Question about True GDM-12 Refrigerator Commercial
I have a true commercial refrigerator that the temperature is not working. It reads 11 degrees F and wont go up using the temperature control knob. Any advice?
    Sergeant:
    Novelist:
  • 193 Answers
The only thing it could be is the thermostat. Or, maybe your thermometer is reading wrong. Is everything freezing up? The thermostat is located up near the top usually on the side of the fan housing inside. It is easy to replace if you have a refrigeration supply company close by.
Posted on Sep 27, 2010
Temperature setting True tssu-60-16
if you tried to adjust the temperature and the cooler continues to freeze the food then replace the thermostat attached to the control knob. Thermostats fail in different ways
Link=> HERE
APPLIANCE 911
Jul 22, 2016 | True TSSU-60-16-ADA Stainless Steel...
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
True t49g side by side not defrosting
True's T-49G is not equipped with a defrost timer as it is a medium temp unit, so I would suspect the temperature control may be defective. Part #800393 is commonly used for the True T-49G, though it's best to check verify with model number and serial number. It could also be as simple as adjusting the temperature dial a little bit. The target temperature range is around 36 degrees Fahrenheit.
May 31, 2011 | True T-49G Glass Door Commercial...
My true freezer temperature gage has a P1 flashing code
Have a look at the Make and model of your thermostat and download the Instructions from the internet or give ur local refrigeration mechanic a call and ask him they are easy to set
Mar 23, 2010 | True Commercial Freezer TM74F
It has a temp control knob. but wich way is to
9 is usually the COLDEST setting on fridges. Place a thermometer in there, try different settings, give the unit 24 hours of closed-door operation to get an accurate reading.
Nov 25, 2009 | True GDM-12 Refrigerator Commercial
True GDM 12 won't go over 57 degrees. Just got it,older model no T-Stat. Cleaned up last night did see some brown syrup looking stuff.I did wait about 8 - 10 hours before pluging in. The unit has been...
All refrigeration equipment has some sort of temperature control, either a temperature control knob(1,2,3,4 or A,B,C,D settings) or the unit has a pressure control to control the box temperature. The pressure control would be in the bottom of the case with the compressor.
Nov 10, 2009 | True GDM-12 Refrigerator Commercial
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
True GDM-12 Refrigerator Commercial Logo
214 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
