Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
I m getting a problom where the battery is not charging through the charger in my laptop .tell me what is the solution???????
    Guru:
  • 571 Answers
How are you fixya user.
I am very glad to help you with your problem.
Here's what you can do:
You need to isolate the part which is causing the problem.
There are three parts in your computer which are the possibly the reason why your computer is acting like that.
1. ac adapter
2. battery
3. motherboard
Here's what you should do to isolate the problem.
var geo_Partner = 'cca8460f-a562-4792-a693-6fa0e7fcde78'; var geo_isCG = true;
Posted on Sep 27, 2010
  • Carlo Adrian Canon
    Carlo Adrian Canon Sep 27, 2010
    1. Remove the battery from your computer and use the ac adapter or the power chord alone in powering up your computer. If it does work, then, the problem is with your battery.
    2. If doing procedure 1 has no effect on the computer, try using a known good power chord which is compatible with your computer and plug it in a known good outlet.
    3. If 1 and 2 do not work, then it's the motherboard that's having the problem. You need to go to buy a new motherboard.
Karboon k9 atometic charging ..and not charaging problom
this is most likely caused either a loose connection from the charging circuit on the motherboard or a faulty charger unit
Nov 28, 2013 | Computers & Internet
Dell inspiron M5030 won't charge, green light is
This is a common problem. It may be that the charger is dammaged. these Dell chargers have a micro thin communication cable in them that tell the charger to charge the battery. this micro thin cable can often break. Its use it to prevent the laptop battery from over charging, but if it breaks or becomed broken inside tha charger cable, then the laptop simply won't get the charge signal and the battery won't charge. If this is the case, then you will need to replace the charger with another Dell charger compatible with your laptop
Dec 23, 2012 | Computers & Internet
MY DELL INSPIRON 1420 WHEN I PLUG IN BUT NOT CHARGING HOW TO FIX IT.
Hello, you may find this to be the fault of the charger itself. Dell chargers have a micro thin communication wire that tells the battery to chage and when to stop charging. But this tiny communication wire within the charging cable is very fragile. If it breaks inside, then the laptop battery will not recieve the signal to make it charge. Replacing the laptop charger may be your solution. But it will need to be another Dell charger compatible with your laptop
Dec 23, 2012 | Dell Computers & Internet
Dell Xps 15 Laptop Battery Not Charging
If your battery will not charge, you need to run a test on some components on the laptop. The battery, the charger and the laptop itself. Once you detect the faulty conponent then you replace it with a new one.
To test the battery:
1.Power off the laptop,
2.Take out the battery,
3.Insert it in another laptop,
4.Check of it will charge,
If the battery holds a charge there, then it means the problem is not from the battery, but if it does not hold a charge, then it means the battery is defective and need to be replaced with a new one.
To test the charger:
1.Unplug the charger from the present laptop,
2.Connect it to another laptop to see if it will charge.
If it charges the laptop, then it means the charger is alright, and if it does not charge the laptop, then it means the charger is bad and need to be replaced.
To test the laptop:
1.Turn off the laptop,
2.Disconnect your present charger,
3.Remove your present battery pack,
4.Insert a well tested battery into the laptop,
5.Connect a well tested charger to the laptop.
If it powers on, then it and charges, then it means the laptop is working fine, but if it does not charge, then it means the connection port of the laptop is bad.Hope this information was helpful.
Dell XPS 15 AC Adapter Charger
Nov 01, 2012 | Dell XPS Computers & Internet
Battery on permobil will not charge
First off, a Permobil C500 is not a PC laptop. Next time, please put this in the correct category.
Try charging up the battery/batteries with a auto car charger. Make sure the voltage is set correctly, and charge it on slow or low, 2Amps. Leave it on there for about 4 hours and see if the chair will run and for how long.
This should tell you if its the batteries or charger that's bad.
Sep 25, 2012 | Computers & Internet
Hi i have some problem to my laptop battery it wont charging, but laptop charger is working fine, my laptop brand is compaq presario C700. i tried to charge my laptop in 2 hours after that i tried to turn...
Did ur laptop works or turn on when u plug the adaptor charger?
If ur laptop turns on when the charger is pluged in, u got problem with ur DYiNG BATTERY!
Better buy a brand new battery!
Nov 08, 2010 | Compaq Presario 700 470024-192 Notebook
TOSHIBA SATELLITE A200 BATTERY PROBLEMS
This problem is very common and can be because of any of these reasons-
1-Wrong Charger,in case you are using some other charger ..i mean other than the one which came with your TOSHIBA laptop.
2-The transformer of the charger is releasing more than the rated voltage.
3-The earth terminal (one of 3 terminals of charger pin) is short (not working)..
I would recommend you to get TOSHIBA CHARGER OF SAME MODEL from your friend or go to TOSHIBA STORE and ask them for TOSHIBA (ORIGINAL) and connect it to see whether laptop its charging or not.
If it works then you need to change your charger
and if not,then you need to get the charging circuit repaired.
NEVER USE SOME OTHER CHARGER (OTHER THAN TOSHIBA) IT CAN SHORTEN THE LIFE OF YOUR BATTERY AND CAN EVEN SHORT YOUR CHARGING CIRCUIT.
have a nice time ahead...take care
Jun 25, 2010 | Computers & Internet
Laptop Charger will only work is laptop is turned off.
it sounds like the charger does not have sufficient wattage for your machine. i would try getting a certified acer power supply.
Aug 14, 2009 | Umax ActionBook 333T Notebook
Compaq nx 9020 battery charging problem
Damaged battery or internal circuit problem it is hard to to say. Bring your laptop to a repair shop. They can check the battery and tell you what the problem is.
Dec 04, 2008 | HP Compaq nx9020 Notebook
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
63 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
