Question about Samsung J700 Cellular Phone
Hi it is in the wrong language after removing the battery
New camera pressed wrong language need English and got German
maybe remove the batterie for a while or play a little around if you see the word Sprache it means Language you can also compare with a google translator some words in different languages
?laNGgwij ?? or other possibillities
Nov 24, 2015 | Cameras
Wrong language accident put printer in "Korean" of
You need uninstall first software driver of HP PHOTOSMART PLUS AIO PRINTER B209A PHOTOSMART PLUS AIO PRINTER B209A All-In-One. and Then reboot your PC. then install again software driver for that printer select English language version.
Oct 16, 2011 | HP PHOTOSMART PLUS B209A All-In-One...
I accidentally put in the wrong language, I don't know how to get english back...thanks:)DeeDee
To change language or date/time in the future, yo should use the Setup menu,
  1. Setting up your camera
    • Attaching the strap
    • Loading the AA batteries
    • Turning on the camera
    • Setting the language and date/time
    • Storing pictures on an SD or SDHC Card
just in case if you need user manual in pdf format pls visit the link
below...
KODAK
EASYSHARE C195. Digital Camera.
Extended user guide
http://support.en.kodak.com/app/answers/detail/a_id/19314/selected/true
KODAK EASYSHARE C195 Digital Camera resources.kodak.com/support/pdf/en/manuals/.../C195_xUG_GLB_en.pdf
www.kodak.com .....
Aug 07, 2011 | Kodak C195 Digital Camera
Keyboard types wrong characters
You may have a wrong default keyboard layout.
To resolve this please do the following:
Assuming you are using Windows 7, click Start->Control Panel, and then go to the "Clock, language and region" icon, and click on the "Change keyboards or other input methods" link.
When the window opens, click the "Change keyboards" button.
When the window opens, check the default input language. Assuming you are in the U.S. If it doesn't say "English (United States) - US" then you need to change that by highlighting the wrong language, and clicking on the "Remove" button.
As a last step, restart the computer to make sure the settings are applied.
Jun 24, 2011 | Sylvania GNET28001XSN Netbook
How to remove these freaky chinese language.. even if i try in language settings.. still it didn't work.. could somebody please help me?? please???
hi bndragonite after you change the language did you pull the battery. pulling the battery acts as a reset function on your phone. You could also fo a hard reser on the phone. You will want to make sure you back up all your inforamtion on your phone. if you don't back up your information it will all wipe out of the phone.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Mar 04, 2011 | Nokia 5310 Cellular Phone
Hi,i acidentaly sellected the wrong language while setting up my new phone.Can you please tell me how to get it back to english australia,i think its on spanish now and i need to change it...thanks...Allan
Take out your manual and look where the language settings was(usually in the settings, but where). Then use your phones graphical interface as an aid and use to get the language settings so that you can change the language. This is how I did when I accidentally selected the wrong language. Good Luck
Dec 31, 2010 | Sony Ericsson XPERIA X10 Cell Phone
When starting up hit wrong langauge. How to change country
Try to reset your tom tom gps device, that way your language will be back at the default language. To reset your tom tom hold down the power button for about 15 seconds, it will restart itself automatically, that way you will have to chose the language once again. Or you can simply remove the battery and reinstall it in once again. Or you can connect it to a computer and format the gps and download its software back on. That is a sure solution
You can also follow the steps below, but you have to be logical about the position where these options are in the language you mistakenly chose.
  1. Tap the screen to bring up the main menu,
  2. Tap change preferences,
  3. Tap the arrow in the bottom right corner until you see change language,
  4. Tap change language,
  5. Follow the instruction on the screen to confirm the language of your choice,
  6. Choose a voice.
That should do the job.
Dec 25, 2010 | Tomtom Ease GPS Receiver
Picked wrong language with instalation
Hi tammy,
Did you pick the wrong language for wondows vista? or was it another program?
Nov 13, 2008 | Acer Computers & Internet
Kodak easy share digital camera C763
go to menu and click each choice until you see a choice of language. English should be obvious ( I think). If that doesn't work, look in your manual for a way to restore it to factory settings. You might even just remove the batteries for about 15 minutes or so. When I replace my batteries I always have to reset my settings such as date. I hope this works
Dec 10, 2007 | Kodak EasyShare One Digital Camera
Wrong Language
2 possible solutions for you. Take the batteries out. Press the power button (with batteries out). Nothing will happen. It's OK. Leave batteries out for 4-6 hours. Re-install batteries. Camera should default to initial set-up screen, where it will ask you for the language of choice.
Solution 2 is turn camera on. Press menu and navigate to set-up (configuracion). Navigate to language (lang.) and select english. That should take care of it. Hope it helps.
Dec 03, 2007 | Fuji FinePix E550 Digital Camera
Samsung J700 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
