Question about Nokia e65 Cellular Phone
Nokia E65, How do I remove the Calender & WLAN Settings off Front Screen? Located below the normal Front Screen Icons running Left to Right are 2 Icons, one is a Calender Page stating "No cal.entries for today" the other is directly below this stating "No WLAN network found". No matter how much i have searched through settings etc i cant seem to remove them from the front screen. Pain as is blocking my Wallpaper can anyone help??
  • Anonymous Apr 30, 2009
    THE WAP IS NOT WORKING WHY?
Go to move settings
Posted on Jun 16, 2008
Tools/Settings/Phone/Standy Mode/Active standby plug-ins
Select the ones you want, deselect the ones you dont want :)
Posted on Jun 07, 2008
I cannot connect my nokia c7 to the internet through wifi
Hi, pls verify below steps,
1.Whether WLAN switched on and has a good WLAN coveage. 2.Security settings on WLAN options
- Check the security modes (Open/WEP/WEP2 - this depends on your WLAN connection) - Check Security settings (Public shared Key settings)
3.You have to be a authorized user in WLAN network if it requires authentication login. 4.Open the browser on you mobile and select General->Connection->Always Ask, then it will prompt for the connection type, Select WLAN.
Thanks, Ramaly
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
FOR HOW LONG CAN THE BATTRY LAST BEFORE YOU CHANGE IT
How Long Does the Nokia E65 battery REALLY last?
Ever wonder how long the phone battery actually lasts? For the first use of my Nokia E65, I charged the phone for 24 hours after receiving it (still not sure if this is necessary), then took it off the charger Saturday afternoon. The battery low warning first sounded 54 hours later. This was after
•Calls: Around 15 calls made and about 3 calls received, with almost 40 minutes call duration in total.
•Data: 726kb data sent and 3.96mb downloaded
•WIFI: About 20 minutes of WIFI use
•Applications: Use of Skype and Gmail application as well as a bit of Nokia Maps and Google Maps
The battery eventually gave up after 2 more hourse of standby. The Nokia website says the following about the Nokia E65 battery:
•BP-4L 1500 mAh Li-Po standard battery
•Talk time (maximum): GSM up to 11 hours; WCDMA up to 4h 40 min
•Standby time (maximum): GSM up to 18 days; WCDMA up to 20 days;WLAN idle up to 170 hours
If you are wanting to make comparisons with the Nokia E71 battery life, this is what the Nokia website claims for the Nokia E71. The Nokia E65 and E71 both use the same battery - BP-4L 1500 mAh Li-Po battery but E71 is slightly more demanding on the battery life.
•Talk time:- GSM up to 10 h 30 min- WCDMA up to 4 h 30 min
•Standby time:- GSM up to 17 days- WCDMA up to 20 days- WLAN idle up to 166 hours
If you are willing to help, maybe you can do the same experiment for your Nokia E65. Use the call logs and the data counter under "Connectivity" and measure how long your Nokia E63 battery lasts with "normal" usage. Report your findings in the comments below and someone just as curious as you googling battery life E65 will also benefit from your efforts.
Your mobile habits may not be as demanding as me but I hope this helped you in your battery life calculations for the Nokia E65.
To charge a battery from empty to full, it took 2 hours and 40 minutes
....... If you are willing to help, maybe you can do the same experiment ... It lasts me about 40 hours before I get a battery low warning .... I got my Nokia E65
Jan 05, 2011 | Nokia e65 Cellular Phone
How do i remove icons from my standby screen nokia 6700 slide they are no calender entries today and share your photos thanx
The only way to do it is to set the contacts bar as the standby theme (menu>settings>settings>general>personalisation>standby mode>standby theme), then go back into the standby mode menu, into Home screen applications and untick all the boxes. You are left with the shortcut bar along the bottom of the home screen, and nothing else. Nice. And stupidly complicated. Thanks Nokia.
Dec 27, 2010 | Nokia 6700 Slide Cell Phone
How do I remove the apps icons (like calender etc icons) from the home screen?
click and hold down the app you dont want then it should come up with a trash bin in the bottom right corner just drag it into that :)
Dec 05, 2010 | Samsung Galaxy S GTI9000 Smartphone
I have n97 from china and i cant remove the shortcut icons on the menu. how can i delete them? i deleted all the items in the shortcut settings but it still appears in the stand by menu.
Hi, there are two desktop backgrounds on the China N97, one has the shortcut icons and the other one is a background without the icons, the shortcut icons on the first cannot be removed to the walk around for it is to press and hold the existing background and the dragging the finger to either the left or right of the screen, this should change the background and the shortcut icons must be gone.
Feb 08, 2010 | Nokia N97 Cell Phone
Booting up all desktop icons have moved to right and are larger
You will need to set your display setting.
follow the process.
1. right click on desktop>go to properties.
2. select tab 'Settings'
3. go down to 'colour quality' and select 'Highest (32 bit)
4. then go slight left to 'Screen Resolution' and drag the bar towards 'More' according to your need.
5. apply the settings and the screen will flick for a few seconds.
this is a quite normal procedure for these kind of issues but if it still doesnt work our then let me know.
Aug 20, 2009 | Apple iBook G3 Mac Notebook
Nokia n95 home screen
I have tried to remove the vertical menu's while maintaining the horizontal shortcuts above, but it doesn't seem possible via the N95 menu. I'm sure there's a more extreme method, but that would be way too much of a pain....
Anyhow, if you would like to remove all of the shortcuts, here's the procedure (N95 non 8GB):
Settings -> General -> Personalisation -> Standby Mode -> Active Standby (OFF)
On my old N95, Settings are under "Tools" in the main menu, however, this may have changed on the newer versions. Although this may not strictly be the procedure for the 8GB version, hopefully it will help.
Cheers
Jul 21, 2008 | Nokia N95 Cellular Phone
AOSS
you need a wireless connection. And so after that, you go to the internet icon,and then you just type in your link.
1. Go to the Main Menu of your PSP.
2. Go to Settings.
3. Scroll down to Network Settings and Press the X button.
4. Select Infrastructure Mode.
5. Select New Connection.
6. Name the connection so that you know it is for web browsing. (ex. WebConnect)
That way you can use another connection for the rest of your online games.
7. Push the Right Direction Key to go to the next menu.
8. Select the Scan option and let it pick up your WLAN settings.
9. Once it picks up a connect, Push the Right Direction Key to go to the next menu.
10. Select Custom for the Address Settings.
11. Push the Right Direction Key to go to the next menu.
12. Leave IP Address Setting on Automatic.
13. Push the Right Direction Key to go to the next menu.
14. Select Manual for your DNS Setting.
15. Push the Right Direction Key to go to the next menu.
16. Enter in 67.171.70.72 as your Primary DNS and just leave the Secondary DNS blank.
17. Push the Right Direction Key to go to the next menu.
18. Select "Do Not Use" for your Proxy Server settings.
19. Push the Right Direction Key to go to the next menu.
20. Push the Right Direction Key to go to the next menu.
21. Push the X button to save your settings.
22. Do a quick test of the connection to make sure it's working correctly. first you need to have a wireless internet at home. next you need to turn on the wlan on your psp, located at the left side corner of your psp. search for a wlan around you. if its not secured, your lucky, you can connect anytime, but if it has a wep key, you need to find out the key to be able to connect. Switch the wlan button (located on the left side) to on and if don't aoss router seperate from the psp you cannot use automatic. So goto new connection and press scan. Follow on screen instructions.
If you do have an aoss router press button on the aoss router inself so the psp can find it.
Okay now that ive given you your answer make sure to follow fixya's system. Instead of taking the answer and running.
THANK YOU,
NATE
Jun 17, 2008 | Sony PlayStation Portable (PSP) Console
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
E65 screen black out
try to check the sensor light on the upper left part and press it maybe its a little loose only....because i had the same problem a while ago and when i press the one connected to the sensor light.... a small brown board, it works properly...maybe yours is a little loose also....no need to pay try this one first....
Jan 29, 2008 | Nokia e65 Cellular Phone
Nokia e65 Cellular Phone Logo
167 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
