Question about GE I Series GSS20IET
I LEFT THE FREEZER DOOR CRACKED OVERNITE, NOW THE FRIDGE WONT COOL,,????? BEEN 2 DAYS
murdozzz2
  • 75 Answers
SOURCE: Freezer not freezing, fridge section not cooling
the problem you have sounds like the defrost heater is not being activated causing the evaporator to choke up with ice which will therfore restrict the airflow through the cabinet,
to resolve this problem you are best to defrost the unit and replace the thermal fuse for the heater' and the defrost sensor, both these parts are located behind the evaporator cover inside the freezer.
hope this is of help murdozzz2
Posted on Dec 08, 2007
SOURCE: GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Posted on Sep 21, 2008
wheelshot
  • 102 Answers
SOURCE: Fridge will not cool properly
You may have a dust build up on the condenser coil. You may notice the jam of the ref door being very warm. This is an indication of a dirty coil (located under your ref) that just needs to be cleaned or your fan motor in the back of the unit may have failed and stopped turning.
Posted on Apr 11, 2009
SOURCE: GE side by side refrigerator. Fridge side not cooling - help!
Hi, they have changed lots of parts, were they defected, did they tested parts for faults or they just change parts, because it's available, there's always a reason why a certain part, go bad. so far you change most of parts in ref. check refrigerant (gas, freon) pressure, check compressor, for faulty suction and high side valve, it's possible your compressor loosing efficiency. or say if compressor normally pump 50 psi. now it's pumping 40 psi. is the refrigeration cycle balance ? is there restriction in your ref. system? is compressor running long enough? plug on ref. let it run for 1hr, listen to compressor for any clicking sound, fans and everything else could be working, be compressor not, compressor could be short cycling (not working long enough) also check voltage in receptacle(outlet) with digital multi-tester, get accurate voltage reading, let me know, could also be a faulty circuit breaker in house (building) not your ref. let me know, system could have very slow refrigerant leak, you could have a very small (slow) gas leak, that's why your refrigerator get hot first, then your freezer, there's a condensate line (loop) that passes through, ref body, close to doors to prevent door gasket from freezing, after few years sometimes develope leaks, cause by rusting. it's very possible there could be small leak in your system. let me know what happened.good luck.
Posted on Aug 14, 2009
SOURCE: Fridge is warm, freezer works.
Smilar problem, but the model is GTH15BBMFLWW
Posted on Aug 20, 2009
Refer door left open overnite. can hear it running but fridge and freezer are not cold.and it has run all day. What can I do? .
the fan that blows air from freezer to fridge is probably frozen with ice from all the moist air when door was left open turn off unit and let defrost will see screws where fan is located to help fan defrost us hair drier to free fan when free enough to turn freely turn on unit and push door switches or close door and listen for fan to go on if goes on turn off unit and and continue to defrost till fan and duct [airway ]is clear of ice than turn on and let run -if fan doesnt go on have tested may have burnt out from trying to run while frozen up repair or replace fan and recheck unit good luck
Jun 27, 2011 | Kenmore 94499 Refrigerator
Left the freezer door open all night and morning noticed it in the afternoon. Thawed it and now the freezer works fine but the fridge doesn't cool
these fridge freezers have a damper flap which means your fridge will not cool until everything in the freezer is frozen hard again this may take up to two days depending how much you have in your freezer
Regards
Ian
Apr 19, 2011 | Hotpoint Refrigerators
FRIDGE/FREEZER ON THE BLITZ?
Try removing everything out of your fridge, switch it off and open all doors for 12 hrs. Then close doors and switch it on for another 24 hrs before putting in you stuff. most likely the evaporator is iced up, you need to defrost if fully.
May 04, 2009 | Refrigerators
Fridge side wont cool unless the freezer door is open
the little fan motor in the freezer is defective.  It may only be stuck.
Apr 01, 2009 | Whirlpool ED5VHGXM Side by Side...
Fridge not cooling
hi there.
welcome to fixya.
initially try to defrost the ref and clean it.
Feb 26, 2009 | Amana ASB 2623 Side by Side Refrigerator
Left door open on freezer last night and now it wont work
turn it off for a day or two let it defrost and then turn it on. it just has frozen up the coil, or the compressor has heated up cause it was working to hard turn it of for a cople of hours to let the compressor cool
Jan 04, 2009 | Frigidaire FRT21P5A Top Freezer...
Servis frost free fridge freezer makin crackin noise afew tyms a day
this is not unusual on any make. the cracking noise is the cabinet creaking with change in temperatue. don't worry about it
Oct 18, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
GE I Series GSS20IET Logo
26 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
