Question about Nikon Coolpix 5400 Digital Camera
Nikon Coolpix 5400
This camera has worked well. Last week my wife took out the memory card and suddenly it will not turn on. I have charged the battery and replaced the memory card to no avail. Any thoughts?
  • camerastew May 29, 2008
    Same problem. It has suddenly gone dead, no power, won't start up. I have tried changing batteries & making sure they are charged up. I'm perplexed!
  • Anonymous Jun 25, 2008
    Same thing here. I took it to the camera shop today & they said that a pin might be bent where the memory card goes. If that's the case, they said they would have to replace the whole board & it would run about $200.
    Problem Solver:
  • 7 Answers
Look into memory inserting slot if you see a bent pin, I doubt it, most likely something internal failed, as of now fixing the camera is not worth it unles Nikon fix it and most likely they will as this is possibly internal component failure, contact them and send it for a repair, they will give you estimate, if it is free or acceptable let them fix it if not garbage can will gladly accept it and move on.
Posted on Jun 28, 2008
I bought a used nikon coolpix and added an 8gb card for it but it says there is no memory available even though i already formatted it
Try reformatting the memory card using the camera go to the camera's Menu and select format memory card.
Dec 13, 2012 | Nikon Coolpix 5400 Digital Camera
My nikon coolpix 8400 won't turn on, I took out the memory card to develop some pictures then I put it back in and then the camera wouldn't turn on all of sudden,it has never done this before! do you...
Make sure the battery is fully charged. If it isn't then charge it up and hopefully your problem is solved. If it is fully charged take it out of the camera for a minute or so then put it back in. Try turning the camera on.
Dec 05, 2010 | Nikon Coolpix 8400 Digital Camera
What is the correct size memory card for a E 5400 nikon
The 5400 takes Type I and Type II Compact Flash (CF) cards and Microdrive cards.
There is a chart in the "First Steps" section of the manual listing approved cards. None of them are larger than 1G.
Jan 04, 2010 | Nikon Coolpix 5400 Digital Camera
Nikon Coolpix L18 suddenly states that card is not formatted.
Sounds as if the card is corrupted - you will have to use data recovery software.
Aug 06, 2017 | Nikon COOLPIX L18 Digital Camera
Camera says out of memory after buying new compact flash card 4gb
Go to http://timescience.wordpress.com/2010/08/09/how-to-downsize-a-4gb-compact-flash-card-to-2gb/. That will make the card 2gb and it worked like a charm on my Nikon 4300 coolpix. It will hold 1059 pictures on the fine setting, 2083 on normal, and 4167 on basic. Hopefully this helps, I looked on the computer for hours until I found this.
Dec 20, 2008 | Nikon Coolpix 4300 Digital Camera
Nikon Coolpix 5400 lines in pix
Yes! Send the camera to Nikon with the service form. It takes about 3 weeks, free of charge.
Nov 05, 2008 | Nikon Coolpix 5400 Digital Camera
Shooting pictures delay
try format your memory card, in camera and if you can then also try format it in memory reader, try different memory card, pls report results if it helped so we can learn.
May 27, 2008 | Nikon Coolpix 5400 Digital Camera
Nikon E5700 digital camara. Camara turns on, everything looks good, shutter opens but only see black through the view finder, monitor and will only take black pictures. I reset camera to factory...
There is a service advisory out for Nikon E5700.
t has come to our attention that in a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras, an electronic component may, in some instances, fail affecting your camera's performance and/or operability.
While only a limited number of COOLPIX 3100, 3500, 4500, 5000, 5400, 5700 and SQ digital cameras are affected by this advisory, if your camera presents symptoms that can include (1) images with a strong color tint, (2) images that are totally black and/or (3) images with visible defects, Nikon will, upon confirmation that the problem is associated to this Service Advisory, service your camera free of charge.
link to info is here: http://www.nikonusa.com/Service-And-Support/Service-Advisories/index.page
Feb 27, 2008 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5400 Digital Camera Logo
138 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
