Question about Maytag Dishwashers
My dishwasher doesn't seem to be cleaning properly. I have cleaned the screen and all sprayers and they are working properly, but not sure the autoclean cycle is working properly. Is the water supposed to drain and refill before the washing cycle begins?
  • 1 more comment
  • rgschaumann Sep 29, 2010
    I have already done those. I went through 1 complete auto clean cycle and think the cycle may not be working properly. If I remember right, it should drain several times and refill - if not partially, completely - as in a pre-rinse, etc., before the soap is dipensed. It does drain before the rinse. . .
    thanks - I'll check it out.
  • rgschaumann Sep 30, 2010
    How do I know if it is the drain pump or the control panel that is not working properly.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Sep 29, 2010
  • Rylee Smith
    Rylee Smith Sep 29, 2010
    Its either the drain pump is not working properly, has gone bad or maybe the drain hose is clogged.
Hi...my Maytag Jet Clean doesn't seem to be actually cleaning anything. Especially the glasses and crystal. They are coming out with a sort of white film on them....lip prints still in place...still...
The upper spray arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Also, make sure the water temperature is 140 degrees.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 12, 2011 | Maytag Dishwashers
Top wond (rack) doesn't clean. Dishes are very dirty at the end of the cycle. However, the bottom rack is fine......please respond asap if possible. Thanking you in advance. Connie
Connie,, make sure in loading the dishwasher you have room for the soap and water to make it to the top rack, (older models) on newer models you have a sprayer just under the rack make sure the sprayers are working fully,, to clean them you can use a hard brush and vinegar,, let stand for 5 minutes and rinse off, also, you can run vinegar ( white) through your machine,, to help clean the jets,, use in place of the soap , then run a couple of times empty to remove and let over odor
May 17, 2011 | Dishwashers
Hi ,my hotpoint aquarius dishwasher FDW60 is not cleaning properly.It seems to be completing a full cycle but the tablet has not dissolved fully.or the dishes are all dirty.Can you advise please ,Dermot
If you have hard water, it is likely that the sprayer in the bottom of the dishwasher has become clogged with hard water deposits. This may be the case, even with soft water.
On most models, the sprayer looks like a propellor, and can be removed by carefully unscrewing the fastener at the top and carefully removing the sprayer. If you have a digital camera, I recommend taking pictures at each disassembly step, so you know how to put things back together (in the reverse order that they were removed). It should not be too difficult to remove it, but you may have to gently work with the fastener at the top to get it to budge.
You will need to clean all the spray holes and ensure that none are clogged. I used an ice pick and toothpicks to clean out the holes recently on my dishwasher. (We have hard water).
You may need to soak the sprayer in vinegar overnight if you're not able to completely clean out all the holes.
Mar 30, 2011 | Dishwashers
Dishes on upper rack are not being cleaned. Seems like upper sprayer is not working properly.
Hi
Please check if something is blocked near the top spray arm, also make sure that all holes are oopen. Use a sharp metal pin to clean the holes on the top spray arm. Make sure the water pressure is not low.
under the screen and youl'll need a Torx driver to get to it after you remove the spray arm and screen. Check to see that the path it travels is clear. I have seen these get blocked up by stuff.
Now check if the top arm spins freely and check the bearings for the arm, if they are producing extra friction while the spray arm spins. Hope this helps... Please post back if you need more assistance.
Daniel
Jan 01, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Not cleaning
Check spray arm jet holes. Clean the clogging with blower or soft bristles.
Apr 12, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
Indesit idl 705, tablet not dissolving and crockery still dirty, was working fine. Sprayer arm seems to not rotate freely
Clean EVERYTHING and ensure it's assembled correctly.
The sprayer arms have an unlocking ring and can be rinsed, the filters must be washed and rinsed and properly reassembled.
Even cleaning the door seals can help.
Test again, clean again (as more muck can be circulated).
Sep 27, 2009 | Indesit 24 in. IDL700 Built-In Dishwasher
Maytag quietseries 300 dishwasher not cleaning properly
UNGLOGGED THE BOTTOM/TOP . CLEAN IT AND SHOULD BE OKAYARMS SPRAYER, THEN IF IS GOOD AN NOT ENOUGH WATER CHECK WATER VALE SCREEN
Aug 19, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwasher that leaves dishes dirty
Your drain could be blocked, remove the drain from the trap below the sink and try running the unit on drain, into a bucket. Also check the connection at the trap to ensure it is free from blockage
Mar 19, 2009 | Dishwashers
My Kitchenaid dishwasher not cleaning dishes on top shelf
You need to clean the jets on the machine arm with an old toothbrush etc... then clean out the debris filter on the bottom of the tub near the dryer bar. The calcification in the little jet areas causes this problem. This should help.
Jan 18, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Kitchen Aid dishwasher - top shelf not getting dishes clean
Is the top sprayer clean and not clogged so that the water can flow through? The top may not be functioning properly.
Jan 16, 2009 | KitchenAid Dishwashers
Dishwashers Logo
386 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
