Question about Magic Chef CPL1110AD Gas Kitchen Range
I need to know what size propane regulator i need for proper operation.
  • Magic Chef Master
  • 3,051 Answers
Hello there:
This is a 1/2 in valve
Regulator, pressure
Part Number: AP4095285
Made by WHIRLPOOL i need to know what size propane regulator i need - dot_216.gif Our Price: $18.90
Compare at: $28.15
You Save: $9.25
Read more: http://www.appliancepartspros.com/part_details.aspx?part_id=4095285#ixzz10lDzswpX
Posted on Sep 27, 2010
I need to know the propane orifice size for a Peerless LUH50A hanging heater When running the unit on a regulated propane tank the heater emits black smoke
ask a qualified gas fitter for the correct jet size and have him position the air shroud correctly to get the correct air /gas ratio for a clean burn
Jan 29, 2017 | Heating & Cooling
That may well be soot its not burning right turn off and do not use . co2 coming off the heater needs a service asap .
I wish to know the proper propane connection as pressure,regulator is it required before connection at heater
I do not recommend someone to tamper with propane connections or regulators unless you are knowledgeable with it. Propane is a "very" powerful gas. Set up properly it is Great. But dangerous if done improperly. Call a professional for your safety.
Dec 22, 2013 | Dometic Heating & Cooling
Convert from lp to ng
orifice sizes will increase since goin from lp to nat gas.......to convert appliances you will need diff gas valves, nat gas and propane will have diff pressures
Dec 05, 2013 | Heating & Cooling
I have an Enviro propane fireplace insert installed last year & it worked fine. The tank & regulator were changed because I got another gas supplier. For some reason now I have a low flame....
It sounds to me like you need to increse gas pressure. Most propane fired units need at least a 11 inch water column of pressure for proper operation. This relates closely 7.5 ounces. I would have regulator checked out by qualified service techs. Thank you
Nov 20, 2010 | Mr. Heater Mr Heater Portable Buddy...
I have a Frigidaire Stove, Model # FGF316ASA. It was changed from propane to natural gas. The oven works well. The burners, however, will only burn a low flame. Is there a solution for this?
When converting an appliance from propane gas to natural sometimes a technician will drill the orifice to a larger size rather than replace the orifices. Either way is fine, but sometimes the orifices don't get drilled to the correct size. The regulator must be on the propane setting if it is a convertible regulator. If your oven is working fine.... the top burner orifices probably need to be checked that they are the correct size. A simple fix.
Tom
Aug 11, 2010 | Frigidaire FGF316 Gas Kitchen Range
How to install a propane system properly assuring that you have the proper flow/pressure to all appliances?
Use the installation manual as a guide to sizing the gas pipe to insure good flow. The issue of pressure requires a manometer and adjusting the gas regulator on the side of the house (or at the tank). Professional plumber or gas company can take care of this for you.
When figuring out the gas pipe size, Do not forget to figure your other gas appliances in. All appliances should be able to operate and stay with in the minimum set forth by each manufacturer. Bosch is likely going to have the tightest requirement. If you do not do it correctly, plan on a cold shower.
Jul 22, 2010 | Bosch & Tankless LP Hot Water Heater
Natural gas to propane
changing from natural to propane requires different jet sizes and repositioning of the air mixture shrouds
working with gas is not in the domain of diy as you have found out so get in a gas fitter to do the conversion properly with out risk of an explosion or fire
Jun 20, 2017 | Vulcan VG36 Gas Kitchen Range
I have an older Genesis grill with a leaking regulator
You can get a replacement regulator at just about any home improvement store (Home Depot, Lowe's, etc.) There haven't been changes in the size of the ports or thread patterns on regulators or propane tanks in the last 15 years.
Oct 07, 2009 | Thermos Stainless Steel Gas Grill
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Magic Chef CPL1110AD Gas Kitchen Range Logo
168 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
