Question about Siemens SX66
Hard reset I took the battery off as you said but it didn't work
  • Gaschech May 25, 2008
    You can download the file mitty 1.42 from this website.
    www.tompda.com/bbs/display.asp?forumID=2052114&luntan=27
Press and hold the Power Button + Reset button simultaneously and that will give you a Hard Reset.
Posted on Dec 08, 2008
The back button is not functioning.
I will not be very helpful but I have the same problem. I took it apart, fiddled with the ribbon flex and then it worked for a while if I squeezed it hard. Then it stopped working again, I took it apart, cleaned the ribbon flex and the sockets with alcohol but it didn't help...
Jan 05, 2011 | Sony Ericsson P1i
My motorola Q9m won't turn on at all. I've tried everything..Took the battery out and put back in, it won't turn on at all.
I had the same problem. We took the battery out twice and put it back in and it did not do anything. A third person tried taking out the battery and putting it back in and the phone works fine now.
I'd focus on the battery connections.
May 19, 2010 | Motorola Mobility Moto Q
How to format the phone
For soft reset type *#7780# For hard reset type *#7370# and if it ask passcode enter the passcode as 12345 as default.Please backup all your data if you performing hard reset because hard reset deletes all data on your phone like contacts,messages,music,videos and photos
Feb 22, 2010 | Sony Ericsson K810i Blue Smartphone
The PC is not switching on
Hi. I assume that you plugged in your original battery after it was out a while. When your device's battery is drained, all the data in your device may be resetted (changes according to your backup battery's condition). So you should first try to plug it into AC power source for a couple of hours without touching it (Let the battery become usable enough). Then, your device should open without any error, but it may take a while because it will install the Operating System from ROM. In most cases, pluging out your battery won't destroy any internal parts of your device, it may just reset it to factory default settings. If there is an error, here is how you can hard reset your device:
HP iPAQ rx3715 Hard Reset:
1. Hold down the Mobile Media button (on the far left) and the iTask button.
2. Then press down the reset button with the styles for a few seconds until the screen goes dark.
3. To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Hope this helps.
May 31, 2009 | HP iPAQ RX3715 Pocket PC
Hard reset and charging problems
do the hard reset again .. hold the power button down while operating the reset in the back .. keep the power button down for a few seconds .. that should bring up a display "delete all" .. you can choose to do so .. that will be a hard reset .. now if the battery is dead and the charger is not working then nothing will work for you .. you might have a bad charger .. often the end that plugs into the unit develops a broken wire inside the cable ..
the m515 wont charge from the sync cable (shame) it needs the external power adapter .. make sure the connections on the charger and palm are clean .. the power adapter is 5 volts and i think about 1 amp .. )(center pos) if you want to try another adapter .. the tip is rather standard ... also you can get a universal power adapter from radio shack that will work on just about anything .. you just plug in a suitable tip .. the tip for your palm is an "A19" .. the power adapter is "IGO" wall adapter 23-1401 model PSM08VADJ ... that seems to work nicely and it plugs directly in to the palm .. so you can work with it plugged in .. when the charger is working there should be a lightning bolt thru the battery symbol .. it sounds like you already know that .. if the battery has gone open then it may not indicate a charge .. but the unit should still work while on the charger if that is actually working ....
Apr 13, 2009 | Palm m515 Handheld
Msg when off... "Data Abor... Reset"
Download the latest handheld OS for your BlackBerry
- wipe out the BB using JL_CMDER
- reload the OS
- don't play with themes
Jan 11, 2009 | RIM BlackBerry 7250
My blackjack wont charge
I did a hard reset because i was having the same problem with a new battery and a new charger. I took my sim card out first to prevent any possible data loss. then followed the following steps:
  1. Once the handset has rebooted to the Today Screen, enter the following code: *2767*3855#. The handset should display a message “Formatting- Please wait a moment”.
  2. The phone will reboot after the Full Reset as this is normal operation.
after i did that i plugged in the charger and it worked perfectly. this is the last step that you would do after updating the software on the BJ
Mar 31, 2008 | Samsung Blackjack SGH-I607 Smartphone
Touch screen not working
You Will need to Hard reset the phone but make sure you back up your info first, because a hard reset will delete all info. To Hard reset the phone hold the two Soft keys which of Dots on them and then while holding those buttons press the reset button located on the bottom of the phone by the Charging port.
Mar 20, 2008 | Sprint Vision PPC-6700 Smartphone
Failing to power up.
Had the same problem: the battery is simply exhausted. Suggest you buy a new battery. A possible solution you might try is to connect it to a charger and make a hard reset (loosing all data and programs stored). Good luck
Sep 03, 2007 | HP iPAQ H5450 Pocket PC
Siemens SX66 Logo
159 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
