oh ensure you use the same leads each time.
If its the monitor then its a replacement or repair, if its the PC, it could be just the graphics card needs reseating or replacing. Not too expensive if you're not into CAD or gaming. You could try second hand but make sure its compatible with your motherboard.
Posted on Sep 06, 2010
Lg monitor power problem
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 06, 2014 | LG Studioworks 563N 15" CRT Monitor
No video input
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Jul 10, 2014 | Philips 190B6CB/27 19" LCD
Hannspree hf199h no picture or sound
Good luck.
Jul 06, 2014 | Computers & Internet
My screen goes black
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
Jul 04, 2014 | HP Computers & Internet
Hp p6530z desktop will not boot
It could be the monitor. Try a different monitor. Here's some tricks I would try...
Good luck.
Jul 02, 2014 | HEWLETT-PACKARD Hewlett Packard Pavilion...
No power , power switch does not respond. checked power cord, fully connected. Tried 3 different home outlets.
Mine did the same the other day and all I had to do was replace the fuse in the plug. Just a thought if your monitor gets power direct and not through the PC
Good Luck
Nov 18, 2009 | Hyundai Computers & Internet
My AL1703 sm monitor will not power on.
that means the power cord is faulty, the monitor does no send message to the power cord rather the power cord sends message to the monitor so its the power cord that's bad expecially if its an adaptor, thanks
Jul 17, 2009 | Acer Value AL1703SM 17" LCD Monitor
Monitors comes on for a few seconds then goes black. the only way is to turn it on and off but still only stays on for a couple for seconds
I think the power board might be going bad in there. Hook up a different good working monitor to the computer and see what happenss.
If the monitor still turns off after a few seconds then you know its the video card acting up. If the monitor stays on then you know its the original monitor that is bad for sure.
Jul 03, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Computers & Internet Logo
99 people viewed this question
Top Orion Computers & Internet Experts
David Payne
David Payne
Are you an Orion Computer and Internet Expert? Answer questions, earn points and help others
